Hey guys i'm a newbie to the forum and the tuning world my tuner asked me to reset my KAM after putting in the tune. I have no idea what that is and can this be done with my SCT X4 device? if so how? I tried to find it on youtube but not having great luck. If anyone can help me out it would be greatly appreciated. I emailed the tuner but where its a weekend i'm not expecting much, people have lives outside of tuning. Thank you in advanced..
Connect your sctx4 to you car, hold the start button until the gauge cluster does a full sweep(same as if you are going to tune it), go to Vehicle Functions -> Special Functions -> KAM Reset -> confirm
It will say reset completed or something similar. It takes a split second to do.
KAM is Keep Alive Memory in the ECU.. so it resets fuel trims, OAR, transmission learning, etc...
Enjoy!
X2 ^^ and Welcome Hut1 ! and due setup an intro @ your earliest convenience. Z
https://www.ecoboostperformanceforum.com/index.php/board,14.0.html (https://www.ecoboostperformanceforum.com/index.php/board,14.0.html)
http://youtu.be/hZAsoqmqhdM (http://youtu.be/hZAsoqmqhdM)
THANKS for the help, I appreciate it.
Speaking of resetting the KAM, why would this be necessary after the OP put in his tune? Brad had me do this once, which I did with the X4, but I never knew exactly why. I have changed tunes and had several tune revisions over the past few weeks. Should I do another KAM reset and, if so, why?
Quote from: Brucelinc on September 24, 2017, 10:43:50 AM
I think it depends on your MY... The 2010-2012 appears to reset almost all the KAM when you do a flash. Hence why my OAR ALWAYS resets after anytime I flash. On the 2013+MY the KAM doesn't get reset on a tune flash. So resetting the KAM maybe beneficial to give the ECU a baseline of 0 to adjust the fueling and transmission adaptive's to settle for the new tune?
I know personally when I switch tunes (which I do a lot of) I ALWAYS do a KAM reset afterwards just to make sure it is starting from scratch for the adaptives. I could all be completely placebo but I feel my transmission does better this way..
[/quote]
Interesting. I just did it the one time that Brad asked me to. Yesterday, I removed my E tune and flashed the 93 octane tune since we are taking a trip and I don't want to mess with mixing fuel along the way. Maybe I should do the KAM reset - although the car runs fine and the transmission seems to behave the same as it did with the E tune. There should be no harm in doing the KAM reset but I thought all of the adapting would take place as the car is driven anyway.
A KAM reset doesn't go all that deep, primarily it is PCM related. For the TCM, you have specifically go in and clear the adaptive tables if there are continued issues after a KAM reset, for example. So there may be many parameters that we don't know about that get touched by the KAM reset that would otherwise be "assumed values" by the PCM. Maybe Brad can shed some light on where these parameters can be found.
