New TSB for 3.5 GDI Sartup Rattle 15-0131
Started by BiGMaC, September 05, 2015, 10:19:59 AM
Just started a survey on a 1700 member ecoboost page...truck heavy is the page, and yet more transverse complaints so far
Quote from: SHOnUup on September 06, 2015, 12:33:02 PM
Interesting info....Maybe we need to start a campaign... I figured that even with reduced number of cam phasers in the transverse 3.5 GDI the issue would be common... Maybe we can get Ford to issue a TSB for us.
r1crusher
I've not had this happen on my car w/ just over 41k miles now and it can sit for a week some times.  The wife's truck hasn't shown this particular issue either and she's got just a tick over 38k miles on the '13.  I typically don't look at the mileage when doing oil changes simply because that doesn't take into account any extended idling time (i.e. remote starting or sitting in traffic, etc.) where the ECU should and thusly reduce the oil life % remaining appropriately.  Once I see them hit the 50% mark I plan their oil changes.  I only use Mobil One Extended oil as well as their filters.
But now that this is all coming to a head with this new TSB I'm going to keep an eye on both cars for any startup noises going forward.
'13 SHO, AJP Tune w/ 3-Bar
'17 F-250 6.7 PowerStroke
'17 XSport
Quote from: BiGMaC on September 06, 2015, 12:39:54 PM
Survey is at 8 transverse to ZERO F150 so far (not much action)...couple MKS & Flex...rest SHO
Lol, we are a contrary bunch, lol.....
im not on Facebook, you can add me to the list.
Darren M
Crap, I think my 15 SHO has this. Just noticed it the other day. Subscribing to remind myself to video it.
Just a Taurus
shaneirish
I have a 2010 SHO with 80,000  and I've noticed the rattle since around 39,000 miles most of the time on cold starts.
What are the factors Ford uses before a TSB is generated?  I think most SHO owners thought it was normal so not many have complained.
2010 SHO 20" Wheels, LMS 4X tune, AirRaid CAI, 3-Bar MAP, 160 Thermostat.  TSB's and Failures TSB-11-12-10 - 6F50/6F55 TRANSMISSION. TSB 11-11-09 - INTERMITTENT STEERING DRIFT/PULL. All four wheel bearings replaced winter 2014-2015 (all failed at different times and within four weeks of each other, PTU Failure at 54,000 miles. Climate heat issue fixed, halfshaft issue. Right front strut bearing plate failure at 79,000. TSB installed the thrust washer over the halfshaft.
Haven't a clue what drives a TSB generation, but I'd think a combination of complaints, service calls, and engineer-assisted enquiries meeting some statistical significance.
shaneirish
OASIS MESSAGE :
SOME 2007-2010 MKZ/EDGE/MKX, 2008-2010 TAURUS, 2008-2009 SABLE/TAURUS X, 2009/2010 FLEX/MKS, 2010 MKT/FUSION EQUIPPED WITH A 3.5L V6 OR 3.7L V6 ENGINE MAY EXHIBIT A LIGHT TICKING NOISE AFTER A COLD START WHICH MAY LAST UNTIL ENGINEWARM UP. THE NOISE IS DUE TO THE COMBINATION OF LIGHT LOAD OPERATING CONDITIONS AND THE NORMAL CYLINDER HEAD AND VALVETRAIN CLEARANCES PRESENT IN A COLD ENGINE.THIS NOISE DOES NOT AFFECT PERFORMANCE OR LONG-TERM DURABILITY OF THE ENGINE.
14SHOCAR
Can someone explain the start rattle? Is that where it feels like its misfiring? and you see your rpms dip a bit? I've been trying to chase this issue down with my car.
14 Taurus SHO (Sold)
Quote from: 14SHOCAR on September 14, 2015, 01:47:33 PM
It's like this, but not nearly as bad
http://youtu.be/2yGPqSYGi5E
I know many 11+ F-150 cannot differentiate between a timing chain rattle or a vacuum pump issue,think they have a re-designed pump which seems to be a more feasible solution than the timing chain.  Z
markssho
#43
Thought I would share a startup rattle from my 2010 SHO. Took these videos this summer as it had between 55k-60k miles on it.
http://vid1374.photobucket.com/albums/ag404/markssho/SHO2/VID_20150815_102452538.mp4
http://vid1374.photobucket.com/albums/ag404/markssho/SHO2/VID_20150821_073524526.mp4
http://vid1374.photobucket.com/albums/ag404/markssho/SHO2/VID_20150828_075733945.mp4
On the first link, you can hear it best. I would say that one is around the medium volume level. I've heard it much louder. The other two are not as loud.  It really isn't consistent as far as the loudness goes. That's why it is difficult to capture it on video (who's gonna video every startup).
66 Galaxie
I keep wondering how much a pre-oiler may or may not help protect our engines from any start up rattles due to bad cam phasers and/or the tensioner on the timing chain.
