SSM 44863 - Effective Dec 11 2014 2010-2015 Multiple Vehicles - Flutter/Turbulance Noise At Highway Speeds With Rear Windows Or Moon/Sun Roof Open
SSM 44856 - Effective Dec 8 2014 Various 2011-2015 Vehicles - Cruise Control Speed Setting Display May Not MatchSpeedometer
SSM 44829 - Effective Nov 20 2014 Various SYNC Equipped Vehicles – Apple iOS 8 and or iPhone 6 Functional Issues
TSB 14-0213 - Effective Nov 12 2014 Multiple Vehicle Lines Equipped With 3.5L TiVCT Or 3.7L Built on 1/3/2012 and Through 7/31/2012 - Malfunction Indicator Lamp (MIL) On With DTC P1450
TSB 14-0209 - Effective Nov 10 2014 2011-2015 Various Vehicles - Shift To Park Message - While In Park / Unable To Remove IKT / Shifter Stuck In Park / Discharged Battery Due To Shift To Park Light On
TSB 14-0196 - Effective Oct 17 2014 2010-2014 3.5L GTDI - Excessive Oil Consumption And/Or Smoke From The Exhaust At Idle During Normal Engine Operating Temperature - Aluminum Valve Cover
SSM 44763 - Effective Oct 15 2014 New Wiring Repair Job Aid is available on PTS under the Service Tips tab
TSB 14-0186 - Effective Oct 6 2014 2011-2015 Explorer/Taurus 2011-2014 Flex/MKT/MKS - Ting/Pop/Click Noise - FrontHalfshaft
TSB 14-0175 - Effective Sep 19 2014 Various 2011-2014 - MyFord Touch/MyLincoln Touch - Ambient Lighting Defaults ToWhite Or Ice-Blue After Cycling Ignition Switch
SSM 44707 - Effective Sep 11 2014 2009-2015 Vehicles Exhibiting Diagnostic Trouble Code (DTC) P06B8, P068A And/OrP2610 After Powertrain Control Module Reprogramming
SSM 44690 - Effective Sep 1 2014 2013-2015 Explorer, Taurus, MKS Exhaust Studs Not Missing
SSM 44689 - Effective Sep 1 2014 2010-2015 MULTIPLE VEHICLE LINES - DIAGNOSTIC PRACTICE OF MODULE SWAPPING OR LIKE VEHICLE ORDERING IS NOT RECOMMENDED
SSM 44676 - Effective Aug 21 2014 New "Live Network Monitor Test" available on PTS.
TSB 14-0132 - Effective Jul 22 2014 Easy Fuel Capless - Concerns With Fuel Nozzle Insertion Or Removal
SSM 44649 - Effective Jul 17 2014 2007-2015-Multiple Vehicles Equipped With All Wheel Drive-PTU Job Aid in Service Tips
TSB 14-0123 - Effective Jun 30 2014 2013-2014 Escape, Fusion, MKZ, Taurus, Flex, MKS, MKT - HD Radio Inoperative -Diagnostic Trouble Code (DTC) U3000:96
SSM 44628 - Effective Jun 30 2014 Multiple Vehicle Lines - Radio Can Be Turned On With Ignition Off and Door Open- Audio Extended Play Mode - Normal Operation
SSM 44582 - Effective Jun 6 2014 Unexpected Scan Tool And/Or Vehicle Electronic Module Behavior During Diagnostics
SSM 44578 - Effective Jun 4 2014 2007-2014 Vehicles Equipped With All-Wheel Drive And A 6F50/55 Transmission-Leak At The Power Transfer Unit Output Shaft Seal
SSM 44564 - Effective May 29 2014 2011-2014 Explorer,Taurus,Flex,Edge,MKX,MKT,MKS Workshop Manual Updates For Rear Brake Service
SSM 44553 - Effective May 22 2014 2013-2014 FWD Vehicles - 3.5/3.7L - Engine Oil Leak At Right hand Head-to-Block-to-front cover T-joint
TSB 14-0105 - Effective May 19 2014 2013-2014 Explorer, 2012-2014 Taurus, MKT And Flex - 3.5L GTDI Diagnostic Trouble Code (DTC) P0087 - Built On Or Before 6/1/2014
SSM 44546 - Effective May 19 2014 Dealer Installed Audio Upgrades
SSM 44531 - Effective May 2 2014 2009-2014 F-150/Taurus/Flex/MKT/MKS, 2010-2015 F-Super Duty, 2011-2014 Explorer Power Seat Track Binding/Seized, Grind, Squeal, Popping Noise Moving Forward or Rearward.
SSM 44469 - Effective Mar 27 2014 3.5L and 3.7L Lower Engine Noise, Timing DTC's or Internal Engine Damage after Crank Pulley Removal.
