Soo.. my car sits in the garage A LOT... I tend to go about a 4 weeks to 6 weeks before needing to fill up the SHO.. do I need to be worried about E20 sitting too long in the lines?
Two words for you:
"Phase Separation".
Do your research.
http://www.biofuelsdigest.com/bdigest/2016/09/25/new-doe-study-gasoline-becomes-stale-before-ethanol-phase-separation-occurs/ (http://www.biofuelsdigest.com/bdigest/2016/09/25/new-doe-study-gasoline-becomes-stale-before-ethanol-phase-separation-occurs/)
Interesting read... short and sweet... I knew ethanol mixes take on water, just didn't know how fast.
4 to 6 weeks should not be an issue, assuming the car is regularly driven. If it does sit around, add a product like STABIL, or HEET, or Ethanol Drier to every, or every other, tankful.
Quote from: StealBlueSho on April 04, 2017, 12:59:16 PM
Can't assume a linear or static relationship between E percentage and phase separation. BUT it does offer some peace of mind to pump gas users.
More research needed, but note the points about phase separation in this article:
http://petroclear.com/resources/dont-be-phased.php (http://petroclear.com/resources/dont-be-phased.php)
With sitting for 4 weeks I would use stabilize in every gas tank because gas will also start to create a wax surface to the lines and tank I'm not sure if the detergents in gas reverse this.
For one year I let my Subaru sit many months before needing a new tank due to my job and having my wife's car parked behind my car so easier to take hers.
Still haven't seemed to have issues from that except for the charcoal tank seemed to go bad and have issues filling up the take in winter but sometimes in summer issue goes away.
Wife wasn't driving the sho when I left to work so I started using stabilize in the tank when I left. This time she's been driving it so probably not going to do it anymore.
