In the image,
Throttle request stays near flat
throttle body dips
boost and wastegate dip and regain over and over
Speed trending upward smoothly
think normal driving, then getting nicely up to speed on an on-ramp boost levels 5-8psi max
upgraded to an 11 lb spring in the Tial
Car is an 11 Flex
FBO - like everything in the catalog , GH turbos, EPP hot pipes "with Tial"
knock counts are clean and negative,
anybody have a similar issue? thoughts on where to continue looking?
Following
Quote from: autox4fun on September 26, 2020, 11:25:49 AM
In the image,
throttle body dips
no boost leaks that I can find, also upgraded to an 11 lb spring in the Tial
Car is an 11 Flex
FBO - like everything in the catolog , GH turbos, EPP hot pipes "with Tial"
can you post the full log? what bugs me is the jitter in the tan/brown line? is that the RPM or speed ?
In the image,
throttle body dips
Car is an 11 Flex
Literally just had this problem amongst others, but what you are describing is was the most prevalent issue that I could feel driving. It ended up being the Boost Control Solenoid which is $79.29 at your local dealer.
I swapped mine in the dealer parking lot after picking up the part.
Boost Control Solenoid - https://www.tascaparts.com/oem-parts/ford-turbocharger-boost-solenoid-bl3z9k378a
Quote from: StealBlueSHO on September 30, 2020, 05:01:24 PM
In the image,
throttle body dips
Car is an 11 Flex
Boost Control Solenoid - https://www.tascaparts.com/oem-parts/ford-turbocharger-boost-solenoid-bl3z9k378a (https://www.tascaparts.com/oem-parts/ford-turbocharger-boost-solenoid-bl3z9k378a)
I had two go bad in a year :P but mine would opt to NOT open the wastegates or partially open and build too much boost
Quote from: TopherSho on September 30, 2020, 06:23:49 PM
In the image,
throttle body dips
Car is an 11 Flex
Yea, I had that issue as well. Always assumed it was issues dealing tuning bigger turbos.. Until Matt at Gearhead had enough data on his turbo's from various other cars.. he was like.. something is off.. check the BCS..
This is a newer part ... 5K miles old.
I did a boost leak test tonight and I had a few small ones at couplers and got those locked down.
What I'm rather upset with is the fittings on the UPR catch can. Major leaks - the 45 I was able to slide out of the hose. I've had the kit for two years, the ends are just press fit fittings to hose - no clamps. The current pictures on their website show worm gears hose clamps on each fittings. I'm going to dig up my old hoses and see if I can get a set of turbos to finally hit hard.
Quote from: TopherSho on September 29, 2020, 04:44:41 PM
In the image,
throttle body dips
Car is an 11 Flex
SPEED is the Brown line
How blown up is that graph ? It should not be that jittery and makes me think speed sensor ...