SSM 44461 - Effective Mar 21 2014 Various 2005-2014 - License Plate Lamp Water Entry Or Oxidation
SSM 44454 - Effective Mar 20 2014 Lower End Engine Noise Diagnostic Aid
TSB 14-0057 - Effective Mar 14 2014 All Wheel Drive - Fluid Leak From Rear Differential Vent Cap - Temperatures Below 0 Degrees C (32 Degrees F)
TSB 14-0037- Effective Feb 21 2014 Global Positioning Satellite Module (GPSM) - Navigation Display Offset Or Incorrect Position Built On Or Before 1/6/2014
TSB 14-0032- Effective Feb 19 2014 2013-2014 Explorer/Taurus/MKS/- AWD - Leak From PTU - Built On Or Before 12/11/2013
TSB 14-0023- Effective Jan 30 2014 2011-2014 Taurus - Headliner Dropping Down And/Or Loose At Rear Window Glass
SSM 44381- Effective Jan 28 2014 2011-2014 - Gasoline Vehicles - Updated PC/ED Diagnostics to Address P013A or P013C
SSM 44375- Effective Jan 24 2014 2013-2014 Taurus/Flex/MKS/MKT/Explorer - Fuel/Emission Line Retaining Clip - Now Available
SSM 44355- Effective Jan 15 2014 3.5L and 3.7L Lower Engine Noise, Timing DTC's or Internal Engine Damage after Crank Pulley Removal.
SSM 44333- Effective Dec 13 2013 2011-2014 All-Wheel Drive Vehicles Equipped With PTU Cooling
SSM 44330- Effective Dec 11 2013 "No PCM Communication" Job Aid in Service Tips.
SSM 44328- Effective Dec 11 2013 SOME VEHICLES COULD EXHIBIT MISFIRE CODES AFTER CERTAIN REPAIRS - MULTIPLE VEHICLE LINES
SSM 44315- Effective Dec 4 2013 2013 Model Year Explorer, Taurus, MKS, Flex, MKT, Fusion, MKZ, and Police Interceptor Utility and Sedan Vehicles may exhibit a fuel odor or hesitation.
TSB 13-12-02- Effective Nov 19 2013 Dirt Accumulation On Rear Door Scuff Plates
SSM 44227- Effective Oct 10 2013 2013-2014 Taurus, Edge, Explorer, Flex, MKT, MKS, MKZ and MKX - DTC P0709 Pinpoint Test Workshop Manual Update
TSB 13-10-06- Effective Oct 4 2013 MyFord Touch/MyLincoln Touch - Various Functionality Concerns - Built On Or Before 8/15/2013
SSM 44206- Effective Sep 27 2013 2010-2013 Multiple Vehicle Lines - Adaptive Cruise Control Module Alignment Job Aid
TSB 13-09-22- Effective Sep 25 2013 SYNC - Various Functionality Concerns
SSM 44156- Effective Aug 26 2013 IDS Coil On Plug (COP) Stress Test Application Usage
TSB 13-08-07-Effective Aug 20 2013 2012-2013 Multiple Vehicle Line -Intermittent/Inoperative Integrated Keyhead Transmitter (IKT) -Built On 9/1/2011 And Through 12/1/2012
SSM 44144-Effective Aug 19 2013 Multiple Vehicle Lines -Workshop Manual Update -Audio System -Section 415-00
SSM 44112-Effective Jul 30 2013 2013 Edge/Flex/Taurus/Explorer/MKS/MKT/MKX –6F50/6F55 Transmission –Built before 4/15/13 -MIL With DTCs P0741 And P1744 With No Additional Symptoms
SSM 32320-Effective Jul 12 2013 Multi-Vehicle Gasoline Engine Failure Analysis And Tips -Job Aid Release
TSB 13-06-11-Effective Jun 11 2013 2013 Police Interceptor Utility And Sedan - Front Door Window Glass Sticking Or Binding - Built On Or Before 3/26/2013
SSM 32241- Effective May 24 2013 2011 - 2013 Multiple Vehicle Lines With MyTouch - Touchscreen Calibration Process
SSM 32238- Effective May 23 2013 2013 Edge, MKX, Flex, Taurus, MKT, MKS, MKZ, Explorer Equipped With A 6F50 Or 6F55 Transmission Built On Or Before 10/26/12 With Slippage During Shifts
TSB 13-05-14- Effective May 13 2013 2011-2013 Explorer/Flex/Taurus/MKT/MKS - Ting/Pop/Click Noise - Front Halfshaft
SSM 32213- Effective May 8 2013 2013 Multiple Vehicle Lines - Workshop Manual Update - Voice Recognition - Section 415.00
TSB 13-04-16- Effective Apr 24 2013 6F50/6F55 Transmission - Intermittent No Upshift - Stuck In 1st Gear - No DTCs - Built On Or Before 9/22/2012
SSM 32173- Effective Apr 5 2013 2013 Police Interceptor Sedan/Utility - Active Transmission Pursuit Mode - Updated Workshop Manual Section 307-01
SSM 32163- Effective Mar 29 2013 2009-2013 F-150/Taurus/MKT/MKS, 2011-2013 F-Super Duty/Explorer - Power Seat Track Bind/Seized, Grind, Squeal Noise Moving Forward or Rearward.
