Quote from: bpd1151Wanted to express my complete gratitude to fellow forums member dbulldog for compiling this following list of TSB's that apply to the 2010-2012 model year's of SHO's.
dbulldog pm'd me this list the other day after advising that he finally "found" this site. I hope each of you take a moment to visit dbulldog's EB profile page and both welcome him here, and thank him for this gi-normous contribution thumb:
To that end, on with the info.......
2010
• 11-12-10 - 6F50/6F55 TRANSMISSION - SLUGGISH ACCELERATION FROM 0-8 KM\H (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP - BUILT ON OR BEFORE 4/15/2011
• 11-11-20 - DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES
• 11-11-16 - SIRIUS RADIO WITH NAVIGATION - VARIOUS FUNCTIONALITY CONCERNS - BUILT ON OR BEFORE 3/8/2010
• 11-11-09 - INTERMITTENT STEERING DRIFT/PULL - BUILT ON OR BEFORE 6/11/2010
• 11-10-07 - INTERMITTENT AIR BAG WARNING INDICATOR - DTCS B0028, B1213 WHEN PASSENGER CLIMATE CONTROL SEAT COMMANDED ON
• 11-08-19 - 3.5L GTDI ENGINE RUNS ROUGH, HESITATES, SHUDDERING WITH MISFIRE DTCS P0300, P0301, P0302, P0303, P0304, P0305, P0306 OR P0316
• 11-08-03 - BLIND SPOT INFORMATION SYSTEM (BLIS) AND CROSS TRAFFIC ALERT (CTA) - FALSE BLOCKAGE AND/OR DIAGNOSTIC TROUBLE CODE(DTC) - U3000 - BUILT ON OR BEFORE 3/29/2011
• 11-05-15 - FRONT BRAKES - INTERMITTENT GRUNT OR GRINDING NOISE
• 11-04-20 - 6F50/6F55 TRANSMISSION AWD - FLUID LEAK - BETWEEN PTU ASSEMBLY AND TRANSMISSION CASE
• 10-22-04 - AWD VEHICLES - SHUDDER/CHATTER/VIBRATION ON TURNS OR THUMP/CLUNK NOISE ON LIGHT ACCELERATION - BUILT 10/1/2009 TO 12/31/2009
• 10-21-06 - DTC P2111 OR P2112, OR LOWER THAN DESIRED ENGINE IDLE SPEED, ENGINE IDLE SPEED FLUCTUATES WITH OR WITHOUT DTCS
• 10-21-02 - 6F50/6F55 TRANSMISSION - SLIP/NEUTRAL OUT, 5TH GEAR START FROM STOP, ELECTRONIC PRNDL ERROR, BACKUP CAMERA IN D - BUILT 3/13/2009-6/30/2010
• 10-20-08 - TIP-IN DELAYED SHIFT AT SPEEDS BETWEEN 15-20 MPH (24-32 KM/H)
• 10-20-06 - BLIND SPOT INFORMATION SYSTEM (BLIS) AND CROSS TRAFFIC ALERT (CTA) - FALSE DTC B11D6:15 WITH INTERMITTENT FAULTS - BUILT ON OR BEFORE 5/21/2010.
• 10-18-07 (http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=172698) - SPEEDOMETER INDICATOR NEEDLE STICKING OR INACCURATE - BUILT ON OR BEFORE 3/25/2010
• 10-15-02 - CENTER HIGH MOUNT STOPLAMP REPAIR/REPLACEMENT PROCEDURE
• 10-14-02 - PTU FLUID LEAK - VENT AREA
• 10-13-04 - SYNC NON-NAVIGATION - NO TURN-BY-TURN DIRECTIONS AND/OR UNABLE TO PIN POINT VEHICLE LOCATION - BUILT ON OR BEFORE 6/14/2010
• 10-13-03 - FM RADIO RECEPTION/SOUND QUALITY CHANGES WHILE DRIVING OR SATELLITE RADIO SIGNAL BLEED THROUGH WHEN USING AUDIO SYSTEM IN AUX MODE
• 10-09-09 - 6F50/6F55 TRANSMISSION - DTC P0751 - HARSH OR NO FORWARD ENGAGEMENTS - PERCEIVED SLIP ON ACCELERATION - SLIP/DELAYED AND/OR HARSH DOWNSHIFTS
• 10-08-03 - SYNC - CALL SOUND QUALITY/BACKGROUND NOISE ISSUES AND/OR VOICE RECOGNITION DIFFICULTIES WHILE DRIVING
• 10-08-01 - ADAPTIVE CRUISE CONTROL (ACC) - TURNS OFF
• 10-07-02 - REAR BRAKE DRAG OR REAR BRAKE NOISE - BUILT ON OR BEFORE 12/14/2009
• 10-06-04 - 6F55 TRANSMISSION WITH ECO BOOST (GTDI)- BUMP 3-1 COASTING DOWNSHIFT BELOW 10 MPH (16 KM/H) BUILT ON OR BEFORE 3/1/2010
• 10-06-02 - REAR PACKAGE TRAY/SPEAKER RATTLE/BUZZ WITH THE RADIO ON - BUILT ON OR BEFORE 12/9/2009
• 10-06-01 - POWER STEERING FLUID LEAK AT THE RESERVOIR FILL CAP
• 10-05-12 - INTELLIGENT ACCESS KEY WITH NO KEY DETECTED OR NO FOB DETECTED - BUILT ON OR BEFORE 3/11/2010
• 10-05-09 - LUGGAGE COMPARTMENT LID SOLENOID STUCK OPEN
• 10-04-03 - 6F50/6F55 TRANSMISSION - SHIFT FLARE INITIAL 2-3 SHIFT / SLIGHT DELAY/BUMP 3-1 COASTING DOWNSHIFT BELOW 10 MPH (16 KM/H) BUILT ON OR BEFORE 11/17/2009
• 10-02-08 - SYNC SYSTEM DEFAULTS TO OR STAYS IN PRIVACY MODE, MULTIPLE VEHICLE LINES
• 10-02-06 - AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION, NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS
• 09-25-07 - SERVICE TIP - POWER TRANSFER UNIT (PTU) - RIGHT HAND INTERMEDIATE SHAFT SEAL LEAKS
• 09-24-13 - RAIN SENSOR MOUNTING RING DETACHED FROM WINDSHIELD
• 09-23-08 - DTC P0096-INTAKE AIR TEMPERATURE: IAT SENSOR 2 CIRCUIT/RANGE PERFORMANCE - BANK 1 - BUILT ON OR BEFORE 10/14/2009
• 09-23-02 - RADIO - HIGH PITCH WHISTLE OR WHINE NOISE BUILT ON OR BEFORE 9/24/2009
• 09-19-02 - POOR AM / FM RADIO RECEPTION WITH REAR DEFROST ON
2011
• 12-01-16 - SYNC - INTERMITTENT VOICE RECOGNITION - BUILT ON OR BEFORE 6/15/2011
• 11-10-29 - FRONT BRAKES - INTERMITTENT SQUEAL
• 11-07-21 - COOLING FAN NOISE, LACK OF A/C AND/OR OVERHEAT CONDITION
2012
Do we have anyone that can take some time to update the list? I realize it is time consuming, so thanks in advance.
If someone can PM or reply here with the updates I'll edit
Originally posted by bpd1151Quote03-04-2012, 03:19 PM
Originally posted by SoCalSHO View Post
Now, where can we get the narrative of the TSB's? I am looking for 11-11-20 and 11-12-10. Thanks
TSB 11-11-20(Ed: Superseded by 12-09-02 http://www.fordservicecontent.com/pubs/content/~WT/~MUS~LEN/3583/tsb12-09-02.pdf (http://www.fordservicecontent.com/pubs/content/~WT/~MUS~LEN/3583/tsb12-09-02.pdf))DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES
Publication Date: November 17, 2011
FORD: 2010-2012 Taurus
ISSUE:
Some 2010-2012 Taurus vehicles may exhibit road dust accumulation on the rear door scuff plate area.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Paint the replacement body quarter trim panel from the Dust Kit to match the vehicle exterior color.
Install the Dust Kit parts. Refer to instruction sheet included in the kit.
