Sorry to take so long to get this up, they have been on for a week now....and I love them! :yell:
Many thanks to Mike and Ecoboost Performance Parts for the pipes :clap2: ..and all the work with Paul and PPE to develop them... without you guys they wouldn't exist.... and they
are worth every penny! Mike has posted a video using my pipes with pipe description also. It's at: http://www.ecoboostperformanceforum.com/index.php?topic=2174.msg30798#msg30798 (http://www.ecoboostperformanceforum.com/index.php?topic=2174.msg30798#msg30798) and a direct link to them in his store is there.
Many Thanks to Jeremy at Black Market Racing for the install and his patience with me taking pics... :clap: and getting in his way as I was "helping" him. I'm an old man, but still enjoy a little wrenching... LOL It is a job that anyone can do if they just know where to hook things up.
Finally thanks to those who couldn't wait and commented before this was done. :bow:
About my particular set of pipes: I chose the ceramic thermal coating option. They're beautiful, should help control heat soak to help our inadequate stock intercoolers, and they match my developing underhood scheme of blackout with rare bright accent.... plus for a little while at least, I'll have a "one of". :coolgleam: The pipes can also be plain or powder coated.
My hotpipes were fabbed to use the two factory BoVs, but these can be ordered to use a really nice single TIAL BoV available in a rainbow of colors. Either way they will convert the turbo blow-off to VTA and will properly eliminate the noisemaker as you'll see.
Points to ponder as you read on: Whether to use the factory setup or the TIAL as far as BoVs and function is a point of personal preference only, since at this point no one objectively knows whether either one is really better for performance. bdp1151 and I have chosen the factory BoV setup (bpd's are powder coated white for his scheme) and I know SwampRat has chosen the TIAL because I had also bought a set of TIAL style from Mike and sold them to SW (if you know SW you know he's going red with them). Both versions have been used successfully. Hopefully there will be some objective testing and comparison over time.
The one thing I suggest for now is that your
primary considerations should be aesthetics and prevention of boost leaks as you consider these hotpipes. If you elevate boost in a tune the factory plastic is prone to failure... Mike has first hand experience trying to chase down the resultant boost leaks form this type of OEM failure.... a real PIA.
OK... Finally...On to the Pics and Tricks!... All the pics can be enlarged by left clicking and the info for each pic is above it
First here's the uninstalled kit:These are the pipes with connection points and a couple of important areas labelled. More about the "shock absorber" later. "TIP" = Throttle-body pressure. The BoV mounts each have two rectangular openings on opposite sides of their mounting bung for quick venting (ie, 2/BoV)... only one is visible here.
(https://i.imgur.com/NgiZRebh.jpg)
Here's the connectors and clamps. High quality hose, stainless connectors and look great! They are grouped together (clamps and connectors) The hump hoses were used to allow the engine motion that the factory "shock absorber" does for the OEM setup. If you've never looked there is a larger than expected anterior and posterior "torque roll" of the engine when it's revved.
Don't try to unscrew the clamps completely. Just loosen the and slip them on the connectors. Be sure to orient them so that you can wrench the nut and the appearance suits you (nuts all point the same direction). More details later. There are three special connectors.. all the others are 2" to 2"... A quick test fit off the car is easy and self explanatory.
(https://i.imgur.com/cRmiLx0h.png)
Don't start the install on a hot engine unless you have a love of blisters :naughty: or long Nomex gloves as several working areas are tight spaces! Remove the stock filter box box or aftermarket CAI and it's air induction inlet first, careful of the sensor, and set it aside. For you stock air guys: just unscrew the clamp from the "saxophone" plastic air pipe behind the box and tease it out.. two press fit securing point are on the bottom.carefully disconnect all the sensors and electrical controls from the BoVs. You will want to remove the entire TIP sensor as it will be used in the install. The back connections and tubing are way down behind the engine ... tight.... some pics later
Here's what you get.(https://i.imgur.com/NgiZRebh.jpg)
Rear stock connections... tight! The view is a close up from the left side to see the OEM turbo to IC Pipe connectionHere's about the best I could do to show the rear turbo to IC pipe (the long one that goes front to back with the BoVs on it) and other connections. The pic was taken from the front left side of the rear turbo to IC pipe. There are several of the push in wire holders that you'll need to gently pry out of the metal plugs to get the relief you need to do the remove and install
(https://i.imgur.com/uwTFlcKh.jpg)
Here's the view of the rear OEM connections from the right side of the engine. no need to label... you get the idea.
