October 15, 2019, 10:21:11 PM
Author Topic: Hotpipes, Meth Bungs and Nozzles  (Read 1420 times)
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
Re: Hotpipes, Meth Bungs and Nozzles
« Reply #30 on: June 17, 2019, 04:48:23 AM »
I'm looking and my dipstick looked funny, touched it and it fell off....thats a first
Thatís messed up the same exact thing happened to mine. I think it was only like $6 from ford
The handle on mine broke off after removing #5 spark plug! I used a sharp Tool pick in order to remove it safely without incident!
Simply poke and pull Up slowly. Z  :)
https://www.harborfreight.com/pick-and-hook-set-7-pc-69592.html
« Last Edit: June 17, 2019, 05:02:15 AM by ZSHO »
Offline 802SHO
  • : Essex Junction Vermont
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #31 on: June 18, 2019, 02:00:28 AM »
I better order a new one now.  Thanks Z!  I was thinking about trying to put a screw in it and lift it out but the picks might work better (safer)
2010 SHO non PP, GH upgraded turbos, GH upgraded IC, EPP Hot Pipes, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous 35 shot, Dicunzolo Gen2 torque mounts, SP542 .028, 160 T, Airaid Intake, 3bar, Thunderstorm Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge, Tuned by AJP Turbo
Highest Trap Speed 123.22 mph
463awhp 569 awtq mustang dyno 6/13/19
11.526 @ 118.50 NED 10/5/19 full interior +75 shot
11.391 @ 123.22 NED 10/5/19 Driver seat +75 Shot
Offline shoNoff
  • : NH
  • -Given: 199
  • -Received: 602
  • Shomu the killer whale
« Reply #32 on: June 18, 2019, 07:11:45 AM »
I got lucky mine still had just enough sticking out so I could grab it with needle nose.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Offline 802SHO
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #33 on: June 20, 2019, 10:17:42 AM »
Update on upgrading to a dual nozzle setup.  If you already have a single nozzle and are tuned for it(me) upgrading to dual nozzles doesn't do anything except throw off everything you're tuned for.  I'm tuned with an M15 nozzle.  If I back off to less I'll need a retune(s) or do more I'll need a retune(s) so basically if your tuner is happy with your meth spray/volume and pressure upgrading will only complicate things and is unnecessary....unless you just want some under the hood eye candy of two nozzles(me) then you'll need to change your nozzles.  I have the Alky system so for me bc I'm tuned for an M15 nozzle I picked up an M5 and M10.  So I'll have two nozzles but will spray the same so my tune is not affected.  I already purchased my dual upgrade so I might as well install it.
Now some may need more volume...per tuner request and you could upgrade to two nozzles or just upgrade your single nozzle.
Big difference though if you're looking to get direct port...in which case I would assume you would want very small nozzles as you would have 6 at least...so you won't spray more than a single but you'll get perfect distribution like ZSHO has on that cute redhead!
And unless you want to mil the meth bungs down don't even bother.  Just drill your own unless you have nozzles with a ton of threads like the SNOW nozzles.
FYI if you already have Alky nozzles and just want to swap them out you don't need to buy the hole nozzle assembly with the 90 degree fitting you can just buy the nozzle tips and washers for 15.99 each.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
« Reply #34 on: June 24, 2019, 03:19:04 PM »
I believe the Dual nozzle kit should have a check valve corresponding with the 90 deg elbow and nozzle. Z
« Last Edit: June 24, 2019, 03:20:50 PM by ZSHO »
Offline 802SHO
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #35 on: June 25, 2019, 02:38:42 AM »
The dual nozzle kit does not come with a high pressure check valve.  The HP check valves are still accessory items to be purchased separately.  I added them to my cart.
My nozzles tips just came in along with another check valve.  I believe it's 11/32 drill bit I will need and I can get these lovely nozzles and check valves assembled and installed!
* Featured Topics
* Recent Topics
by Gofspar | Today at 08:56:02 PM
Also it's extra bad if I go around a corner and apply some heavy ...
Re: Meth and bank imbalance?
by bamsho | Today at 06:17:18 PM
My single port Alky Controls with M15 nozzle, both banks on my '1...
Re: Help with codes
by ZSHO | Today at 06:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosi...
Re: Newbie first time in a Ford!
by SHOdded | Today at 12:26:34 AM
Anti-spam measures.  We get hit hard and often LOL.  Should ...
Re: Splitter
by 802SHO | October 14, 2019, 02:23:41 PM
Dropped the splitters off for corner rounding.  Should have them ...
Re: Rear upper control arms?
by SHOdded | October 13, 2019, 02:16:52 PM
What year is your Flex?  I am including the procedure for a 2011,...
Re: New PB 11.8947 Gearhead E30
by 802SHO | October 13, 2019, 08:36:08 AM
Congrats man and welcome to the 11's buddy!...
Re: Snow Pics!
by Gjkrisa | October 12, 2019, 11:56:20 PM
Here's a neat picture of the ice on her in the woods https://uplo...
Re: Boost leak help
by ZSHO | October 12, 2019, 12:04:22 PM
The wastegates should be in the closed position AFAIK! In your case it...
Re: PPE Updated Downpipes
by 76fomoco | October 11, 2019, 08:11:46 PM
I too would like to delete the 3rd cat so post back with your DP'...
Re: End of an era!
by 76fomoco | October 11, 2019, 08:05:10 PM
man I would love to by this hood!...
by 76fomoco | October 11, 2019, 08:01:20 PM
KEEPEM COMING!...
Re: Check engine flashing, fuel smell, limp mode, and now no start
by StinkinLinkin13 | October 11, 2019, 02:27:04 PM
Awesome. Congratulations and great job! 🍻...
Re: 2014 pp driveline in 2010 sho questions.
by Spyder3000gtvr4 | October 11, 2019, 10:00:01 AM
Havenít had time to look at the car again will try this weekend. Will ...
Re: Throttle body size for Taurus SHO?
by ddlopes | October 11, 2019, 09:11:49 AM
Looks like the BBK may need to be modded to work properly... according...
Back to top