PART NUMBER PART NAME
AG1Z-5420530-D Dust Kit
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
111120A 2010-2012 Taurus: Install The Revised Weatherstrip Kit Following The Kit Instructions. Can Be Claimed With Operations B And C As Necessary 2.3 Hrs
111120B 2010-2012 Taurus: Additional Time To Prep and Paint New Molding Assemblies. Can Be Claimed With Operations A And C 1.5 Hrs
111120C 2010-2012 Taurus: Additional Time For Vehicles With Tri-Coat Finish. Can Be Claimed With Operation A And B 0.5 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
5420530 42
__________________________________________________ __________________________________________________ _________________
TSB 11-12-10http://www.fordservicecontent.com/Ford_Content/pubs/content/~WT/~MUS~LEN/3517/tsb11-12-10.htm (http://www.fordservicecontent.com/Ford_Content/pubs/content/~WT/~MUS~LEN/3517/tsb11-12-10.htm)
6F50/6F55 TRANSMISSION - SLUGGISH ACCELERATION FROM 0-8 KMH (0-5 MPH) FOLLOWED BY A HARSH BUMP OR A SLIP ON TAKE-OFF FOLLOWED BY A BUMP - BUILT ON OR BEFORE 4/15/2011
Publication Date: December 19, 2011
FORD: 2010-2011 Taurus
2009 Edge, Flex
2010-2011 Edge, Flex
2011 Explorer
LINCOLN: 2010-2011 MKS
2009 MKX
2010-2011 MKT, MKX
This article supersedes TSB 11-9-11 to update the Service Procedure.
ISSUE:
Some 2009 Edge, MKX and Flex vehicles built on or after 5/4/2009, 2010-2011 Edge, Flex, MKS, MKT, MKX, Taurus and 2011 Explorer vehicles built on or before 4/15/2011 may have a sluggish acceleration or hesitation feel during a rolling stop 0-8 Km/h (0-5 MPH) followed by a harsh bump or feel like a slip on take-off from a stop followed by a harsh bump.
ACTION:
SERVICE PROCEDURE
This valve body modification is only available for transmissions originally built with MERCON® LV listed on the dipstick.
There is a new calibration and transmission valve body change to correct this condition. The valve body change was to delete one hole in the valve body separator plate and remove one check ball from the valve body in the same area where the hole in the separator plate was deleted.
NOTE: IF THIS PROCEDURE IS NOT FOLLOWED CORRECTLY, ADDITIONAL NEW CUSTOMER SYMPTOMS WILL BE PRESENT, SUCH AS LOSS OF REVERSE OR 2-3 SHIFT FLARE.
For all model years except 2009, proceed to Step 2. For 2009 model year vehicles, verify the transmission dipstick has MERCON® LV listed on the dipstick.
Yes - The dipstick has MERCON® LV listed on the dipstick; proceed to Step 2.
No - The dipstick does not have MERCON® LV listed on the dipstick; this procedure does not apply. Follow normal Workshop Manual diagnostics.
Reprogram the PCM to the latest calibration using IDS release 73.04 and higher. This new calibration is not included in the VCM 2011.5 DVD. Calibration files may also be obtained at www.motorcraft.com (http://www.motorcraft.com).
Remove the transmission valve body. Refer to the Workshop Manual (WSM), Section 307-01.
Replace both separator plates listed in the Parts List. The X identifies the hole in the valve body separator plate which will be eliminated. (Figure 1)
Figure 1 - Article 11-12-10
Remove one (1) check ball identified as X. (Figure 2)
Figure 2 - Article 11-12-10
Proper check ball locations on the remaining six (6) valve body check balls shown with arrows. (Figure 2)
Install transmission valve body. Refer to WSM, Section 307-01.
BT4Z-7Z490-B Valve Body Separator Plate
7T4Z-7Z490-D Valve Body Separator Plate
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
111210A 2009-2011 Edge And MKX: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.0 Hrs.
111210A 2010-2011 Taurus And Flex 3.5L DOHC, MKS And MKT 3.7L, 2011 Explorer 3.5L: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.0 Hrs.
111210A 2010-2011 Taurus, MKS, Flex, And MKT 3.5L GTDI: Replace The Separator Plate, Includes Time To Remove And Install Main Control, Remove Check Ball, And Reprogram The PCM (Do Not Use With Any Other Labor Operations) 3.1 Hrs.
DEALER CODING
7A100 42
04-27-2012, 08:56 AM
**RECENTLY ADDED** .....and applies to 2010 MY's:
12-02-08 - INTERMITTENT STEERING DRIFT/PULL - BUILT ON OR BEFORE 6/11/2010
FORD: LINCOLN:
2010 Taurus, Flex 2010 MKS, MKT
This article supersedes TSB 11-11-9 to update the
Integrated Diagnostic System (IDS) calibration.
WARRANTY STATUS: Eligible Under Provisions Of
New Vehicle Limited
ISSUE Warranty Coverage
Some 2010 Taurus, MKS, Flex and MKT vehicles built on or before 6/11/2010 and equipped with a
3.5L gasoline turbo direct injection (GTDI) engine may exhibit an intermittent steering pull/drift left or right. A customer may describe the condition as one where they believe the vehicle needs a front end alignment.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS
part coverage tool.
ACTION OPERATION DESCRIPTION TIME Reprogram the power steering control module 120208A 2010 Flex, MKT, Taurus, 0.3 Hr. (PSCM) to the latest calibration using IDS release And MKS 3.5L GTDI:
75.04 and higher. This new calibration is not Reprogram The Power
included in the VCM 2011.9 DVD. Calibration files Steering Control Module
may also be obtained at www.motorcraft.com (http://www.motorcraft.com). (Do Not Use With Any
While reprogramming the PSCM the IDS may automatically reprogram the anti-lock brake system (ABS) module. As a result, during the PSCM
DEALER CODING
CONDITION
programming procedure, you may see screens indicating the ABS is being programmed in addition
BASIC PART NO. CODE
3504 04
to the PSCM. PROGRAM CODE:
If the vehicle has a constant pull and/or drift left or right, do not continue with this article. Refer to the Workshop Manual, (WSM) Section 204-00 for normal diagnostics.
T12
This is reimbursable as a Pre-Defined Repair only. Claim using the unique program code provided. Since this TSB has a program code, entering the parts, labor and misc. expense details is optional.
Thanks so much for updating this Shodded.
http://www.fordservicecontent.com/Ford_Content/pubs/content/~WT/~MUS~LEN/3631/tsb13-05-27.htm (http://www.fordservicecontent.com/Ford_Content/pubs/content/~WT/~MUS~LEN/3631/tsb13-05-27.htm)
TSB 13-5-27
6F50/6F55 TRANSMISSION - SLIP/NEUTRAL OUT - 5TH GEAR START FROM STOP - BACKUP CAMERA ON IN DRIVE - BUILT 3/13/2009-6/30/2010
Publication Date: May 27, 2013
FORD: 2009-2011 Taurus, Edge, Flex
LINCOLN: 2009-2011 MKS, MKX; 2010-2011 MKT
This article supersedes TSB 13-4-2 to update Service Procedure
ISSUE:
Some 2009-2011 Edge, Taurus, Flex, MKS, MKX and 2010-2011 MKT vehicles equipped with a 6F50 or 6F55 transmissions and built on 3/13/2009 and through 6/30/2010 may intermittently exhibit one or more of the following concerns; transmission slipping or neutral-out, 5th gear start from stop, backup camera on in Drive, or speed control dropping out or inoperative. This may be due to high resistance in the digital transmission range (TR) sensor.
ACTION:
Follow the Service Procedure steps to correct the concern.
SERVICE PROCEDURE
Check the TR sensor circuit resistance.
1. With brakes applied, engine off, key on, move the shifter to low gear (L or M) position.
2. Turn key off.
3. Disconnect connector C168 from the transmission.
4. Measure the resistance between the transmission connector pins:
8 and 4
8 and 5
8 and 6
8 and 7
a. The top row of the transmission's pins are numbered 1-10 from left to right. (Figure 1)
(http://www.ecoboostperformanceforum.com/gallery/60_09_01_14_3_43_24.jpeg)
Figure 1 - Article 13-5-27
b. If any of the four measurements are above 5 Ohms, proceed to Step 5.
c. If all measurements are within specification, this article does not apply. Refer to the appropriate Workshop Manual (WSM) Section for diagnosis and repair.
5. Replace the TR sensor. Refer to the WSM, Section 307-01.
a. Use only essential special service tool (ESST) 307-696 to remove the retaining pin that holds the TR sensor in the transmission case.
b. Attach ESST 307-696 to the transmission case with two (2) pan bolts.
c. Slide the cylinder over the head of the retaining pin and tighten the nut on the threaded shaft to pull the cylinder up and retaining pin out of the transmission case. (Figure 2)
(http://www.ecoboostperformanceforum.com/gallery/60_09_01_14_3_43_54.jpeg)
Figure 2 - Article 13-5-27
d. Do not allow the park pawl actuator rod to become disengaged from the park pawl and the abutment. Keep the end of the park pawl actuator rod behind the machined valve body mating surface of the transaxle case. If the park pawl actuator rod becomes disengaged from the park pawl and the abutment, transaxle removal and disassembly is required to install the actuator rod. (Figure 3)
(http://www.ecoboostperformanceforum.com/gallery/60_09_01_14_3_44_15.jpeg)
Figure 3 - Article 13-5-27
9E9Z-7H557-B TR Sensor
7T4Z-7B210-A Retaining Pin
WARRANTY STATUS:
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
130527A 2009-2011 Edge, Flex, MKX, MKS, Taurus and 2010-2011 MKT: 2.5 Hrs.