(https://i.imgur.com/UaY0HrVh.jpg)
We found it easiest to remove the rear BoV to get access to the spring clamps on the rear BoV recirc hose (the hard one to get to and remove for going VTA with OEM piping). It also let me get a little better pic from the left side of the car. This is one of several pics showing the coating of oily crankcase blow-by from the PCV inside the IC and turbo pipes... after only 7000 miles... a real argument for a catch can! (BTW I have ordered one and a clean side separator to replace the oil breather cap... but that's another install post for later).
(https://i.imgur.com/ZU1ts9Wh.jpg)
The next few pics are final stock pipe removal.The rear turbo to IC out! Following the slight struggle to disconnect the rear turbo from the IC pipe (Be careful about the brake vacuum assist lines crossing the firewall!)... and then .....after removing the engine compartment underpan to get best access the clamp on the rear turbo to IC pipe connector in the lower left front from the IC inlet...We removed this pipe... This pipe is in two parts in the EBPP kit if you remember... a good idea and also allows another hump hose to accommodate the front to back engine motion (check out mike's video linked above if your lost). You see here the hump hoses are important in a minute.
This pic shows the rear turbo to IC pipe removed and the front BoV recirc pipe still on the "saxophone. We found it easier to disconnect it from the IC pipe and then after taking the IC (BoV) pipe out to remove it then due to access. You might also want to access the rear turbo connection to the IC pipe from below, but we did this without using a lift since we knew most guys would.
(https://i.imgur.com/SVoK5gyh.jpg)
Here's the rear turbo connection to the IC pipe after the Stock pipe was removed. It's a reach so have your extensions and wigglers ready for your ratchet!
(https://i.imgur.com/c9jZVpRh.jpg)
Here's the connection port on the left front IC inlet where the OEM IC pipe from the rear turbo connected (from the rear turbo back to front pipe) with the rear to front IC/BoV pipe out. This is left front below where the OEM airbox mounts and easily accessible.
(https://i.imgur.com/ktURHYwh.jpg)
A bigger view of the same as above You have to go from below to even see the front turbo to intercooler connection points other than a slight glimpse of the front turbo output nipple.
(https://i.imgur.com/wdK3Y7Yh.jpg)
Of course we had one more pipe to remove.......the right sided intercooler outlet to throttle-body pipe removed... Easy to see and do. This is of course on the right side of the engine compartment don't have deep pic... sorry, but it is the easiest connection and easy to see... So
the removal is done!!(https://i.imgur.com/M2SLn7Th.jpg)
Just before we install... let's look at a couple of other things.First what do you reuse?... We did not take the
TIP sensor off the car, rather just unscrewed it from the mount on the IC outlet to throttle-body pipe. The pipe was tapped for a diferent screw... but Mike has that corrected now... besides, as you'll see we used shiny black screws of apprpriate size... love it!... I'll be replacing the BoV mounting screws with black in the future. You'll also need the
BoVs and screws if your using OEM BoVs, and you'll need the
rubber bumper of the "shock absorber"... here's some pics of this stuff and some info on them.
Here's a pic of the shock absorber in the Plastic IC/BoV pipe... The left of screen is the front in the SHO and the right of screen is the rear. you'll notice the white appearing (it's actually black) round rubber grommet in the oval sliding channel. It has a hole that mounts over a stud sticking straight up from left side the throttle-body manifold and the grommet moves in the channel when the engine does all that antertior-posterior motion I spoke of earlier.
(https://i.imgur.com/whpeWFGh.jpg)
You'll have to push it out of the channel (easy to do)... and then push the metal center out (easy to do) and save it.. I'll show you what we did on the install. BTW, when you get the pipes off you'll notice a lot of unnecessary bends and flattening of the OEM pipes which can't be good for air flow... These hotpipes eliminate all that.
Here's a pic of what you reuse.(https://i.imgur.com/CiJnwbsh.jpg)
These are the OEM pipes removed... note the shape as I commented above... The noisemaker is in the upper right. Sorry about the blurriness of this pic.
(https://i.imgur.com/ltgoC9Th.jpg)
One last VERY important point... with this install or any VTA conversion... you MUST cap the BoV recirc hose inlet nipples on the OEM air induction... see the pics below.... If you've forgotten you can left click any of the pics to enlarge and see better.
