- RotM Winner
- Elite Member
- Boosted
- Logged
I removed my passenger axle and knuckle/rotor/wheel bearing assembly and was able to fairly easily maneuver the rear turbo out, also put it back up that way as well. I did this with the front of the car on jack stands from my back. I didn't drop the subframe.
