Started by EcoPowerParts, January 14, 2013, 08:56:36 AM
802SHO
Data log last night cleared me for resuming nitrous tuning.  I will perform a 3rd gear pull log with the 15 shot later today.  I'm interested to find out if I can eventually use the jet for the 35 shot.
I'll be logging a lot more since I had that wierd o2 glitch.
SM105K
Quote from: 802SHO on August 23, 2019, 10:33:16 AM
Let it eat!
FiveLeeter918
New Turbosmart wastegates came in, time to figure out how to get these big bear claws in there to install them...
- Lee
Ortiz Performance Vendor Forum | Find us on Facebook! | Shop Today!
bamsho
Make sure you measure the stock rod length for both front and back.  Had to modify both of my Turbosmart actuators, even though I bought the one for the SHOs.  Rear one is a freakin S.O.B to do.  Good luck.
FiveLeeter918
good to know! I havent even taken them out of the box yet and no instructions seem to exist so we'll see how it goes.
- Lee
Jordan
Got the kit all set up and wired in just waiting on picking up the bottle tonight then some logs
802SHO
Quote from: Jordan on August 24, 2019, 07:34:45 PM
Sweet man!  Let her rip tatar chip!
Jordan
Put everything back together and hid up the nitrous kit to an oem standard! Unless your an expert you'd never know. Car responding well. Sent off a couple logs to see how she is doing.
802SHO
Quote from: Jordan on August 26, 2019, 10:22:27 AM
From what I saw I'd say it's very well hidden!  Nice install!  I'm itching for the 35 shot
nickstewartroc
Got my downpipes and MSD coils installed finally. Hearing the turbos spool more with the downpipes, need to put it back up on the lift and make sure I don't have any leaks. Unfortunately the coils didn't help my slightly rough idle like I was hoping (since so many people have said it's helped their idle)
Current:
2013 Ruby Red Flex Limited EcoBoost, Unleashed Tuned, drop in filter
Gone but not forgotten: 2011 SHO Non-PP in Black Tuxedo Metallic - Catback, DPs, Stoptech Z23s, MDesign CAI, LMS Tune
SM105K
As Shodded eluded too.  The car needs to be re-tuned.
X2 -SHOdded is spot on and most likely need a tune adjustment! Definitely also check the Pre-cat Gaskets for any leaks which will throw off your Fuel trims. Z
nickstewartroc
Thanks guys! Working on getting it re-tuned, I'll shoot Torrie an email for now, haven't had a chance to datalog yet
Current:
Macgyver
#6959
Installed the Performance Engine mounts. I think I went with the Race model. I forget. They are as advertised and nothing that I have not felt before. It does make the SHO sound like a true performance sedan. Almost like a V8 screaming. The shifting is awesome now.
Detailed her top to underside also. Yeah the whole underside got wiped down and any exposed rust nuts, threads, brake fittings got a dose of Fluid film. For being a Pa car. No rust anywhere. Just the rear cross member edges. When I got her at 2 years old. I treated the whole underside for possible future rust. Its holding up well and was worth the effort.
Just for fun I included my 2014 Nissan Juke Nismo RS 6 speed custom lower Engine mount.