I used 1" diameter by 1.5" long hi temp (600 degree rating) silicone caps to hold up as well as prevent migration with pressure or heat cycling ...from McMaster-Carr. Likely you could get them locally too they are about $1 each in bags of 5 http://www.mcmaster.com/#92805k28/=r0vyup (http://www.mcmaster.com/#92805k28/=r0vyup)
(https://i.imgur.com/In9jLaLh.jpg)(https://i.imgur.com/pqlaemPh.jpg)
Glad you're still with me and I trust this rather long post helps on things beyond just these pipes
On to the install!First we did the IC to Throttle-body install... It's the easiest. The lower end of the connector tubing will be a little short to cover the whole IC outlet nipple, but there is plenty of room for the clamp to be properly applied... Mike has lengthened this hose about 1/2" for future SHO kits... but no worries if you have one now... I have had zero problems... And overall this kit looks STELLAR IMHO.
(https://i.imgur.com/pEHfhgyh.jpg)
Here's the bottom hump hose connection nipple from the IC outlet to the pipe going to the throttle-body. This pic was HARD to get. The nipple on the IC is about 1.5" long and at least an inch is covered allowing proper application of the clamp. No Worries.
(https://i.imgur.com/ZsExDSgh.jpg)
Install of the rear turbo to the rear to front pipeNext we installed the modified "shock absorber" grommet below the tab on the rear turbo to IC pipe. It goes over this stud on the top right of the engine... leave it loose until the turbo to IC pie connection is made at the back of the engine.
Here's the two things that go together.... You will place the rubber grommet from the stock pipes over the stud first... I recommend a Nylok or other self locking type of nut to secure it. Of course, the back connections are made to the turbo outlet and the connector for the piece going from the IC pipe pictured to the connector pipe that will go to the IC (in left front) from the rear turbo is loosely put on the free end.
(https://i.imgur.com/AiCRvk2h.jpg)
Here's the rear turbo output connection with hump hose.(https://i.imgur.com/bvIchkCh.jpg)
Below is a better view of the rear turbo output connection.(https://i.imgur.com/qeHfMWAh.jpg)
After connecting the IC/BoV pipe from the rear turbo to the pipe that will connect from there to the dedicated IC inlet for the rear turbo into the IC in the lower left of the car it looks like the pic below. BTW the front and rear turbos each have a dedicated IC nipple for input. Note that the nut is now holding the hotpipes to the stud in the manifold mentioned before and the rubber grommet is between the tab on the hotpipe section and the manifold to eliminate vibration. The lower connection to the IC input nipple was also made and everything on these two pipe sections tightened up.
(https://i.imgur.com/R7Es2YWh.jpg)
Now on to the b*tch of the whole job :boom: ... It MUST be done from underneath and it is tight. Putting that short 1.5" to 2" pipe in the lower left front of the car to connect the front turbo to it's dedicated IC input nipple is tedious and very space limited for hands and wrenches. I only have one pic 'cuz we were concentrating on the job.
A lift might help, but I don't know if removing the left front tire/wheel or drive-up jacks would be much aid. The pic was taken by putting the camera up in the tight space while under the car and just shooting until there was a reasonable pic...
BUT it
was done with the car on the ground. Thanks again Jeremy! It took about 20 minutes to do this part... the shortest connection... Jeez! :pat: The trick is to put the hoses on the pipe... then slip the one on the large (IC) end all the way up on the pipe to gain working space. Then,
after the front turbo is connected.... just slide the connecting hose and clamp down the pipe and on to the the IC connector nipple. :thumb:
Oh yea, be sure all your clamps are one this pipe
before you start!
Here's the front turbo to it's dedicated IC inlet connection below.(https://i.imgur.com/uzSS6iOh.jpg)
Here's the whole set installed with the BoVs and electrical connections made... and double checked to avoid malfunction or CELs.(https://i.imgur.com/ZmJYCLHh.jpg)
We then reinstalled the OEM air induction box and connected it up... and started the car to be sure.... Viola' .. 2.5 hours were not wasted! ;D
I knew from talking with bpd 1151 that the engine cover would need modifying... Mine is a little different than what he had to cut off that awesome true CF engine cover he has. In my case Jeremy had to cut a small wedge out of the rear left corner to accommodate the rear BoV due to the beefed up bung (which I would not change!) It looks just fine... thinking of having a custom CF made anyway.
Here's the cut we made in the cover and then the final job completion pic. YAY!!... and look at that sweet pipe in the right front of the car! :shades:
(https://i.imgur.com/q2Xb6UEh.jpg)
and a closeup mounted... BTW, no rattles in a week and no functional problems. it fit right on the pop connectors sticking up from the engine.