Replace The TR Sensor Includes Time To Perform The Diagnosis
In The Service Procedure
DEALER CODING
7H557 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2013 Ford Motor Company
SSM 44863 - Effective Dec 11 2014 2010-2015 Multiple Vehicles - Flutter/Turbulance Noise At Highway Speeds With Rear Windows Or Moon/Sun Roof Open
SSM 44856 (http://www.ecoboostperformanceforum.com/index.php/topic,496.msg120529.html#msg120529) - Effective Dec 8 2014 Various 2011-2015 Vehicles - Cruise Control Speed Setting Display May Not MatchSpeedometer
SSM 44829 - Effective Nov 20 2014 Various SYNC Equipped Vehicles – Apple iOS 8 and or iPhone 6 Functional Issues
TSB 14-0213 - Effective Nov 12 2014 Multiple Vehicle Lines Equipped With 3.5L TiVCT Or 3.7L Built on 1/3/2012 and Through 7/31/2012 - Malfunction Indicator Lamp (MIL) On With DTC P1450
TSB 14-0209 - Effective Nov 10 2014 2011-2015 Various Vehicles - Shift To Park Message - While In Park / Unable To Remove IKT / Shifter Stuck In Park / Discharged Battery Due To Shift To Park Light On
TSB 14-0196 - Effective Oct 17 2014 2010-2014 3.5L GTDI - Excessive Oil Consumption And/Or Smoke From The Exhaust At Idle During Normal Engine Operating Temperature - Aluminum Valve Cover
SSM 44763 - Effective Oct 15 2014 New Wiring Repair Job Aid is available on PTS under the Service Tips tab
TSB 14-0186 - Effective Oct 6 2014 2011-2015 Explorer/Taurus 2011-2014 Flex/MKT/MKS - Ting/Pop/Click Noise - FrontHalfshaft
TSB 14-0175 - Effective Sep 19 2014 Various 2011-2014 - MyFord Touch/MyLincoln Touch - Ambient Lighting Defaults ToWhite Or Ice-Blue After Cycling Ignition Switch
SSM 44707 - Effective Sep 11 2014 2009-2015 Vehicles Exhibiting Diagnostic Trouble Code (DTC) P06B8, P068A And/OrP2610 After Powertrain Control Module Reprogramming
SSM 44690 - Effective Sep 1 2014 2013-2015 Explorer, Taurus, MKS Exhaust Studs Not Missing
SSM 44689 - Effective Sep 1 2014 2010-2015 MULTIPLE VEHICLE LINES - DIAGNOSTIC PRACTICE OF MODULE SWAPPING OR LIKE VEHICLE ORDERING IS NOT RECOMMENDED
SSM 44676 - Effective Aug 21 2014 New "Live Network Monitor Test" available on PTS.
TSB 14-0132 - Effective Jul 22 2014 Easy Fuel Capless - Concerns With Fuel Nozzle Insertion Or Removal
SSM 44649 - Effective Jul 17 2014 2007-2015-Multiple Vehicles Equipped With All Wheel Drive-PTU Job Aid in Service Tips
TSB 14-0123 - Effective Jun 30 2014 2013-2014 Escape, Fusion, MKZ, Taurus, Flex, MKS, MKT - HD Radio Inoperative -Diagnostic Trouble Code (DTC) U3000:96
SSM 44628 - Effective Jun 30 2014 Multiple Vehicle Lines - Radio Can Be Turned On With Ignition Off and Door Open- Audio Extended Play Mode - Normal Operation
SSM 44582 - Effective Jun 6 2014 Unexpected Scan Tool And/Or Vehicle Electronic Module Behavior During Diagnostics
SSM 44578 - Effective Jun 4 2014 2007-2014 Vehicles Equipped With All-Wheel Drive And A 6F50/55 Transmission-Leak At The Power Transfer Unit Output Shaft Seal
SSM 44564 - Effective May 29 2014 2011-2014 Explorer,Taurus,Flex,Edge,MKX,MKT,MKS Workshop Manual Updates For Rear Brake Service
SSM 44553 - Effective May 22 2014 2013-2014 FWD Vehicles - 3.5/3.7L - Engine Oil Leak At Right hand Head-to-Block-to-front cover T-joint
TSB 14-0105 - Effective May 19 2014 2013-2014 Explorer, 2012-2014 Taurus, MKT And Flex - 3.5L GTDI Diagnostic Trouble Code (DTC) P0087 - Built On Or Before 6/1/2014
SSM 44546 - Effective May 19 2014 Dealer Installed Audio Upgrades
SSM 44531 - Effective May 2 2014 2009-2014 F-150/Taurus/Flex/MKT/MKS, 2010-2015 F-Super Duty, 2011-2014 Explorer Power Seat Track Binding/Seized, Grind, Squeal, Popping Noise Moving Forward or Rearward.
SSM 44469 - Effective Mar 27 2014 3.5L and 3.7L Lower Engine Noise, Timing DTC's or Internal Engine Damage after Crank Pulley Removal.
SSM 44461 - Effective Mar 21 2014 Various 2005-2014 - License Plate Lamp Water Entry Or Oxidation
SSM 44454 - Effective Mar 20 2014 Lower End Engine Noise Diagnostic Aid
TSB 14-0057 - Effective Mar 14 2014 All Wheel Drive - Fluid Leak From Rear Differential Vent Cap - Temperatures Below 0 Degrees C (32 Degrees F)
TSB 14-0037- Effective Feb 21 2014 Global Positioning Satellite Module (GPSM) - Navigation Display Offset Or Incorrect Position Built On Or Before 1/6/2014
TSB 14-0032- Effective Feb 19 2014 2013-2014 Explorer/Taurus/MKS/- AWD - Leak From PTU - Built On Or Before 12/11/2013
TSB 14-0023- Effective Jan 30 2014 2011-2014 Taurus - Headliner Dropping Down And/Or Loose At Rear Window Glass
SSM 44381- Effective Jan 28 2014 2011-2014 - Gasoline Vehicles - Updated PC/ED Diagnostics to Address P013A or P013C
SSM 44375- Effective Jan 24 2014 2013-2014 Taurus/Flex/MKS/MKT/Explorer - Fuel/Emission Line Retaining Clip - Now Available
SSM 44355- Effective Jan 15 2014 3.5L and 3.7L Lower Engine Noise, Timing DTC's or Internal Engine Damage after Crank Pulley Removal.
SSM 44333- Effective Dec 13 2013 2011-2014 All-Wheel Drive Vehicles Equipped With PTU Cooling
SSM 44330- Effective Dec 11 2013 "No PCM Communication" Job Aid in Service Tips.
SSM 44328- Effective Dec 11 2013 SOME VEHICLES COULD EXHIBIT MISFIRE CODES AFTER CERTAIN REPAIRS - MULTIPLE VEHICLE LINES
SSM 44315- Effective Dec 4 2013 2013 Model Year Explorer, Taurus, MKS, Flex, MKT, Fusion, MKZ, and Police Interceptor Utility and Sedan Vehicles may exhibit a fuel odor or hesitation.
