October 15, 2019, 09:36:55 PM
Author Topic: Hotpipes, Meth Bungs and Nozzles  (Read 1419 times)
Offline 802SHO
  • : Essex Junction Vermont
  • -Given: 1603
  • -Received: 781
  • Boosted
Re: Hotpipes, Meth Bungs and Nozzles
« Reply #15 on: June 15, 2019, 07:51:02 AM »
look at my picture again you will have to account for the hose and clamp.
fyi I started with the m15 nozzle and ajp had me move down to the m5 as it was spraying way too much. but it was a lms tune I started with.
not a perfect conversion but
m5= about 500 ml/min
Ok that explains him saying it was spraying a $*it ton.  Maybe I should downgrade to an M5 since I'll have two but he said he was finally happy with it and here I go adding more nozzles.
On the fence if I should add another nozzle since I don't need it one bit, at least not in the same location.
2010 SHO non PP, GH upgraded turbos, GH upgraded IC, EPP Hot Pipes, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous 35 shot, Dicunzolo Gen2 torque mounts, SP542 .028, 160 T, Airaid Intake, 3bar, Thunderstorm Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge, Tuned by AJP Turbo
Highest Trap Speed 123.22 mph
463awhp 569 awtq mustang dyno 6/13/19
11.526 @ 118.50 NED 10/5/19 full interior +75 shot
11.391 @ 123.22 NED 10/5/19 Driver seat +75 Shot
Offline 802SHO
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #16 on: June 15, 2019, 07:52:32 AM »
I'm looking and my dipstick looked funny, touched it and it fell off....thats a first
Offline 5ohSHO
  • Full Member
  • : Fort Worth, TX
  • -Given: 39
  • -Received: 111
« Reply #17 on: June 15, 2019, 07:56:31 AM »
It's not broken it's just broke-in.
Offline 76fomoco
  • Full Member
  • : Nampa, ID
  • -Given: 59
  • -Received: 114
« Reply #18 on: June 15, 2019, 07:57:02 AM »
Ya Brad made 50 more HP then LMS on 2/3's less meth. LMS M15 nozzle.
2013 PP AJP multi tunes, 160 TS plugs, 3 bar, LMS catch can, EPP catted DP's, bridgestone potenza s007a
Best 5-25-19  12.51 @ 111.38 at 3350 DA
93+ meth 413 whp and 473 wtq 58* and 4020 DA on a mustang dyno
E30 415 WHP and 468 WTQ 70* and 3700 DA on a mustang dyno
Offline 802SHO
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #19 on: June 15, 2019, 08:08:45 AM »
Brad destroyed my Livernois Meth tune.  It was only 12 psi.  His base 93 3 bar 14 psi tune with no meth killed it.  Brad is very good!
« Last Edit: June 15, 2019, 08:19:35 AM by 802SHO »
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
« Last Edit: June 15, 2019, 09:34:53 AM by ZSHO »
Offline 802SHO
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #21 on: June 15, 2019, 10:28:46 AM »
1/8"NPT Bung correct! Don't want to spray to much cause sometimes less is more! Z
https://prometh.com/collections/nozzle-holders/products/npt-straight-nozzle-holder-with-4an-elbow-fitting?variant=18925484965957
https://prometh.com/collections/nozzles
Yes 1/8 NPT.  It's just the Alky nozzles are not long enough to thread into the bung enough.