(https://i.imgur.com/3ClbCW2h.jpg)
The finished product... that cut is not noticeable and enough of the pipes show to really add something aesthetically IMHO. :dance2:
(https://i.imgur.com/HANsP9gh.jpg)
Thanks to all the troopers who looked this far. :bigthanx: I hope that you, like me, learned some things about the SHO and the 3.5EB engine beyond just installing the EBPP hotpipes.
When I get my black shiny RX catch can and Cleanside separator it will be plumbed with black braided hoses and shiny black true AN connecters. At that time I hope to use the same hoses and connectors for all the tubing to replace the rubber push on barb hose there now.... And I'm gonna do something with the stock air box appearance too.... but..... That will be another story!
I know the how to isn't done yet , but a Superb write up and excellent illustrated picture's .
I am sure what follows will be awesome as well .
I am curious though if 4DR could get the silicone connectors in RED ?
Very nice illustration..
Two questions...
Is there any reason to believe the metal hot pipes would aid in "heat-soak"???
Also, really really wish I could get these for the xsport....
Great write up so far Tom! I love the annotated pictures. Your pipes did come out beautiful!
Oh yeah!!
Seriously jealous too!
Sent from my iPhone using Tapatalk (http://tapatalk.com/m?id=1)
Quote from: bigmoneycloser on March 09, 2014, 06:28:42 PM
Two questions...
As BigMac stated , THE primary reason for for getting this is to prevent boost leaks with upgraded turbos and/or higher boost levels .
The second reason being asthetics .
In there testing they were not able to see any real conclusive benefits with thermal coating in regards to heat soak.
Quote from: SwampRat on March 09, 2014, 04:14:43 PM
I sent PM to 4DR and the RED ones are on order for me .
That will look sick!
Hi All... Thanks to those so anxious to look that I wasn't finished yet... I'm flattered
My original post finished now with pages of pics is at: http://www.ecoboostperformanceforum.com/index.php?topic=2248.msg32460#msg32460 (http://www.ecoboostperformanceforum.com/index.php?topic=2248.msg32460#msg32460)
Thanks again Tom. This write up is really one for the books. I know that many guys here will find it very useful. Heck, I might even do it (have it done) now!
Quote from: SwampRat on March 09, 2014, 06:59:06 PM
Two questions...
Actually the coated hotpipes have not been tested for heat soak or it's effect, if any, on performance... underhood temps may be useful. So , as I said it's effects are unproven as far as that, but that's not why I got them as I said... the downpipes were tested... sorry if it caused confusion.
Well ....... We will see , I doubt it will make any difference ... Could be wrong though ...
Anyway As I said before ... GOOD Job on the How To .
My Laptop will be fired up during my install in a few Days.
I ' ll change out the Visible Silicone connectors to the RED ones when I get them .
My HotPipes are being refinished in RED of course as we speak . LOVE that anodized RED Tial BOV ! !
Awesome packing job BigMac ..
My PPE non catted Downpipes will be here tomorrow .
Thanks Tom for the write up, great job!
Thanks Guys! Appreciate you all taking the time to look. Just trying to take the mystery out of things
tom:
great writeup for sure & a beautiful set of pipes. swrat- got to have pics when you get it done in red with the painting i've done under the hood this would put the the look of the engine completely over the top & I love over the top.
mikev
Thanks Mike .... don't forget the pics of your new wheels when thy arrive!
Quote from: mval on March 10, 2014, 11:12:26 AM
tom:
mikev
Here they are ...
(https://i.imgur.com/ENqCFihh.jpg)
I like the idea of custom charge pipes but mine will have to be black or silver. If I had a blue SHO, maybe blue would be alright.
Excellent write up, very detailed. I assume I can use for my 2010 if I decide on hot pipes?
Brad
2010 SHO with PP
Sent from my iPhone
Quote from: FracaSHO on March 11, 2014, 01:11:54 AM
Brad
2010 SHO with PP
Sent from my iPhone
The PPE hotpipes should fit 2010 and up and the install should be good also... minor differences likely......
Enjoy! :thumb: You feel faster even if your not... (http://i1331.photobucket.com/albums/w596/knot2bfound/Junk/clip-art-speedy-gonzales-716677_zpsd3a37279.jpg) (http://s1331.photobucket.com/user/knot2bfound/media/Junk/clip-art-speedy-gonzales-716677_zpsd3a37279.jpg.html)
This thread is like torture for me...