TSB 13-12-02- Effective Nov 19 2013 Dirt Accumulation On Rear Door Scuff Plates
SSM 44227- Effective Oct 10 2013 2013-2014 Taurus, Edge, Explorer, Flex, MKT, MKS, MKZ and MKX - DTC P0709 Pinpoint Test Workshop Manual Update
TSB 13-10-06- Effective Oct 4 2013 MyFord Touch/MyLincoln Touch - Various Functionality Concerns - Built On Or Before 8/15/2013
SSM 44206- Effective Sep 27 2013 2010-2013 Multiple Vehicle Lines - Adaptive Cruise Control Module Alignment Job Aid
TSB 13-09-22- Effective Sep 25 2013 SYNC - Various Functionality Concerns
SSM 44156- Effective Aug 26 2013 IDS Coil On Plug (COP) Stress Test Application Usage
TSB 13-08-07-Effective Aug 20 2013 2012-2013 Multiple Vehicle Line -Intermittent/Inoperative Integrated Keyhead Transmitter (IKT) -Built On 9/1/2011 And Through 12/1/2012
SSM 44144-Effective Aug 19 2013 Multiple Vehicle Lines -Workshop Manual Update -Audio System -Section 415-00
SSM 44112-Effective Jul 30 2013 2013 Edge/Flex/Taurus/Explorer/MKS/MKT/MKX –6F50/6F55 Transmission –Built before 4/15/13 -MIL With DTCs P0741 And P1744 With No Additional Symptoms
SSM 32320-Effective Jul 12 2013 Multi-Vehicle Gasoline Engine Failure Analysis And Tips -Job Aid Release
TSB 13-06-11-Effective Jun 11 2013 2013 Police Interceptor Utility And Sedan - Front Door Window Glass Sticking Or Binding - Built On Or Before 3/26/2013
SSM 32241- Effective May 24 2013 2011 - 2013 Multiple Vehicle Lines With MyTouch - Touchscreen Calibration Process
SSM 32238- Effective May 23 2013 2013 Edge, MKX, Flex, Taurus, MKT, MKS, MKZ, Explorer Equipped With A 6F50 Or 6F55 Transmission Built On Or Before 10/26/12 With Slippage During Shifts
TSB 13-05-14- Effective May 13 2013 2011-2013 Explorer/Flex/Taurus/MKT/MKS - Ting/Pop/Click Noise - Front Halfshaft
SSM 32213- Effective May 8 2013 2013 Multiple Vehicle Lines - Workshop Manual Update - Voice Recognition - Section 415.00
TSB 13-04-16- Effective Apr 24 2013 6F50/6F55 Transmission - Intermittent No Upshift - Stuck In 1st Gear - No DTCs - Built On Or Before 9/22/2012
SSM 32173- Effective Apr 5 2013 2013 Police Interceptor Sedan/Utility - Active Transmission Pursuit Mode - Updated Workshop Manual Section 307-01
SSM 32163- Effective Mar 29 2013 2009-2013 F-150/Taurus/MKT/MKS, 2011-2013 F-Super Duty/Explorer - Power Seat Track Bind/Seized, Grind, Squeal Noise Moving Forward or Rearward.
SSM 32153- Effective Mar 26 2013 2009-2013 Brake Rotor Protective Soft Cover Removal
TSB 13-03-11- Effective Mar 20 2013 Global Position Satellite Module - Traffic Directions And Navigation - Unable To Locate Vehicle - Built On Or Before 01/15/2013
TSB 13-03-01- Effective Mar 1 2013 2013 Explorer/Taurus/MKS - Hazard Lights Staying On - Brake Warning Indicator On Keyless Entry Illumination On - Multiple Door Ajar Lights On With Doors Closed
TSB 13-01-13- Effective Jan 31 2013 2013 Escape/Fusion/Flex/MKT/MKS/Taurus - Audio Static Popping - Distorted Sound - Stereo To Mono Change On FM - Built On Or Before 12/10/2012
TSB 13-01-01- Effective Jan 3 2013 Vehicles with Easy Entry / Easy Exit Feature Power Telescoping/Tilt Steering Column Does Not Return To Correct Position
SSM 12055- Effective Dec 6 2012 2009-2013 Multiple Vehicle Lines - Battery Light Flickers - Stays On - Low Charging
TSB 12-11-08- Effective Nov 15 2012 Radio With 4.2-Inch Display Stays On 20-30 Seconds After Key Off And Door Open
SSM 12019- Effective Oct 29 2012 Low Current Switch Failures Due To Improperly Installed Accessories
SSM 22553- Effective Oct 19 2012 AUTO TRANS - MERCON LV FLUID COLOR
SSM 11024- Effective Oct 17 2012 2013 C-MAX/Focus Electric and Fusion/MKZ Hybrid - Instrument Cluster Functionality
SSM 22524- Effective Sep 27 2012 6F50/ 6F55 TRANSMISSION - NEW SERVICE TOOL FOR TRS RETAINING PIN REMOVAL
SSM 22512- Effective Sep 14 2012 LOWER END ENGINE NOISE DIAGNOSTIC AID
TSB 12-09-02- Effective Sep 10 2012 DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES
SSM 22501- Effective Aug 30 2012 6F50/6F55 TRANSMISSION MOUNTING BOLT QUANTITY CHANGE FROM 11 TO 10
TSB 12-08-12- Effective Aug 15 2012 ALL WHEEL DRIVE - FLUID LEAK FROM REAR DIFFERENTIAL VENT CAP - TEMPERATURES BELOW 32 DEGREES F (0 DEGREES CELSIUS)
SSM 22473- Effective Aug 10 2012 SERVICEABLE FUEL LEVEL SENSORS
SSM 22456- Effective Jul 31 2012 SYNC - APIM REPLACEMENT/PROGRAMMING - CONFIGURATION ERROR
TSB 12-07-03- Effective Jul 10 2012 MISSING PIDS FOR ALL WHEEL DRIVE (AWD)/4 WHEEL DRIVE (4WD)
SSM 22421- Effective Jun 28 2012 ACCESSORY (WIRELESS) KEYLESS ENTRY KEYPAD IS APPLICABLE WITH REMOTE KEYLESS ENTRY (RKE) ONLY AND THE RETRIEVAL OF MASTER CODE.
SSM 22416- Effective Jun 27 2012 2010-2013 MULTIPLE VEHICLE LINES - WIRING DIAGRAM SECTION 5 UPDATE FOR SUPPLEMENTAL RESTRAINT SYSTEM (SRS) CONNECTOR REPAIR
SSM 22387- Effective Jun 6 2012 BRAKE OVER ACCELERATOR FEATURE - 2011 - 2013 FORD AND LINCOLN PRODUCTS
SSM 22357- Effective May 16 2012 2010-2013 MULTIPLE VEHICLE LINES - DIAGNOSTIC PRACTICES OF MODULE SWAPPING IS NOT RECOMMENDED DUE TO THE MODULE'S ARCHITECTURE.
SSM 22343- Effective May 3 2012 2009-2013 MULTIPLE VEHICLE LINES - SIRIUS SATELLITE SUBSCRIPTION ASSISTANCE JOB AID
SSM 22339- Effective May 2 2012 2009-2013 MULTIPLE VEHICLE LINES - LIMITED NUMBER OF SATELLITE CHANNELS MAY OCCUR WHILE USING THE SEEK FUNCTION - SERVICE TIP
SSM 22324- Effective Apr 18 2012 2011-2013 MULTIPLE VEHICLE LINES - INVISION DUAL HEAD RESTRAINT DIGITAL VIDEO DISC (DVD) - REAR SEAT ENTERTAINMENT SYSTEM SUPPLEMENT
SSM 22280- Effective Mar 21 2012 2011-2013 EXPLORER, EDGE,MKX, 2011-2012 F-150 AND F-SUPER DUTY, 2013 FLEX, TAURUS, MKS AND MKT ADD ON EQUIPMENT CAUSING RUN-ON
SSM 22226- Effective Feb 21 2012 TORQUE CONVERTER LEAK TEST - (NON-6R60-75-80)- AUTOMATIC TRANSMISSION
Thanks to brucelinc and BiGMaC for finding this TSB:
http://www.f150forum.com/f70/ford-ecoboost-warning-part-2-my-findings-261533/index5/#post3541547 (http://www.f150forum.com/f70/ford-ecoboost-warning-part-2-my-findings-261533/index5/#post3541547)
Here it is TSB 14-0113
It is not quite perfect yet but shows they are working on the issue.
FORD:
2010-2014 Flex, Taurus; 2013-2014 Explorer
LINCOLN:
2010-2014 MKS, MKT
ISSUE
Some 2010-2014 Flex, MKS, MKT, Taurus and 2013-2014 Explorer vehicles equipped with a 3.5L Gasoline
Turbocharged Direct Injection (GTDI) engine with an aluminum valve cover may exhibit excessive oil consumption and/or
excessive engine oil smoking condition from the tail pipe at idle during normal engine operating temperatures.
ACTION
SERVICE PROCEDURE
1. Remove the positive crankcase ventilation (PCV) Valve. Refer to Workshop Manual (WSM), Section 303-08.
2. Inspect for oil in the crankcase vent oil separator through the PCV valve opening. Is there presence of liquid oil, more
than slight vapor?
a. No - this article does not apply refer to WSM, Section 303-00 for Excessive Engine Oil Consumption.
b. Yes - proceed to Step 3.
3. Replace the right hand valve cover, refer to WSM, Section 303-01D.
4. Replace the crankcase vent oil separator, refer to WSM, Section 303-08.
5. Drive the vehicle at normal operating temperature for 20 minutes at constant highway speed to remove oil residue
from catalytic converter.
This link may be helpful in pulling up TSBs:
http://www.revbase.com/BBBMotor/TSb/ (http://www.revbase.com/BBBMotor/TSb/)
Most current ones may not show up, be aware.
