I have confirmation that two new turbos will be released to the public on 9/13!
Here's the latest news!
For the Flex/Taurus engine, looks like we will offer two turbo sizes:
+1 which is 100-200 rpms laggier than stock but will do 100-150HP more flow over
+2 which is 400-500 rpms laggier than stock but will do 150-200 more flow over stock. (slightly larger than a GT20)
$2200.00 + core charge ship date 9/13
For the F150 there will only be the +2 size and no +1 size. ship date 9/20
$3000.00 for the trucks
Guys I'm ready to start taking deposits on turbos! $100.00 holds your spot for the first sets!
I'm ready to get these into your hands ASAP!
Rough Kit Price, Tech Info on each package, What company? Etc. Etc.
I'm sure you'll have deposits with more info having been posted.
Take a look, you've even caught the attention of EcoBrickBob!
He's practically waiting on the edge of his wheel chair, chomping on his dentures -------> :wheelchair:
Quote from: bpd1151 on August 29, 2013, 07:30:18 PM
$2200.00 for either +1 or +2, Garrett turbo upgrades, flow like a GT20 on the big one.
The stuff I put up is all the tech info available right now, these guys are going to be the BEST turbo upgrade available and at that price much better than just a compressor wheel upgrade!
Whole lot of behind the scenes wheeling and dealing being done, but looks like I'll be in the turbo upgrade game sooner, rather than later!
:spiteful:
:yell:
I don't have no dentures... NO TEETH PERIOD... But I did have to change my diaper twice!
No teeth = more room to warm those nuts.
Haha
Sent from my DROID3 using Tapatalk 6
anxious to see what else will be required to run these turbos (injectors/fuel pump/etc)
The key word is "safely". Since it appears there are no larger DI injectors or larger DI pumps that fit these engines that are currently available, one is going to have to depend on external fuel options at some point. That means going to a system like 4DRHTRD or 100% methanol injection. Or we can all wait for aftermarket DI injectors and DI pumps.
Not true Bob, I have tested my dual in tank fuel pump to be able to run 50/50 E85 mix on the stock DI setup with the upgraded in tank fuel pump at around 450HP. If you were to run E10 91 or 93 the fuel system should support over 500HP with just the in tank fuel pump upgrade. I'm also working on a possible Ford fuel pump upgrade from another vehicle to see if that can match the results. Either way we have enough power with the stock system and an upgraded fuel pump to be able to support plenty of HP, add meth on top of that and 600HP should be easily attainable.
I guess I am passing out phony 4 year old info again....
So... what you are seeing is that our DI Injectors and the DI pump are not the issue?
I did see FRP gains with my KB Boost a Pump so understand why the Dual Fuel pump setup would help, but was under the impression that the DI FP was still a bottleneck. With the KB BAP 50% voltage boost to the stock in tank fuel pump, I still saw my FRP drop to below 1,000 PSI a couple times at the high end of 2nd gear, which concerned me. Lambda also fluttered for a split second at those low FRP's.
Are you looking at the Shelby 500 pump? believe it is a Dual pump. How about modding some of the GM pumps like the one in the ZL-1 or CTS-V?
I am saying that as of 2 weeks ago the DI pump and fuel injectors are not an issue for around 500WHP or possibly more of 91 or 93 gas from my tests without falloff of the DI pump pressure.
After I put in the dual ITFP setup I saw 2200psi on the stock fuel system at WOT with no lean issues using stock pump and injectors, the aux fuel injectors were unplugged. This option will be expensive however as the dual ITFP itself is around $780.00 + around $200 in fittings and a $300.00 fuel pressure regulator + it's a bear to install.
I'm looking at the stock F150 5.0L ITFP as it's rated for 360HP on E85 over 500HP on E10 gas. Lots of guys running new trucks and mustangs at around 600HP on stock pump. If we can get the lift pump to keep up pressure to the DI pump we should be there. This should be a plug and play pump with no wiring changes, you could add a BAP on top of that if you wanted.
Vishnu on the BMW side has installed an inline fuel pump in the tank that let's them see 700HP on the stock DI system. I'm taking to the people that make their pumps to check out our platform as of this morning.
I'm trying to get the fuel upgrade side around $600 to $900 to support the 600WHP of the turbos without meth, you can add meth as desired after that.
But yes as of 2 weeks ago your information is now dated, sorry man, I'm staying on top of the platform and doing more and more tests as time goes on.
