I believe you may have that backwards SkinnyTick.
The attached image, is directly from the Megan Coilover kit I installed way back in 2014.
Yes, I have the 32 way adjustment set of coils (since discontinued by Megan due to lack of sales). I understand that their only current offerings are the 15 way adjustable. So please verify the info you have posted is accurate for the 15 way kit.
Either way, at the top of each coil over, is a dial that illustrates which direction to spin, to gain desired settings.
Harder - One would spin clockwise (to the right) The LOWER the numerical value, the HARDER.
Softer - One would spin counterclockwise (to the left). The HIGHER the numerical value, the SOFTER.
Now with that out of the way.... my own personal settings at the track have typically been with a 1 in the rear, and a 5, or even a 6 up front.
Street use.... usually a 12 in the rear, and an 18 up front.
Ultimately, the settings one choose, is completely left up to the end user, but those are mine.