Thank you for keeping up on these TSBs. My wife's car was slipping to neutral. I live in snow and ice, and if this were to happen in the winter, my family could have been in an accident. She took it in a year ago and was told that they couldn't duplicate the symptoms. Nothing was fixed. As much as I would like to up the performance, I'm trying to have a car that won't kill my wife and kids first. This transmission TSB gave me the info I needed to get her car fixed. Thanks again. After the warranty is up though, she'll be smoking M5s.
Thank you to jmr061 and Sinister-CO!
OASIS SPECIAL SERVICE MESSAGE NUMBER: 44333
MESSAGE TITLE: 2011-2014 All-Wheel Drive Vehicles Equipped With PTU Cooling
APPLICABLE VEHICLES:
2013 - 2014 TRUCK: 00134 EXPLORER 4DR
2013 - 2014 CAR: 00117 TAURUS
2011 - 2014 TRUCK: UB EXPLORER
2013 - 2014 TRUCK: UB EXPLORER
2013 - 2014 CAR: PH TAURUS
2011 - 2014 TRUCK: 00134 EXPLORER 4DR
OASIS MESSAGE:
Some 2011-2014 Explorer that are Export, and 2013-2014 Police Sedan and Utility, Taurus SHO, and Explorer Sport vehicles equipped with AWD and a liquid cooled Power Take-Off Unit (PTU) may experience sludging or contamination of the PTU lube as a result of increased internal lube temperature caused by excessive lube loss from the PTU, or internal PTU failure. Please refer to Workshop Manual (WSM)section 308-07B for PTU diagnosis. If diagnostics lead to replacement of the PTU due to deteriorated lube (sludged or metal contaminants), please also replace the PTU vent hose using base part number 7034 during this repair.
APPLICABLE SYMPTOM CODES:
4***** Start/Run/Move
442*** MovingRun/Move
4429** 4 x 4 Function
442938 Inoperativeion
446*** Fluidsativeion
4464** Axledsativeion
446487 Visible Leakon
446488 Contaminationn
448*** Noiseminationn
4482** Moving/Driving
448202 Always/Driving
448212 Coldys/Driving
448234 Hotdys/Driving
448239 Intermittentng
500000 DRIVELINEentng
507000 DRIVELINE AUXILARY TRANS/PTO CONCERNS
508000 DRIVELINE TRANSFER CASE CONCERNSCERNS
509000 DRIVELINE AXLE CONCERNS CONCERNSCERNS
510000 DRIVELINE FLUID CONCERNSCONCERNSCERNS
597997 DRIVELINE NOISE CONCERNSCONCERNSCERNS
700000 NOISE AND VIBRATIONCERNSCONCERNSCERNS
702000 NVH OTHER NOISE CONCERNSCONCERNSCERNS
702100 NVH NOISE CONCERN -- FRONTNCERNSCERNS
FIELD SERVICE ACTION NUMBER 15S02: recall (http://philadelphia.cbslocal.com/2015/01/28/ford-recalls-taurus-lincoln-mks-models-to-fix-door-latches/) involves 2010 to 2013 model years of the Ford Taurus and Lincoln MKS. Ford says a door latch spring can become unseated, allowing the door to unlatch in a side-impact crash. The company says it knows of no injuries from the problem. Dealers will inspect the latches and replace door handles if needed.
15V040000 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg84424.html#msg84424): Interior door handle return spring Recall
I have a couple of these that need done... I bought my SHO about 5 months ago and still have the CPO warranty, does anyone know if I take it in if I will have to pay for the TSB's? Such as the transmission or third brake light one?
Thanks,
Nick
Quote from: nickstewartroc on January 30, 2015, 06:45:35 PM
Thanks,
Nick
If you are talking about the transmission tsb that fixes the slipping out of gear and slamming back in, good luck getting them to fix it in the first place..... Mine has the problem. I gave my 10 SHO to them for a full week while I was in Jamaica and they decided not to fix it unless they can replicate the problem. Well it does it about twice a month, so fat chance it will ever happen in front of a mechanic.
Thanks,
Nick
No you don't...
x2, you have three years to get those TSB's rectified,so essentially dont hold out,make an appt and mention the TSB thats pertaining to your vehicle and see if its affected,post any updates that you may have.
TSB 14-0175 Ambient Lighting Fix contents:
TSB 14-0175
FORD: 2011-2014 Edge, Explorer
2013-2014 F-150, Flex, Fusion, Taurus
LINCOLN: 2011-2014 MKX
2013-2014 MKS, MKT, MKZ
ISSUE:
Some 2011-2014 Edge, Explorer, MKX, 2013-2014 Fusion, Taurus, Explorer, Flex, F-150, MKZ, MKT and MKS vehicles equipped with MyFord Touch™/MyLincoln Touch™ and ambient lighting may exhibit the ambient lighting defaulting to white on Lincoln vehicles or ice-blue on Ford vehicles after cycling the ignition switch.
TSB 14-0175 MYFORD TOUCH/MYLINCOLN TOUCH - AMBIENT LIGHTING DEFAULTS TO WHITE OR ICE-BLUE AFTER CYCLING IGNITION SWITCH
Publication Date: September 19, 2014
ISSUE:
ACTION:
SERVICE PROCEDURE
1.Determine the level of software in the accessory protocol interface module (APIM) by navigating to the system information screen on the 8 inch radio display. Select:
a.Menu
b.Help
c.System Information
1.If the last five numeric digits (e.g. 4.30.13171.PRODUCT) are 13171, proceed to Step 2.
2.If the last five numeric digits are not 13171, this article does not apply. Refer to the Workshop Manual (WSM), Section 417-02 for normal diagnosis.
2.Perform SYNC module (APIM) custom programming. Refer to WSM , Section 415-00.
a.When the scan tool displays the list of available software, make sure the software version DA5T-14D544-BD (V3.6) has a green check mark. Also select the ambient light settings restore EA5T-14D546-AMA.
1.If the system auto-selects several other applications, proceed with the applications auto-selected.
b.Select continue and follow the on screen prompts.
c.As the programming is being performed, several reboots may occur.
d.Once the programming is completed, return the thumb drive to the scan tool to report software installation to the Ford online database.
140175A Perform Reprogramming Of The APIM Using The USB Flash Drive (Do Not Use With Any Other Labor Operations) 0.3 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
DEALER CODING
14D212 04
TSB 15-0086 (supersedes TSB 14-0196):
3.5L GTDI – EXCESSIVE OIL CONSUMPTION AND/OR SMOKE FROM THE EXHAUST AT IDLE DURING NORMAL ENGINE OPERATING TEMPERATURE – ALUMINUM VALVE COVER
Publication Date: May 27, 2015
FORD: 2010-2014 Flex, Taurus; 2013-2014 Explorer
LINCOLN: 2010-2014 MKS, MKT
The article supersedes TSB 14-0196 to update the Part List.
ISSUE:
Some 2010-2014 Flex, MKS, MKT, Taurus and 2013-2014 Explorer vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine with an aluminum valve cover may exhibit excessive oil consumption and/or an excessive engine oil smoking condition from the tailpipe at idle during normal engine operating temperatures.
ACTION:
SERVICE PROCEDURE
1.Remove the positive crankcase ventilation (PCV) valve. Refer to Workshop Manual (WSM), Section 303-08.
2.Inspect for oil in the crankcase vent oil separator through the PCV valve opening. Is there presence of liquid oil, more than a slight vapor?
a.No – this article does not apply refer to WSM, Section 303-00 for excessive engine oil consumption.
b.Yes – proceed to Step 3.
3.Replace the right hand valve cover, refer to WSM, Section 303-01.
4.Replace the crankcase vent oil separator, refer to WSM, Section 303-08.
5.Drive the vehicle at normal operating temperature for 20 minutes at constant highway speed to remove oil residue from the catalytic converter.
AA5Z-6582-E Valve Cover
AA5Z-6A666-D PCV Valve
AA5Z-6A785-F Crankcase Vent Oil Separator
TA-357 Motorcraft® High Performance Engine RTV Silicone
XO-5W30-QSP Motorcraft® SAE 5W-30 Premium Synthetic Blend Motor Oil
PM-4-A Motorcraft® Metal Brake Parts Cleaner
ZC-31-B Motorcraft® Metal Surface Prep Wipes
ZC-30-A Motorcraft® Silicone Gasket Remover
150086A 2013-2014 Explorer 2010-2014 0.3 Hr.
Taurus, MKS, Flex And MKT 3.5L
GTDI: Inspect For Oil In The
Crankcase Vent Oil Separator.
None Found Includes Time To
Replace PCV Valve (Do Not Use
150086B 2013-2014 Explorer 3.5L GTDI: 2.1 Hrs.
Inspect For Oil In The Crankcase
Vent Oil Separator. Replace Right
Hand Valve Cover, Crankcase Vent
Oil Separator, PCV Valve Includes
Time For Road Test (Do Not Use
150086B 2010-2014 Flex, MKT, Taurus And 2.2 Hrs.