How about the pump in the Raptor engine package? Didn't you install a larger fuel line also? Is your system still return-less? Am I dreaming that you used stock line as return line and added a new larger line?
At least we have access panels to our fuel system under middle/back seat. In G8's you have to drop the tank or cut access panels.
Quote from: EcoBrick Bob on August 30, 2013, 01:12:39 PM
No reason to look at Raptor engine, the 5.0L guys are putting superchargers on and hitting 600HP on stock factory fuel pump that support E85 out of the box.
The fuel system that I'm trying to get to will use the factory fuel line which is 3/8" and should support the 600HP requirements at the pressure we're running.
I installed a new -6 line to the front with a FPR under the hood and used the factory line for a return line. I also ran two new power lines from the fuel pumps to relays under the hood and used the factory power line as a trigger for the relays.
I'm working on a way to just use the factory line and at most run a new power wire and hook up relays. I really would like to be able to offer a really easy fuel pump upgrade that requires just swapping pumps though.
We'll see how my work pans out though. :)
BTW, DI pump upgrade later would only boost the factory fuel system capabilities with a new ITFP setup.
The G8 guys have found big price differentials on various Stock GM pumps. The Camaro ZL 1 pump is like under $400. whereas the CTS-V pump is twice as much.
It would be nice to have a plug and play system that adds fuel as you say. Probably worth the money as a safety point, even if one wouldn't go to larger turbos or stronger engine internals.
That's why I am so interested in the G8 stuff, as I don't want to run out of fuel, even with my N/A G8 system. Would be nice to take advantage of E 85 also in both vehicles, at least in IA where it's plentiful and relatively cheap!
4DR....
Any plans of your own for these turbos to make their way onto your Flex?
Quote from: bpd1151 on August 30, 2013, 04:13:32 PM
4DR....
I get the first set of +2's to come out besides their test vehicle. :)
I wonder who'll be #3?
:hmmm:
I'm waiting on input from LMS; they're doing my turbos--I'm not half chopping that crap here without a tuner handy who can throw it on dyno and properly tune it.
Quote from: geswek on August 30, 2013, 04:24:59 PM
If they can tune for Tials with a compressor wheel upgrade and a stock WGA there's no reason they shouldn't be able to tune for an actual turbo upgrade with equalized compressor and exhaust wheel upgrades. But you choose your path Storm! :)
Price on ATP site is a place holder, I'm being told around $2500 list price for the upgrade. The second I have pricing I'll post up!
Twin turbo upgrade, direct bolt-on stock location. +2 size Garrett flows 200-250HP more than stock turbos. Remachined stock end housings. All new CHRA (Center Housing Rotating Assembly). Core change required.
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-SHO-001_550-1.jpg)
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-SHO-001_550-2.jpg)
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-SHO-001_550-3.jpg)
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-SHO-001_550-4.jpg)
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-SHO-001_550-5.jpg)
I should have pricing today but here's the info!
The pricing on ATP's site is a place holder, I'm being told around $900 list. I'll be putting up a group buy the second I have official pricing.
Front mounted intercooler upgrade. Direct replacement stock location unit. Garrett high density cores. Supports 800HP.
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-F150-001_550-1.jpg)
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-F150-001_550-2.jpg)
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/ATP-F150-001_550-3.jpg)
(http://www.atpturbo.com/mm5/graphics/00000001/Catalog%20Images/Vehicle%20Specific/DYNO-ATP-F150-001_1.gif)
What is the labor time involved to change both turbos?
Quote from: SRT82ECOBOOST on September 16, 2013, 12:29:42 PM
Depends on how good your tech is but mine were done in 12 hours
Sent from my HTC6435LVW using Tapatalk 4
I'm in love with the intercooler.
I'm in love with the upgraded turbos...... (we need a love/heart emoticon thing so I can enter that here)......
I am looking forward to the arrival of my set, and those pics 4DR posted are mos def eye candy / eye porn.
I know what i'll be fap'n to tonight :smoke:
Oooooooooo mmmmmmmyyyyyyyy I'm with bpd so dont interrupt me when im cleaning my room :yeah:
Ahh can't wait to hear official pricing on that pretty intercooler.
Sent from my SCH-I535 using Tapatalk 2
(http://img.tapatalk.com/d/13/09/17/unaduneg.jpg)
Quote from: TuxedoSHO on September 17, 2013, 08:35:48 AM
No lie!!
Hahaha
