Stock turbo efficiency..?
Started by StinkinLinkin13, March 19, 2020, 09:59:17 PM
SuperPete
Thank you SHOadded, all things you mentioned was checked twice and in great working order.
Noisemakers delete - DONE
C-Clip checked.
all hoses vacuum pressure checked, solenoid was even replaced.
BOV diaphragm checked, checked again and looks great.
2014 SHO, GearHead TUNNED /Powered by Matt Robinson
PPE Downpipes, GearHead Intercooler, AirAid Intake
XDI-35 HPFP @ E40,   MSD Coilpacks
MUSTANG DYNO: 426/446
Continental Extreme Contact 06 & Powerstop Z23 all 4 corners
TopherSho
Add in the IAT2 temps to that last data set .. curious ...
Best 0-60 public road 4.35s
SuperPete
here is my for previously posted pull
TopherSho
Quote from: SuperPete on April 13, 2020, 06:49:40 PM
What is your elevation,  the air density should be fine with it under 70f ...  Only thing I can think is elevation playing a factor..
SuperPete
StinkinLinkin, you want to share your info? I would like to see your input also.
I am in PA, 400ft above sea level,
That's what I am saying, all the environment numbers are perfect...
TopherSho
DRAT,  you mentioned DA earlier.  huh .. yeah i am stumped a bit too.  18 pounds is totally doable unless you are on different turbos..  I seem to recall at least one previous member running 20 which i thought was insane ..
Jordan
So everything is perfect and the only thing you "think" is good is the turbos because they only have 31k miles on them. Sounds like you already found the solution just not willing to swap them. Turbos internally could have some drag not allowing them to spin as freely so while visually they look and feel perfect doesn't mean they are.
ridered74
In 3rd gear mine goes up to 18 and tapers down to about 14.5, in 4th gear it holds 18 thru most of the rpms but towards the end tapers down to 16.
Attached picture is what 4th gear looks like.
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
TopherSho
I wonder if the people running full custom hot-pipes hold pressure longer/better?
Jordan
Quote from: TopherSho on April 14, 2020, 01:01:56 PM
I only upgraded my hot pipes when I went upgraded turbos other than the noisemaker delete
SuperPete
Quote from: Jordan on April 14, 2020, 12:07:28 PM
maybe you are correct, I wanted to get everything else checked out before making this kind of investment and to measure it's necessary, right?
Now, I keep seeing often this same issue come up, that's why I brought this up.
Jordan
Quote from: SuperPete on April 14, 2020, 01:26:09 PM
Need the right buddy to get it done on warranty ;)
SM105K
#27
I am almost 100% my turbos are tired. Car made 391/470 E30 tune and K&N drop in only.  I actually lost some boost across the board when I installed the GH IC however my car made the same power.  Less boost more efficiency.
I checked my BOVs, added DP's and a better exhaust.  Even then boost recovery was minimal.  However with the full exhaust HP didnt move but TQ did rise from 470 to 494. Added the noisemaker delete pipe and still have not recovered boost.  Will log to confirm.
SuperPete
Well, larger IC takes longer to build up pressure and harder for tiny turbos to keep pressure up,
Who knows, I been braking my head soo much these 2 weeks, I had nightmares about it.
Anyway, at some point I will upgrade turbos, just not now.
SM105K
Quote from: SuperPete on April 14, 2020, 02:41:00 PM
I have too.  However, I am happy with my SHO as it sits.  It makes good power and I have 100% faith that I can drive cross country in it and arrive safely.  I just cannot justify at this time spending another $4500 to make my SHO a 500/600 car and put it in the extreme zone for trans failure.  The $4500 could be spent for a big fuel system and cams for new my project.  High 3 digit and low 4 digit power is very reasonable for that set up.
