bamsho
Quote from: bamsho on May 16, 2020, 05:59:08 PMBlah Blah Blah
Hahaha. I believe a song was made after that phrase. Yup. Sure was. Here you go buddy. Just for you.....
https://youtu.be/3taEuL4EHAg
StealBlueSho
Chris_Flex
Replaced my AC condenser today was really surprised to see it also has a trans cooler with it on my flex are the SHO like that also?
2013 Ford Flex Ecoboost
BC Coilovers
Trans mounts
Unleashed e30 Tune
SuperPete
correct, SHO also has trans cooler inside of the condenser, just like yours.
2014 SHO, GearHead TUNNED /Powered by Matt Robinson
PPE Downpipes, GearHead Intercooler, AirAid Intake
XDI-35 HPFP @ E40,   MSD Coilpacks
MUSTANG DYNO: 426/446
Continental Extreme Contact 06 & Powerstop Z23 all 4 corners
MKS Tom
Air filter for the MKT and new battery for the MKS.  Both cars are filthy.  lol  Started working on my Subaru SVX as well again today too.
MKS Tom
StealBlueSho
Just a quick clean with my favorite detailing product!
bamsho
Well I said bye bye to the noisemaker.  Bought an Explorer Sport pipe, guess the MKS is on national back order.  Had to do some modification, and bought Vibrant silicone tube to go from pipe end to throttle body.  Also relocated the meth nozzle too.
StealBlueSho
Quote from: bamsho on May 29, 2020, 01:31:59 PM
how much did that end up costing you?
MKS Tom
Dropped mine off at the dealer.  Was having shifting issues as soon as I left the driveway.  Was able to get it back in the driveway.  Tried it again in the morning with similar results.  I was able to drive it to the dealer that is about 2 miles away and it seemed better but I didn't push it at all.  I have a warranty and I have been stock since February.  I expect it to be covered.
Good luck.  Hope it is not the dreaded direct clutch issue, just a range sensor :)
MKS Tom
Quote from: SHOdded on June 02, 2020, 10:58:23 AM
With having a warranty I hope it is the trans and the torque converter.  lol
mrhighcaliber
Got my block and crank back from Holbrook Racing engines. I drilled and tapped the outers main holes from a m9 to the m10 to accept the Livernois/ARP hardware for the 2018 blocks. I Also drilled the outer main cap holes and windage tray holes to accommodate bigger stud hardware. Had the mains align line honed, crank journals polished and both hot washed.
Sent from my PH-1 using Tapatalk
