Finally found my noise on passenger side it appears to be a broken fuel line bracket under passenger footwell. Anyone have an idea of what it is called or a part number? See picture attached, appears plastic broke from clip.https://www.dropbox.com/s/z0o5kjux0dvhemt/Fuel%20Line%20Bracket.jpg?dl=1 (https://www.dropbox.com/s/z0o5kjux0dvhemt/Fuel%20Line%20Bracket.jpg?dl=1)
(https://i.imgur.com/BmQ1iKph.jpg)
I'm not quite certain its related to the fuel line! Z
Brake line then?
possibly these, but no pics, so no idea
Ford 8A8Z-2K340-A
8A8Z-2K340-A
Bracket
Base Number: 2082
Callout Name: 2082
$12.11$7.79
Ford 9A8Z-2K341-A
9A8Z-2K341-A
Bracket
Callout Name: 2082
Replaced by: DG1Z-2K341-A
The sticker on the one line says fuel. That line goes through the bracket. That's why I'm thinking fuel return or something.
I did not even see a bracket listed under fuel system. I think there is a brake-fuel line combo there, Tho.
I see a fuel tube bundle bracket just before this in the service manual, but they just say remove that and say zero about the bracket in front of it (my problem child). Apparently they are fuel tubes now and not fuel lines. Maybe dealer would be cool and look at it with minimal cost, but who knows.
Quote from: Sbouvia on December 27, 2017, 06:23:38 PM
I also noticed the oil supply lines are now called (Tubes)Dunno !!
I'm hoping you can fabricate or mend that piece together to prevent it from rubbing! Z
https://drive.google.com/file/d/0B8JUL90DXgdiWTA0NE1UUG83Q0ExVVc5U1ZEaXUtbXpJTzBr/view