SSM 32153- Effective Mar 26 2013 2009-2013 Brake Rotor Protective Soft Cover Removal
TSB 13-03-11- Effective Mar 20 2013 Global Position Satellite Module - Traffic Directions And Navigation - Unable To Locate Vehicle - Built On Or Before 01/15/2013
TSB 13-03-01- Effective Mar 1 2013 2013 Explorer/Taurus/MKS - Hazard Lights Staying On - Brake Warning Indicator On Keyless Entry Illumination On - Multiple Door Ajar Lights On With Doors Closed
TSB 13-01-13- Effective Jan 31 2013 2013 Escape/Fusion/Flex/MKT/MKS/Taurus - Audio Static Popping - Distorted Sound - Stereo To Mono Change On FM - Built On Or Before 12/10/2012
TSB 13-01-01- Effective Jan 3 2013 Vehicles with Easy Entry / Easy Exit Feature Power Telescoping/Tilt Steering Column Does Not Return To Correct Position
SSM 12055- Effective Dec 6 2012 2009-2013 Multiple Vehicle Lines - Battery Light Flickers - Stays On - Low Charging
TSB 12-11-08- Effective Nov 15 2012 Radio With 4.2-Inch Display Stays On 20-30 Seconds After Key Off And Door Open
SSM 12019- Effective Oct 29 2012 Low Current Switch Failures Due To Improperly Installed Accessories
SSM 22553- Effective Oct 19 2012 AUTO TRANS - MERCON LV FLUID COLOR
SSM 11024- Effective Oct 17 2012 2013 C-MAX/Focus Electric and Fusion/MKZ Hybrid - Instrument Cluster Functionality
SSM 22524- Effective Sep 27 2012 6F50/ 6F55 TRANSMISSION - NEW SERVICE TOOL FOR TRS RETAINING PIN REMOVAL
SSM 22512- Effective Sep 14 2012 LOWER END ENGINE NOISE DIAGNOSTIC AID
TSB 12-09-02- Effective Sep 10 2012 DIRT ACCUMULATION ON REAR DOOR SCUFF PLATES
SSM 22501- Effective Aug 30 2012 6F50/6F55 TRANSMISSION MOUNTING BOLT QUANTITY CHANGE FROM 11 TO 10
TSB 12-08-12- Effective Aug 15 2012 ALL WHEEL DRIVE - FLUID LEAK FROM REAR DIFFERENTIAL VENT CAP - TEMPERATURES BELOW 32 DEGREES F (0 DEGREES CELSIUS)
SSM 22473- Effective Aug 10 2012 SERVICEABLE FUEL LEVEL SENSORS
SSM 22456- Effective Jul 31 2012 SYNC - APIM REPLACEMENT/PROGRAMMING - CONFIGURATION ERROR
TSB 12-07-03- Effective Jul 10 2012 MISSING PIDS FOR ALL WHEEL DRIVE (AWD)/4 WHEEL DRIVE (4WD)
SSM 22421- Effective Jun 28 2012 ACCESSORY (WIRELESS) KEYLESS ENTRY KEYPAD IS APPLICABLE WITH REMOTE KEYLESS ENTRY (RKE) ONLY AND THE RETRIEVAL OF MASTER CODE.
SSM 22416- Effective Jun 27 2012 2010-2013 MULTIPLE VEHICLE LINES - WIRING DIAGRAM SECTION 5 UPDATE FOR SUPPLEMENTAL RESTRAINT SYSTEM (SRS) CONNECTOR REPAIR
SSM 22387- Effective Jun 6 2012 BRAKE OVER ACCELERATOR FEATURE - 2011 - 2013 FORD AND LINCOLN PRODUCTS
SSM 22357- Effective May 16 2012 2010-2013 MULTIPLE VEHICLE LINES - DIAGNOSTIC PRACTICES OF MODULE SWAPPING IS NOT RECOMMENDED DUE TO THE MODULE'S ARCHITECTURE.
SSM 22343- Effective May 3 2012 2009-2013 MULTIPLE VEHICLE LINES - SIRIUS SATELLITE SUBSCRIPTION ASSISTANCE JOB AID
SSM 22339- Effective May 2 2012 2009-2013 MULTIPLE VEHICLE LINES - LIMITED NUMBER OF SATELLITE CHANNELS MAY OCCUR WHILE USING THE SEEK FUNCTION - SERVICE TIP
SSM 22324- Effective Apr 18 2012 2011-2013 MULTIPLE VEHICLE LINES - INVISION DUAL HEAD RESTRAINT DIGITAL VIDEO DISC (DVD) - REAR SEAT ENTERTAINMENT SYSTEM SUPPLEMENT
SSM 22280- Effective Mar 21 2012 2011-2013 EXPLORER, EDGE,MKX, 2011-2012 F-150 AND F-SUPER DUTY, 2013 FLEX, TAURUS, MKS AND MKT ADD ON EQUIPMENT CAUSING RUN-ON
SSM 22226- Effective Feb 21 2012 TORQUE CONVERTER LEAK TEST - (NON-6R60-75-80)- AUTOMATIC TRANSMISSION
