Started by POPSTAGE2, May 22, 2014, 09:05:58 AM
Quote from: JimiJak on May 22, 2014, 11:50:18 AMDid you put the new o ring inside or outside of the CSS?Originally it was on the inside, but after installing mine on the outside between the bottom of the can and the plastic base, it hasn't leaked a drop.
Quote from: POPSTAGE2 on May 22, 2014, 12:18:20 PMQuote from: JimiJak on May 22, 2014, 11:50:18 AMDid you put the new o ring inside or outside of the CSS?Originally it was on the inside, but after installing mine on the outside between the bottom of the can and the plastic base, it hasn't leaked a drop.Installed it like how it was originally... on the inside. So, need to pry the top and bottom apart to install it your way?Thanks!Guy