Lol
Have a great day... Off to the jet plane..
Two questions...
No objective evidence exists that metal pipes help with heat soak... In daily driving anything will become heat saturated over time. In going to the black thermal ceramic coating (only available in black... just happened to match the scheme I doing) I hope to delay heat soak as well as speed radiation of the heat from the pipes (faster cool off)... it's a cat and mouse game in the relatively closed SHO engine bay. Still no performance gain or loss is really anticipated beyond prevention of boost leaks.
BTW, I'm considering having the raised center of my hood modified to have a 1" cowl vent to let the engine compartment breath better... then we'll see. I don't notice anything during the 10 days or so that I've had them on.
I'm sure that they could be fabbed for the Xsport.... It would just be needed here in Phoenix for a couple of days. I've worked with Paul on adjusting fitment and it's painless... You'd have a "one of" ... at least for a while!
I found something that I think would be a good addition to the HotPipe Kit and polish the look up even more.
It took a lot of digging and I think these will work , 4DR can let us know for sure .
The 4 Large Clamps that are very visible on top are the ones that I want to change .
The two going into the TB and the two on the drivers side top .
I think I think they are 2.5" and 3" clamps , at least I hope so.
They are Proflow 150 silicon hose clamps
The clamps I have found are only available in Australia and are made there.
This website sells these and ships to the US and they take PayPal.
(https://i.imgur.com/8OTDTJnh.jpg)
They are available in Red , Black , Blue and Silver
Personally love the clamps Mike has included. more secure... maybe just take them and paint them red or blue, etc.
Quote from: SwampRat on March 14, 2014, 01:00:54 AM
(http://i1287.photobucket.com/albums/a628/kbeck59/redclamp_zps42c5f160.jpg) (http://s1287.photobucket.com/user/kbeck59/media/redclamp_zps42c5f160.jpg.html)
You guys are welcome to customize your kits however you want but I can't increase the price of the kit any more, it's already expensive in my opinion. the clamps I include work very well and are cost effective, great combination. :)
I found something that I think would be a good addition to the HotPipe Kit and polish the look up even more. They are available in Red , Black , Blue and Silver
Pretty but...Personally love the stainless clamps that Mike includes with the kit now as they are better made for hose clamps... the hinges are an engineering weakness as are the oval cutouts... just take them and paint them red or blue, etc. if you want.... or get custom made for your preferences if you want them.... or have a different scheme. Solid performance and a balance between cost effectiveness and appearance were clearly the goals the goals of the kit.
Quote from: 4DRHTRD on March 14, 2014, 01:22:59 AM
Quote from: BiGMaC on March 14, 2014, 01:25:28 AM
(http://i1331.photobucket.com/albums/w596/knot2bfound/Hotpipes/1-Hotpipesconnectorslabelled_zpsac74d008.png) (http://s1331.photobucket.com/user/knot2bfound/media/Hotpipes/1-Hotpipesconnectorslabelled_zpsac74d008.png.html)
I was'nt suggesting these be added to your kit , It was meant to be considered as something others may consider to do on there own .
4DR What are the sizes of the clamps that I mentioned ?
BigMac , I disagree with you on the structural integrity of these clamps . If I can get them in the correct size I will try them .
Understand completely. Thanks for the opinion.... trying things is what modding is about for sure, Sorry to confuse... didn't mean that the clamps were structurally unsound. My comment was actually not about the strength of those clamps, but their function in the application. I still must point out the engineering weakness in a hose clamp that doesn't completely and equally compress the entire circumference of a connection of a hose between two hard surfaces given the motion of our engines anterior to posterior (which the hump hoses are designed to compensate for) from the start of tightening such as the ones you posted as well as the limitations on the amount of force that can be applied to the entire circumference when the object of the kit is no boost leaks including hose failure. Let's just agree to disagree on this point.
Illustrations of the difference with full circumference compression from the initial application can be seen in the pic I posted and here in the install:
for more on these clamps info likely is best found here:
http://www.ecoboostperformanceforum.com/index.php?topic=2113.msg33365#msg33365 (http://www.ecoboostperformanceforum.com/index.php?topic=2113.msg33365#msg33365)
Let's move on to constructive & on topic posting and let everyone just decide rather than anyone post repetitively... Cheers, NHF :beer2:
The clamps I buy are ordered by silicone tubing size, makes it easy for me if I need a 2.5" silicone hose clamp that's what I order. :)
I've tried the whole order a size bigger scenario and ended up with a crap ton of extra clamps :D
I belief the clamps and couplers in the kits are from siliconeintakes. I have been using there stuff for over 10 years now any never had a problem. I swapped out couplers at the intercooler and TB with hump couplers to give a little more flex at as the motor moves when I installed my kit.
