Started by scap99, May 12, 2014, 11:47:01 AM
Quote from: Raiderfan1890 on May 15, 2014, 08:35:28 AMHey, if I lived within 4 hours I would have Erick install that too lolIt's the Thuggish Ruggish BoneFired from the other forum... thrice
Quote from: FoMoCoSHO on May 14, 2014, 11:45:31 PMQuote from: scap99 on May 14, 2014, 10:09:19 PMQuote from: SwampRat on May 14, 2014, 10:04:30 PMQuote from: scap99 on May 14, 2014, 08:46:38 PMNot yet, Erick is trying to talk me into a dyno tune.Hey scapp , I noticed in your sig that you are doing an E30 blend.Does MPT support blending with there tunes or are you monitoring FRP , KR and stuff on your own .I was doing an E85 blend with Torrie at Unleashed in my 13 SHO .FoMoCoSHO is big on blending here as well .Yes.But I run torque pro app, too.Mike B. corrupted me...scap, if you're running the OBDMX adapter, you should try out the OBDLink software. It polls the ECM much faster than Torque.
Quote from: scap99 on May 13, 2014, 09:57:16 PMQuote from: 4DRHTRD on May 13, 2014, 09:42:41 PMOrdered Monday, installed Tuesday, damn you're fast!Mine's been in the garage for 2 months....AND....I had to drive to my old house to pick it up from some strange guy....lolI still don't know how PayPal did that when I had just cleared out all the alternate addresses from my profile before placing the order.
Quote from: scap99 on May 15, 2014, 02:29:58 PMQuote from: FoMoCoSHO on May 14, 2014, 11:45:31 PMQuote from: scap99 on May 14, 2014, 10:09:19 PMQuote from: SwampRat on May 14, 2014, 10:04:30 PMQuote from: scap99 on May 14, 2014, 08:46:38 PMNot yet, Erick is trying to talk me into a dyno tune.Hey scapp , I noticed in your sig that you are doing an E30 blend.Does MPT support blending with there tunes or are you monitoring FRP , KR and stuff on your own .I was doing an E85 blend with Torrie at Unleashed in my 13 SHO .FoMoCoSHO is big on blending here as well .Yes.But I run torque pro app, too.Mike B. corrupted me...scap, if you're running the OBDMX adapter, you should try out the OBDLink software. It polls the ECM much faster than Torque.I didn't notice any more speed, but I did notice many pids were missing...
Quote from: FoMoCoSHO on May 17, 2014, 06:23:28 PMQuote from: scap99 on May 15, 2014, 02:29:58 PMQuote from: FoMoCoSHO on May 14, 2014, 11:45:31 PMQuote from: scap99 on May 14, 2014, 10:09:19 PMQuote from: SwampRat on May 14, 2014, 10:04:30 PMQuote from: scap99 on May 14, 2014, 08:46:38 PMNot yet, Erick is trying to talk me into a dyno tune.Hey scapp , I noticed in your sig that you are doing an E30 blend.Does MPT support blending with there tunes or are you monitoring FRP , KR and stuff on your own .I was doing an E85 blend with Torrie at Unleashed in my 13 SHO .FoMoCoSHO is big on blending here as well .Yes.But I run torque pro app, too.Mike B. corrupted me...scap, if you're running the OBDMX adapter, you should try out the OBDLink software. It polls the ECM much faster than Torque.I didn't notice any more speed, but I did notice many pids were missing...Agreed on the lack of PIDS. I need to reach out to those guys about that. I am curious about no difference in speed however. On my setup and on Mike's embedded vids the difference in speed is shocking, especially with trims, timing, and lambda.Thanks for the input, looks like I have some investigating to do.
Quote from: scap99 on May 17, 2014, 06:29:16 PMQuote from: FoMoCoSHO on May 17, 2014, 06:23:28 PMQuote from: scap99 on May 15, 2014, 02:29:58 PMQuote from: FoMoCoSHO on May 14, 2014, 11:45:31 PMQuote from: scap99 on May 14, 2014, 10:09:19 PMQuote from: SwampRat on May 14, 2014, 10:04:30 PMQuote from: scap99 on May 14, 2014, 08:46:38 PMNot yet, Erick is trying to talk me into a dyno tune.Hey scapp , I noticed in your sig that you are doing an E30 blend.Does MPT support blending with there tunes or are you monitoring FRP , KR and stuff on your own .I was doing an E85 blend with Torrie at Unleashed in my 13 SHO .FoMoCoSHO is big on blending here as well .Yes.But I run torque pro app, too.Mike B. corrupted me...scap, if you're running the OBDMX adapter, you should try out the OBDLink software. It polls the ECM much faster than Torque.I didn't notice any more speed, but I did notice many pids were missing...Agreed on the lack of PIDS. I need to reach out to those guys about that. I am curious about no difference in speed however. On my setup and on Mike's embedded vids the difference in speed is shocking, especially with trims, timing, and lambda.Thanks for the input, looks like I have some investigating to do.I have the obd link mx and a galaxy s4.What device were you using?
Quote from: scap99 on May 17, 2014, 06:58:23 PMInteresting...Now y'all got me nervous.
Quote from: FoMoCoSHO on May 17, 2014, 10:23:41 PMQuote from: scap99 on May 17, 2014, 06:58:23 PMInteresting...Now y'all got me nervous.I'm not sure you need to be nervous, the data between the two is similar.What is different, at least with my setups, is that for any two consecutive data points in torque, there may be 10 more in between using OBDLink...if that makes any sense.
