Started by cseverens, November 03, 2016, 01:25:39 PM
Quote from: nickwalter4 on November 03, 2016, 01:40:33 PMMy Xsport drains 3 qts or less. still takes 5.5 every 5k. this last one i did i only drained like a quart and a half after 5k tuned oil was all sludgey and dark brown. I have an OCC but it doesn't collect that much. low oil was one of a few factors starting to give me problems with VCT actuation/oil control solenoid(s). was litterallly just searching for a topic like this on here because i did the oil change last night.
Quote from: SHOdded on November 03, 2016, 01:35:56 PMProbably just did not drain it long enough. But typically no more than 1/2 will come out at any given time. Was the fluid at FULL before the drain? Maybe he did not use the drain plug? IDK.
Quote from: derfdog15 on November 03, 2016, 01:42:38 PMQuote from: nickwalter4 on November 03, 2016, 01:40:33 PMMy Xsport drains 3 qts or less. still takes 5.5 every 5k. this last one i did i only drained like a quart and a half after 5k tuned oil was all sludgey and dark brown. I have an OCC but it doesn't collect that much. low oil was one of a few factors starting to give me problems with VCT actuation/oil control solenoid(s). was litterallly just searching for a topic like this on here because i did the oil change last night.I think he was talking about transmission fluid? If your car is burning that much oil, you have an issue, and I would look to get that fixed ASAP or you may be looking at replacing a motor in the near future.
Quote from: cseverens on November 03, 2016, 02:21:23 PMso I picked the car up. he said only 3 qts came out, but 5.5 did go in to get it at the correct level. nick and derf, this is regarding transmission fluid, not engine oil.
Quote from: ZSHO on November 03, 2016, 03:04:01 PMQuote from: cseverens on November 03, 2016, 02:21:23 PMso I picked the car up. he said only 3 qts came out, but 5.5 did go in to get it at the correct level. nick and derf, this is regarding transmission fluid, not engine oil.I changed the TOPIC a bit for ya. Z