I use all hump pipes now except IC to TB pipe as it needs the extra length of a straight connector.
On the hot pipes, is there a spot for meth? I thought i remember when there was a group buy up for these, that it was a option but i don't see it in the store?
Quote from: Josephm on March 14, 2014, 02:44:45 PM
I have not knowingly seen a set made that way... but it's a great idea for an option if it doesn't currently exist!
Maybe some Hotpipe and Meth users like bpd will chime in
I opted NOT to have a hole designed into my hot pipes.
I instead, drilled a hole into the bottom of the silicone hose, that is pre-TB.
Been working just fine.
Quote from: BiGMaC on March 27, 2014, 12:15:52 AM
(https://i.imgur.com/Ela53Qlh.jpg)
Two pics of mine ... look a backside of TB inlet .
(https://i.imgur.com/dTz0tU9h.jpg)
4DRHTRD's Flex with Tial BOV and HotPipes
(https://i.imgur.com/QGswMzLh.jpg)
So there you have it joseph! :icon_wink:
It looks like adding a Meth injection site to the hotpipes has been done both with and without special fabrication on the hotpipes. SwampRat's HPs were originally 4DRs (who developed the pipes). So I'd bet you could have it done if you asked him for it in the fab.
Thanks guys.
I bought a set of these used from a buddy who traded in his SHO. I plan to install them this weekend on my EB Flex. The set I bought has the Tial BOV. Can someone who has the Tial setup tell me where you spliced for the vacuum reference on the BOV?
svt54 if you would be kind enough to follow the new members INTRO section simply by following this link and Due post some pic'a of your current setup. Z http://www.ecoboostperformanceforum.com/index.php/board,14.0.html (http://www.ecoboostperformanceforum.com/index.php/board,14.0.html) BTW there are a couple of ways off doing it but found it much easier tapping into the brake vacuum line using a 3/8 brass tee barb and will have some good pic's for ya tomorrow morning cause it has been a long day,think SHOdded was the only one to see my setup in person,thanks. Z
Definitely even better in person.
For those that removed the stock charge pipe, what are those plastic band clamps that couple the hoses to the plastic charge pipe? How are they installed/tightened/removed?? Are they physically attached to the hoses or could I dremel them off and replace with SS liner clamps?
Quote from: metroplex on February 01, 2017, 04:57:25 PM
They are not serviceable; Permanently molded clamps.
I had the same style clamps on the SHO intake piping I bought to install the AJP boost regulator on my XSport.
Long story short, you can use a Dremel cutoff wheel and carefully cut through them. I cut about 90% of the way through and stuck a flat blade screwdriver into the slot. A firm twist will separate the remaining plastic and leave the hose unharmed. Replace with your choice of clamp. :)
X2 they R not serviceable and would say the plastic band to be the weak point of the intake charge pipes and AFAIK are susceptible to leak and split sooner then later and the very reason i went with the PPE Hotpipes from Mike.B at www.ecopowerparts.comfrom (http://www.ecopowerparts.comfrom) pics below. Z
(http://i.imgur.com/jmewHK7h.jpg?1)(http://i.imgur.com/G7vnUDRh.jpg?1)
Thanks guys.
Any idea on the size of the hose OD? I have a bunch of liner clamps, just want to make sure I have the right size. Would it be about 2" OD?
The EPP Hot Pipes look great, but I'd be more concerned if the rubber hose constantly tears apart or if the plastic charge pipes split apart and would consider the EPP hot pipes at that point.
I believe its a 2"IDX1.5"ID (Hump) Hose coupler needed based on video below. Z
[url=http://www.youtube.com/watch?v=lYO3XFt0bZU#]! No longer available] (http://[/url)! No longer available (http://www.youtube.com/watch?v=lYO3XFt0bZU#)
I found this thread to be almost as articulate and extensive as bpd1151!. LOL. Z
I literally just finished installing these on my 2014 PI, that rear pipe was leaking oil at the connector, and EPP had a Tax Return discount... perfect timing. :-) I'm not sure yet how I like the VTA sounds, but I can always turn up the stereo.
Took about 2 hours, and to stop in the middle to go get some deep sockets - doh. YUGE shout out to BigMac - your pic's and writeup made this almost easy! So thanks a million for that!