MKS 3.5L GTDI: Inspect For Oil In
The Crankcase Vent Oil Separator.
Replace Right Hand Valve Cover,
Crankcase Vent Oil Separator, PCV
Valve Includes Time For Road Test
Operations)
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage.
DEALER CODING
6A785 42
TSB 14-0019
LACK OF AIR CONDITIONING AND/OR ENGINE OVERHEAT CONDITION – BUILT ON OR AFTER 9/1/2010
Publication Date: January 29, 2014
FORD: 2011-2012 Taurus; 2011-2012 Explorer, Flex
LINCOLN: 2011-2012 MKS; 2011-2012 MKT
This article supersedes TSB 13-12-21 to update the vehicle application.
ISSUE:
Some 2011 and 2012 Explorer, Taurus, Flex, MKS and MKT vehicles built on or after 9/1/2010 and equipped with dual engine cooling fans may exhibit a lack of air conditioning (AC) performance while the vehicle is stationary or moving at slow speeds, and/or an overheat condition. Diagnostic trouble codes (DTCs) P0217, P1299 and P1285 may be present.
ACTION:
SERVICE PROCEDURE
1.Using the Integrated Diagnostic System (IDS) with a release of 87.05 and higher, check the powertrain control module (PCM) for a later calibration. Is a later calibration available for the PCM?
a.No – proceed to Step 2.
b.Yes – reprogram the PCM to the latest calibration using IDS release 87.05 and higher. Calibration files may also be obtained at www.motorcraftservice.com (http://www.motorcraftservice.com). Proceed to Step 2.
2.Using IDS, select Data Logger, select Output State Control, command the Cooling Fan Speed Desired PID to High speed (FAN_CTRL# or FAN_DSD# – above 90%) for 1 minute and verify cooling fan operation. Are the cooling fans operating?
a.No – please be sure to check the fan assembly for being original equipment manufacturer (OEM). (Figure 1)
Figure 1 – 14-0019
i.For Taurus and MKS vehicles, replace the cooling fan motor and control module assembly. Refer to Workshop Manual (WSM), Section 303-03 and then proceed to Step 5.
ii.For Explorer, Flex and MKT vehicles, proceed to Step 3.
b.Yes – this article does not apply. Refer to WSM, Section 303-03 for normal diagnostics.
3.Remove the cooling fan motor and control module assembly. Refer to WSM, Section 303-03.
4.Remove the cooling fan control module from the original cooling fan motor assembly and transfer onto the new cooling fan motor assembly. Tighten screw to 7 Nm (60 lb-in).
5.Install the new cooling fan motor assembly. Refer to WSM, Section 303-03.
6.Check coolant level and top off as necessary using the correct coolant type. Refer to WSM, Section 303-03.
BA8Z-8C607-D Cooling Fan (Explorer, Flex and MKT)
BA5Z- 8C607-C Cooling Fan and Module (Taurus and MKS)
VC-10-A2 Motorcraft® Specialty Green Engine Coolant (Concentrated)
VC-3-B Motorcraft® Orange Antifreeze/Coolant Concentrated
140019A 2011-2012 Explorer, MKT, Flex: Inspect Cooling Fan Operation, Replace Cooling Fan, Transfer Electronic Module, And Reprogram The PCM If Necessary (Do Not Use With Any Other Labor Operations) 0.8 Hr.
140019A 2011-2012 Taurus, MKS, Flex, MKT 3.5L GTDI: Inspect Cooling Fan Operation, Replace Cooling Fan, Transfer Electronic Module, And Reprogram The PCM If Necessary (Do Not Use With Any Other Labor Operations) 1.4 Hrs.
WARRANTY STATUS
DEALER CODING
8C607 42
TSB 14-0023 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79196.html#msg79196) HEADLINER DROPPING DOWN AND/OR LOOSE AT REAR WINDOW GLASS
TSB 14-0057 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79004.html#msg79004) ALL WHEEL DRIVE – FLUID LEAK FROM REAR DIFFERENTIAL VENT CAP – TEMPERATURES BELOW 0 DEGREES C (32 DEGREES F)
TSB 14-0130 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79044.html#msg79044) EXHAUST ODOR IN VEHICLE
TSB 14-0132 (http://www.revbase.com/BBBMOTOR/TSb/DownloadPdf?id=186074) EASY FUEL CAPLESS-CONCERNS WITH FUEL NOZZLE INSERTION OR REMOVAL
TSB 14-0186 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79065.html#msg79065) Ting, Pop or Click Noise From the Front Wheel Area When Accelerating From a Stop, on Turns or When Shifting Between Drive/Reverse and/or Reverse/Drive
TSB 14-0198 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79098.html#msg79098) EXHAUST – SULFUR ODOR AFTER HARD ACCELERATION
TSB 14-0223 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79169.html#msg79169) 2.0L GTDI – LACK OF POWER – DTC P2111, P2101 AND/OR P2112 – AMBIENT TEMPERATURES BELOW 0 DEGREES CELSIUS (32 DEGREES FAHRENHEIT) BUILT ON OR BEFORE 10/5/2014
TSB 14-0231 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79171.html#msg79171) MYFORD TOUCH – concerns with navigation, voice recognition, call sound quality, phone pairing, clock, media, WiFi pass code entry, rear view camera guidelines, no Russian language package and/or poor system performance
TSB 15-0003 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79174.html#msg79174) 3.5L GTDI – FUEL ODOR FROM ENGINE OIL AND/OR ENGINE OIL LEVEL OVERFULL
TSB 15-0047 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79170.html#msg79170) SHIFT TO PARK OR TRANSMISSION NOT IN PARK MESSAGE – DISCHARGED BATTERY DUE TO SHIFT TO PARK LIGHT ON / UNABLE TO REMOVE IKT
TSB 15-0086 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79067.html#msg79067) 3.5L GTDI – EXCESSIVE OIL CONSUMPTION AND/OR SMOKE FROM THE EXHAUST AT IDLE DURING NORMAL ENGINE OPERATING TEMPERATURE – ALUMINUM VALVE COVER
15S18/15V340/15V340000 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg84212.html#msg84212): Loss of Electric Power Steering Assist
TSB 15-0105
3.5L GTDI – INOPERATIVE, EXCESSIVELY NOISY VACUUM PUMP, HARD BRAKE PEDAL ON INITIAL START-UP AND/OR OPEN FUSE F64 IN THE BATTERY JUNCTION BOX
Publication Date: June 22, 2015
FORD: 2011-2012 F-150
ISSUE:
Some 2011-2012 F-150 vehicles equipped with a 3.5L gasoline turbocharged direct injection (GTDI) engine may exhibit a hard brake pedal on initial start-up, an electric vacuum pump that is inoperative or excessively noisy and/or fuse F64 is open in the battery junction box (BJB).
ACTION:
SERVICE PROCEDURE
1.Does the vacuum pump operate?
a.Yes – proceed to Step 2.
b.No – proceed to Step 3.
2.Is the vacuum pump excessively noisy?
a.Yes – proceed to Step 7.
b.No – this procedure does not apply, refer to Workshop Manual (WSM), Section 206-00 for normal diagnosis.
3.Inspect fuse F64 in the BJB. Is the fuse open?
a.Yes – replace the fuse and proceed to Step 4.
b.No – proceed to Step 4.
4.Check for battery voltage at the vacuum pump connector C1560 pin 1 with the ignition key in the run position. Is battery voltage present?
a.Yes – proceed to Step 5.
b.No – this procedure does not apply. Repair the voltage supply circuit. Refer to the Wiring Diagram, Cell 42-1.
5.Disconnect the vacuum pump connector C1560. Check the resistance to ground at the harness connector pin 2 with the ignition key off. Is the resistance less than 5 ohms?
a.Yes – proceed to Step 6.
b.No – this procedure does not apply. Repair the ground circuit. Refer to the Wiring Diagram, Cell 5-1.
6.Inspect pins 1 and 2 in C1560. Are both pins clean and tight?
b.No – this procedure does not apply. Repair the wiring harness. Refer to the Wiring Diagram Cell 5-1.
7.Replace the vacuum pump and install the harness kit. Refer to WSM, Section 206-07 and the instructions provided in the harness kit.
CL3Z-9C490-D Vacuum Pump Harness Kit
BL3Z-2A451-A Vacuum Pump
150105A 2011-2012 F-150 3.5L EcoBoost: Diagnose And Replace The Brake Vacuum Pump Includes Time To Install Harness Kit (Do Not Use With Any Other Labor Operations) 1.0 Hr.
WARRANTY STATUS
DEALER CODING
9C490 42
manu:
thanks again for update. that slip tranny issue that larry still has & will not be fixed by the tsb & in my case made it worst which was a mixed blessing as force them to change the 2 sensors.
