SHO 0-120mph Dig
Started by Jordan, May 07, 2019, 02:42:41 PM
jman
Now I'm curious to know what are the cans on the right...
2010 - Unleashed Tune - Corsa Exhaust - 275/40-R20 - H&R Springs
SM105K
Quote from: jman on May 10, 2019, 11:31:13 AM
Brake clean.
Jordan
Yep whole lotta brake clean lol. I use it for my other projects cleaning off grease and oil junk.
Vvvdannyvvv
camera man is a true mvp just saying.
2012 SHO
Plugs, 3 bar, Catless dp, springs
Fastest Run stock 13.9 full weight plus extra
Fastest run on LMS 93 Race tune 12.41 full weight.
Fastest run on Ortiz TBD
Jordan
Quote from: Vvvdannyvvv on May 10, 2019, 11:49:11 AM
I was going to say it was you but then realized it was you commenting
jman
Quote from: Jordan on May 10, 2019, 10:48:05 AM
Do you normally leave your garage unlocked?
In which area did you say you lived?
18SHO
Quote from: Jordan on May 10, 2019, 11:05:05 AM
Quote from: SM105K on May 10, 2019, 10:51:18 AM
Quote from: SHOdded on May 10, 2019, 08:52:59 AM
Am sure you already do this, but fresh fluids - trans, engine oil, ptu/rdu - will likely aid the effort.
Haha trust me.... Maintenance is kept up
I think you are more on top of maintenance then me....lol
I usually do a trans drain and fill after a few rough outings. Oil gets changed not by mileage but when I feel it's had a hard enough time lol... Usually about 2k-3k. PTU has been drain and filled twice since I have owned it (92k, but was flushed at like 108k then 118k) about to go in for a third one. I have a buddy help me with that at the ford dealership. RDU was drain and filled around 118k as well.
The trans do you get all the fluid out and refill or just whatever comes out you replace? I hear only 6 qts or so comes out only
2018 SHO PP factory stock for now
AJPTURBO E30 tune stock plugs .028 gap
5.25.19 12.53 @ 112.96 1.85 60FT 1850 DA 71 F
Best trap 113.61
Jordan
Drain and refill about 5-6 quarts at a time, but I've done it like five times
