MIL Flashing, P0087, P0301, rough idle, hesitation, fuel smell.
Started by Deebeaux, June 20, 2016, 10:36:12 AM
Do you have the OBD troubleshooting guide for your year?
http://www.fordservicecontent.com/ford_content/catalog/motorcraft/OBDSM1404.pdf
I couldn't get it to open, let me know if you have an issue, I have it backed up somewhere if not.
Methinks we should sticky these in the troubleshooting section.....
Gjkrisa
On Android Google PDF viewer works
Quote from: Gjkrisa on June 24, 2016, 06:21:42 PM
Great document. On iPhone it just opens in a new browser window and then I saved it to iBooks which synced it automatically to all of my devices... Back to the OPs problem...
Deebeaux
I do have it, thanks. Someone linked me to it earlier and I searched around in it for the P0087 and the P00C6 seem to point to the HPFP or LPFP typically, but the low rail pressure could be caused by an injector stuck open. Not super clear on how I can determine if an injector is stuck open without just changing it an seeing what happens.
From what I can determine by reading the linked document is the P0087 and P00C6 codes are indicated of insufficient feed pressure to the fuel rail, and the sensors involved are the FLI (fuel level input), FRP (fuel rail pressure), FVR (fuel volume regulator, solenoid on HPFP), and Lift Pump (LPFP). I'm still leaning toward injector as my problem is a single cylinder and I've found three other forum references to the same symptoms and injector was at fault. I think a stuck open injector is plausible to cause low rail pressure if the fault is extreme enough.
The parts I ordered (injector, LPFP, and FPCM) will all be here Wednesday. I'll try swapping the FPCM first, but if that doesn't do the trick I think the injector on cylinder #1 is my next best guess in terms of throwing pars at it. If all three of those parts don't fix it, I suspect a compress test is in order before ordering a HPFP.
Any insight is openly welcomed. Thanks to everyone in this thread. I couldn't have asked for a better welcome to the EBPF community.
Quote from: FoMoCoSHO on June 24, 2016, 06:06:58 PM
2020 Tesla Model S Performance FSD
[SOLD!] 2014 Tuxedo nonPP | 401A, driver assist, nav, multi-contoured seat | AEM drop-in, Unleashed 3bar 93 tune
Sorry a bit late to the SHO.  Z      https://dochub.com[EDIT] Wiring schematics for ya later.
Deebeaux
Ugh. Parts delayed a day. UPS truck had "mechanical difficulties" which caused the delay. Don't worry, the irony is not lost on me. Hopefully this weekend I can get her back on the road. Moved it around back today to have a good place to work on it, startup is unchanged with the white smoke and misfire and a SUPER strong smell of fuel. I keep checking under the car for a Niagara Falls of fuel coming out. LOL.
Hopefully this weekend I can dig into it more. Thanks again to everyone for the help, here's to some progress on this long holiday weekend.
LOL!  Hope the weekend is much kinder to you than UPS has been :)
Deebeaux
UPS delivered. So far, it's NOT the FPCM. Swapped it, problem persists. Dinner and then on to the next likely item, which I'm taking a stab at the injector next, unless someone thinks something else should be tried first.
no easy fix :(  better be the injector ...  take pics of the removal/install if you dont mind.  Noones documented yet.
Deebeaux
Well, I really hope it's the injector. If it's not, it's probably bottom end, which I'm really not in the mood for.
I'll snap some good pics and post them up when done.
Cylinder #1 is in the bank closet to the firewall closed to the passenger side, correct? (I've confirmed that a few times, but want to make sure before I do something really stupid. Lol.
If I decide to run a compression test, what's the best way to prevent the car from firing when starting? Unplugging all the coils?
correct.3 would be opposite/driver side on rear bank.
On most cars, pulling the fuel pump fuse/relay prevents starting the engine.  Let me check.
sholxgt
I think you can floor the throttle and push the start button and it will just crank. Will turn over as long as you push start button. Just release start button prior to letting off throttle.
Best to let SHOdded confirm :)
I know polskifacet did a compression test recently, maybe you should PM him?  But sholxgt's method is kind of the same.  Per the manual, you should definitely remove the spark plugs though.  Flooring the accelerator will cut off the fuel injectors while cranking, but I do prefer pulling the fuel pump fuse for safety reasons.  Can't verify if fuse pulling works here though.
Deebeaux
Here's the "official" Ford procedure...
Compression Test
  • Make sure the oil in the crankcase is of the correct viscosity and at the correct level and that the battery is correctly charged.
  • Operate the vehicle until the engine is at normal operating temperature.
  • Turn the ignition switch to the OFF position, then remove all the spark plugs.
  • Set the throttle plates in the wide-open position.
  • Install a compression gauge in the No. 1 cylinder.
  • Install an auxiliary starter switch in the starting circuit. With the ignition switch in the OFF position, and using the auxiliary starter switch, crank the engine a minimum of 5 compression strokes and record the highest reading. Note the approximate number of compression strokes necessary to obtain the highest reading.
  • Repeat the test on each cylinder, cranking the engine approximately the same number of compression strokes.
I'll pull fuse and FPCM plug as well, just to be safe. I don't have an auxiliary switch hanging around so I'll have to have a buddy toggle the start button.