Turbine Shaft Speed (TSS) Sensor
This Turbine Shaft Speed (TSS) sensor is a Hall-effect pickup that sends a signal to the PCM that indicates transaxle turbine shaft input speed. The TSS sensor provides converter turbine speed information for TCC strategy. Also used in determining static LPC pressure settings.
Output Shaft Speed (OSS) Sensor
The Output Shaft Speed (OSS) sensor is a Hall-effect pickup, located on the transfer shaft drive gear, that sends a signal to the PCM to indicate transmission output speed. The OSS is used for TCC control and shift scheduling
good luck trying to get them to fix it until you can make it happen with tech in car w/ tech laptop hooked to obd port.
but no trouble since they put new sensors in is the good thing
Glad to hear it, Mike! Too bad these gremlins are so hard to pin down, but electronics are often like that ...
Hard shifts? Might need TSS/OSS/TR sensors. Part numbers here:
http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79533.html#msg79533 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79533.html#msg79533)
I think this site is maintaining an active and current list of all TSB and recall notices. The latest power steering recall for my 2011 which was announced couple months ago on list.
If you change year in address bar you can search any year Taurus and further change allows search for other vehicles as well.
http://www.fordproblems.com/tsbs/Taurus/2011/ (http://www.fordproblems.com/tsbs/Taurus/2011/)
Not an official 3.5EB transverse-related TSB, but since so much interest has been shown ...
TSB 15-0044 3.5L GTDI – DTC P0016 – PRIMARY TIMING CHAIN WEAR – BUILT ON OR BEFORE 10/10/2014
Malfunction Indicator Lamp (MIL) Illuminated with Diagnostic Trouble Code (DTC) P0016 – 2011-2014 Ford F-150
Publication Date: March 30, 2015
FORD: 2011-2014 F-150
This article supersedes TSB 14-0194 (http://www.revbase.com/BBBMotor/TSb/DownloadPdf?id=187147) to update the Parts List.
ISSUE:
Some 2011-2014 F-150 vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 10/10/2014 may exhibit a malfunction indicator lamp (MIL) illuminated with diagnostic trouble code (DTC) P0016. Other DTCs and driveability concerns may also be present. This concern may be due to a worn primary timing chain.
ACTION:
SERVICE PROCEDURE
1.Is the vehicle build date on or before 10/10/2014?
b.No – this procedure does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnosis.
2.Using Integrated Diagnostic System (IDS), with key on and engine running (KOER), select the VCT_INT_ACT1 Parameter Identification Data (PID) in the Datalogger.
a.If VCT_INT_ACT1 PID reads +6 degrees or greater, proceed to Step 3.
b.If VCT_INT_ACT1 PID reads +5 degrees or less – this procedure does not apply. Refer to Powertrain Control/Emissions Diagnosis (PC/ED) manual for normal diagnostics.
3.Replace the primary timing chain. Refer to Workshop Manual (WSM), Section 303-01.
AT4Z-6268-C Primary Timing Chain
AA5Z-9439-A Intake Gasket
BL3Z-6584-A Cam Cover Gasket – Left Hand
BR3Z-6584-B Cam Cover Gasket – Right Hand (2011–2012)
DL3Z-6584-B Cam Cover Gasket – Right Hand (2013–2014)
BL3Z-9E583-B High Pressure Pump O-ring
BR3Z-8507-C Pump Gasket
BR3Z-8527-A Pump O-ring
7T4Z-8590-A Coolant Inlet Seal
XW4Z-6700-AA Crank Seal
BR3Z-6020-A Front Cover Radial Seal
F5RZ-6A340-B Damper Bolt
TA-25-B Motorcraft® Threadlock and Sealer
TA-24-B Motorcraft® Thread Sealant with PTFE
150044A 2011-2014 F-150 3.5L GTDI: Diagnose And Replace The Primary Timing Chain (Do Not Use With Any Other Labor Operations) 8.9 Hrs.
WARRANTY STATUS
DEALER CODING
6268 33
Service Bulletin No.: 14R01
Component(s): EQUIPMENT NHTSA ID Number: 10057898
Potential Number of Units Affected: 183,425
Vehicles: FORD POLICE INTERCEPTOR SEDAN 2013-2014; FORD TAURUS 2010-2014
SUMMARY:
Ford Motor Company (Ford) is recalling certain model year 2010-2014 Taurus vehicles manufactured November 24, 2008, through February 28, 2014, originally sold in, or currently registered in, Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, Wisconsin and the District of Columbia. When used in areas that use road salt, the license plate lamp assembly may experience an electro-chemical reaction and corrosion as a result of water intrusion.
CONSEQUENCE:
This corrosion may result in a short circuit, increasing the risk of a fire.
REMEDY:
Ford will notify owners, and dealers will replace the license plate lamp assemblies, free of charge. The recall began on July 26, 2014. Owners may contact Ford customer service at 1-800-392-3673. Ford's number for this recall is 14S08. Note: Under program 14R01, Ford will notify owners in non-corrosion states, and, at the customer's request, dealers will replace the license plate lamp assembly.
NOTES:
Owners may also contact the National Highway Traffic Safety Administration Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to www.safercar.gov (http://www.safercar.gov).
TSB 15-0131 (2011-2015 F150)
ISSUE
Some 2011-2015 F-150 vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 5/29/2015 may exhibit a clicking/tapping or rattle type noise from the top front cover area of the engine upon initial start-up that may last for 2-5 seconds after a cold soak of six or more hours.
Full:
http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg98709.html#msg98709 (http://www.ecoboostperformanceforum.com/index.php/topic,3836.msg98709.html#msg98709)
Do these TSBs have to be performed while under original warranty? I have noticed that a couple of these apply to me. I purchased an Extended Warranty from my bank. Looks like I have the 12-2-8 (intermediate drifting/pulling) and 10-15-2 (rear 3rd brake light dropped out of nowhere while running errands yesterday). And to my understanding, these are supposed to be replace free of charge?
Whether you have Ford or non-Ford warranty you have to check what your warranty covers. TSB is independent of warranty coverage, it is simply a service bulletin advising techs what to do in the event of that particular issue occurring. Sometimes Ford does extend warranty on parts/repairs in a Customer Satisfaction Program, like brake booster, APIM, etc. But this is rare.
Ahhhh I see. So the TSB is more of a how to/guide on some symptoms and fixes. I was more under the impression that it was kind of like a recall.
Then it would have said "Recall" :) But yes, a TSB is a how to/guide.
TSB 14-0105 3.5L GTDI DIAGNOSTIC TROUBLE CODE (DTC) P0087 – BUILT ON OR BEFORE 6/1/2014
FORD: 2012-2014 Flex, Taurus; 2013-2014 Explorer
LINCOLN: 2012-2014 MKT
ISSUE:
Some 2013-2014 Explorer, 2012–2014 Taurus, MKT and Flex vehicles equipped with a 3.5L Gasoline Turbocharged Direct Injection (GTDI) engine and built on or before 6/1/2014 may exhibit a rough idle and/or DTC P0087 after a hot engine restart.
ACTION:
Reprogram the powertrain control module (PCM) to the latest calibration using IDS or Ford J2534 release 90.03 and higher. Calibration files may also be obtained at www.motorcraft.com (http://www.motorcraft.com).
NOTE: ADVISE THE CUSTOMER THAT THIS VEHICLE IS EQUIPPED WITH AN ADAPTIVE TRANSMISSION SHIFT STRATEGY WHICH ALLOWS THE VEHICLE'S COMPUTER TO LEARN THE TRANSMISSION'S UNIQUE PARAMETERS AND IMPROVE SHIFT QUALITY. WHEN THE ADAPTIVE STRATEGY IS RESET, THE COMPUTER WILL BEGIN A RE-LEARNING PROCESS. THIS RE-LEARNING PROCESS MAY RESULT IN FIRMER THAN NORMAL UPSHIFTS AND DOWNSHIFTS FOR SEVERAL DAYS.
140105A 2013-2014 Explorer, 2012-2014 Taurus, MKT, Flex 3.5L GTDI: Retrieve DTCs, Reprogram The PCM Includes Time To Clear Codes (Do Not Use With Any Other Labor Operations) 0.3 Hr.
WARRANTY STATUS
DEALER CODING
RECALEM 04
2007-2016 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police – AWD – Ticking/Knocking Noise From Driveline – Built On Or Before 30-Jun-2016
Some 2007-2016 Edge/MKX/Flex/MKT/MKZ/MKS/Taurus/Taurus Police/Explorer/Explorer Police equipped with All Wheel Drive (AWD) and built on or before 30-Jun-2016 may exhibit a ticking and/or knocking noise coming from the driveline area.
To identify this noise, refer to Workshop Manual (WSM), Section 100-04, and follow the symptom chart.
If the source of the noise is identified as the PTU and/or internal to the PTU, disassemble PTU assembly.
Refer to updated WSM, Section 308-07. If the PTU is determined to be repairable, utilize kit GB5Z-7P258-A and the included instruction sheet.
TSB 10-2-6 AFTERMARKET POWERTRAIN CONTROL MODULE CALIBRATION, NON-FACTORY MODIFICATION OR AFTERMARKET COMPONENTS
FORD:
2010 Taurus, Flex
LINCOLN:
2010 MKS, MKT
ISSUE
Some 2010 Taurus, Flex, MKS and MKT vehicles equipped with an EcoBoost engine may have unauthorized aftermarket modifications to the powertrain hardware and/or calibration which may result in exceeding component design limits. Such modifications could cause damage to the powertrain and/or void the factory powertrain warranty.
ACTION
Review Service Procedure
SERVICE PROCEDURE
Unauthorized calibration modifications may or may not be detectable using standard tools (Integrated Diagnostic System (IDS), Portable Diagnostic Software (PDS), NGS+ VCM). Changes can be made to the calibration and flashed to the PCM through the OBD port. Physical modifications to the hardware may or may not be present. If aftermarket power/torque-increasing modifications are suspected, care should be taken to record and store the following items: Permanent Diagnostic Trouble Codes (DTCs), Pending DTCs, Freeze Frame Data, Mode 6 and Mode 9 data. The data should be printed and attached to the repair order for later reference.
The DTCs, freeze frame data, Mode 6 and 9 data can be obtained by using the IDS, PDS or NGS+VCM under tool box selection. The Powertrain tab will provide the OBD Test Modes tab and Mode 6 and 9 data selection after the vehicle has been identified.
Attempting to increase the engine output via recalibrating the PCM may result in poor drivability, DTCs, or component failures. A partial list of calibration induced component failures is given below:
^ Piston damage.
^ Spark over-advanced (knock-induced damage).
^ Insufficient enrichment.
Excessive Cylinder Pressure:
^ Turbocharger damage.
Over-Speed:
^ Catalyst damage.
Over-Temperature/Melting:
^ Transmission, PTU, Torque converter damage.
Hardware Modifications:
The following list contains items that are frequently modified in an effort to increase the engines torque/power output. Modifying these items may, or may not improve the performance, but can lead to drivability issues, DTCs and possibly component failures:
^ Air induction system (air box, low pressure and high pressure air ducts).
The system may be particularly susceptible to flexible air ducts between the air filter and the compressors. Restrictions on either side of the compressor can result in over-speeding the turbo (Figures 5-6).
^ Wastegate actuator pre-tension.
The full load output of some turbocharged engines will increase if the wastegate spring pre-tension is increased. This is not the case with the EcoBoost engine. Adjusting the wastegate pre-tension out of the specified range can result in DTCs. A tamper evident paint dot has been applied to the wastegate actuator adjustment mechanism to make modifications more apparent.
^ Throttle inlet and intake manifold pressure sensors.
These sensors and the associated wiring should be inspected to verify they have not been modified.
^ Additional fuel injection devices.
The high pressure fuel system used for the EcoBoost engine will not support additional fuel flow beyond what the factory calibration requests. Inspect the engine for an additional aftermarket injector(s) located somewhere in the induction system to provided increased fuel flow.
^ PCV system modifications.
If the PCV system is modified (vented to atmosphere being the most common modification) it can result in a condition where oil gets past the turbine seal even on an undamaged, fully functional turbocharger. Oil in the exhaust system may not be sufficient evidence to identify a failed turbo if the PCV system has been compromised.
^ Compressor bypass modifications (a.k.a. blow-off valve, or anti-surge valve).
It is common to modify these components so they make more noise. If the aftermarket devices fail to seal properly when closed, elevated turbo speeds and compressor outlet temperatures will occur.
^ Exhaust air path/system.
Removal of catalysts or mufflers/resonators to reduce exhaust backpressure may result in over-speeding the turbo(s).
February 27, 2017 MANUFACTURER COMMUNICATION NUMBER: SSM 46412 - PTU
Components: POWER TRAIN, EQUIPMENT
NHTSA ID Number: 10095858
Manufacturer Communication Number: SSM 46412
Summary
SOME 2007-2016 EDGE/MKX/FLEX/MKT/MKZ/MKS/TAURUS/TAURUS POLICE/EXPLORER/EXPLORER POLICE EQUIPPED WITH ALL WHEEL DRIVE (AWD) AND BUILT ON OR BEFORE 30-JUN-2016 MAY EXHIBIT A TICKING AND/OR KNOCKING NOISE COMING FROM THE DRIVELINE AREA. TO IDENTIFY THIS NOISE, REFER TO WORKSHOP MANUAL (WSM), SECTION 100-04, AND FOLLOW THE SYMPTOM CHART. IF THE SOURCE OF THE NOISE IS IDENTIFIED AS THE PTU AND/OR INTERNAL TO THE PTU, DISASSEMBLE PTU ASSEMBLY. REFER TO UPDATED WSM, SECTION 308-07. IF THE PTU IS DETERMINED TO BE REPAIRABLE, UTILIZE KIT GB5Z-7P258-A (PTU Idler Gear Repair Kit, about $315) AND THE INCLUDED INSTRUCTION SHEET. FOR CLAIMING, USE CAUSAL PART 7P258 AND APPLICABLE LABOR OPERATIONS IN SECTION 07 OF THE SERVICE LABOR TIME STANDARDS (SLTS) MANUAL.
77 Associated Products
Vehicles
MAKE MODEL YEAR
FORD EDGE 2007-2016
FORD EXPLORER 2007-2016
FORD FLEX 2009-2016
FORD TAURUS 2007-2016
FORD TAURUS POLICE INTERCEPTOR 2013-2015
LINCOLN MKS 2009-2016
LINCOLN MKT 2009-2016
LINCOLN MKX 2007-2016
LINCOLN MKZ 2007-2016
SSM 44856 - Various 2011-2015 Vehicles - Cruise Control Speed Setting Display May Not MatchSpeedometer
Some 2013-2015 Fusion, Taurus, 2011-2015 Explorer, 2013-2014 Edge, Flex, 2013-2015 Lincoln MKS, MKX and 2013-2014 Lincoln MKT, vehicles may exhibit a cruise control speed that does not match the speedometer speed. The Instrument Panel Cluster (IPC) provides a tolerance which allows the speedometer gauge to display between 3% lower and 7% higher than the actual vehicle speed. This means that with an actual vehicle speed of 96 kmh (60 mph), the speedometer may indicate between93 kmh (58 mph) and 103 kmh (64 mph), which is normal. Refer to Workshop Manual(WSM), Section 413-01 Description and Operation, Instrument Panel Cluster (IPC). If you are outside of this tolerance range, refer to the WSM for normal diagnosis.
-MANU Great INFO as always. Z :thumb: :thumb:
SSM 47119 – 2011-2018 Explorer/Police Interceptor Utility/Police Interceptor Sedan Taurus/Flex/MKT and 2011-2016 MKS – 3.5L EcoBoost – Engine Assembly Replacement
During 3.5L EcoBoost engine assembly replacement, inspect the color of the positive crank ventilation (PCV) camshaft cover adaptor located next to the high pressure fuel pump on the original engine and compare to the service replacement engine.
The adaptor color of the service replacement engine must match the original engine.
If the adaptor on the original engine is green, install a green adaptor (HL2E-6762-AA) on the service replacement engine.
If the adapter is removed from the camshaft cover, damage will occur to the adapter locking mechanism.
Make sure detached pieces of the locking mechanism do not fall into the open port during removal.
APPLICABLE VEHICLES
2013 – 2018 EXPLORER
2011 – 2018 FLEX
2011 – 2016 LINCOLN MKS
2011 – 2018 MKT
2011 – 2018 TAURUS
Quote from: SHOdded on June 14, 2017, 10:13:12 AM
I always wondered about that. Thanks for the info.
https://www.ecoboostperformanceforum.com/index.php/topic,3836.msg151658.html#msg151658 (https://www.ecoboostperformanceforum.com/index.php/topic,3836.msg151658.html#msg151658)
TSB 17-2219 Latest TSB for SHIFT TO PARK messages
TSB 10-22-4 AWD VEHICLES - SHUDDER-CHATTER-VIBRATION ON TURNS OR THUMP-CLUNK NOISE ON LIGHT ACCELERATION - BUILT 10-1-2009 TO 12-31-2009
Replace the PTU
Replace the PTU
I know this is an older thread, but all the effort to put it together helped me to help my local Ford dealer complete a diagnosis and get the proper work done. Thanks to those of you that worked on this list. Dennis
attached pdf for 10-22-4