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
« Reply #22 on: June 15, 2019, 11:51:01 AM »
Shoot Julio an email @ www.Alkycontrols.com ! He can certainly provide you with some insight on what the best alternative. Z
Julio Don • idoxlr8_70@yahoo.com
« Last Edit: June 15, 2019, 01:18:28 PM by ZSHO »
Offline 76fomoco
  • Full Member
  • : Nampa, ID
  • -Given: 59
  • -Received: 114
« Reply #23 on: June 15, 2019, 07:06:10 PM »
so the problem is the snow aka the rest of the meth guys use a different nozzle than alky controls does, Not only in the way it is threaded (all 1/8 npt with 24p) but also in the flow rating. the alky kit is by far the better kit but didn't keep flow relations in perspective (literately) with the rest of the performance world. And yes Julio knows the relation to flow of his to the others but will not give it to you. The snow or others are ML/pm and the alky is GPh
these guys cover the conversion rates
Offline 802SHO
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #24 on: June 15, 2019, 07:43:47 PM »
I did ask Julio about this, I want to say he had been drinking as he seemed in a really good mood but maybe that's just him...he didn't care for the bungs, he said the nozzles don't sit in far enough and I'm better off to drill my own holes plus it's cheaper.
I think I'm going to install my Hotpipes except the IC to TB and order to M5 nozzles from Alky and drill my own.  And plug the bungs.  I'm not a huge fan of the two bungs especially since they are literally right next to each other.  They should be spread out.  But the pipes look great and I love the bare aluminum look!
Offline 76fomoco
  • Full Member
  • : Nampa, ID
  • -Given: 59
  • -Received: 114
« Reply #25 on: June 15, 2019, 07:52:16 PM »
Mike at EPP should ask if your going ALKY or snow for the bung. He has been down this road many of time for sure!
Offline 802SHO
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #26 on: June 15, 2019, 07:55:39 PM »
I agree.  It's only asked if I want 1/8 or 1/4 NPT.  No mention of the bung depth which really is after getting them...crucial for nozzle brand.  Overall still pleased but I'll have two plugged meth bungs.  Silly.
Offline 76fomoco
  • Full Member
  • : Nampa, ID
  • -Given: 59
  • -Received: 114
« Reply #27 on: June 15, 2019, 08:42:11 PM »
That you paid extra to have installed and have to pay to plug. I'm in the same boat. so no poking fun.
for guys going forward do not get the bung and just drill your own hole if your using the alky kit!
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • : New York SHO
  • -Given: 1682
  • -Received: 3640
« Reply #28 on: June 16, 2019, 03:20:07 AM »
The bungs seem to close for comfort like a pair of boobs IMO! Shoot Mike an email on your issue! Mike is a good guy. Z  :)
Perhaps bpd1151 Alky dual nozzle setup! Z
https://www.ecoboostperformanceforum.com/index.php/topic,524.0.html
« Last Edit: June 16, 2019, 04:02:01 AM by ZSHO »
Offline shoNoff
  • : NH
  • -Given: 199
  • -Received: 602
  • Shomu the killer whale
« Reply #29 on: June 16, 2019, 06:51:55 AM »
That’s messed up the same exact thing happened to mine. I think it was only like $6 from ford
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
* Featured Topics
* Recent Topics
by Gofspar | Today at 08:56:02 PM
Also it's extra bad if I go around a corner and apply some heavy ...
Re: Meth and bank imbalance?
by bamsho | Today at 06:17:18 PM
My single port Alky Controls with M15 nozzle, both banks on my '1...
Re: Help with codes
by ZSHO | Today at 06:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosi...
Re: Newbie first time in a Ford!
by SHOdded | Today at 12:26:34 AM
Anti-spam measures.  We get hit hard and often LOL.  Should ...
Re: Splitter
by 802SHO | October 14, 2019, 02:23:41 PM
Dropped the splitters off for corner rounding.  Should have them ...
Re: Rear upper control arms?
by SHOdded | October 13, 2019, 02:16:52 PM
What year is your Flex?  I am including the procedure for a 2011,...
Re: New PB 11.8947 Gearhead E30
by 802SHO | October 13, 2019, 08:36:08 AM
Congrats man and welcome to the 11's buddy!...
Re: Snow Pics!
by Gjkrisa | October 12, 2019, 11:56:20 PM
Here's a neat picture of the ice on her in the woods https://uplo...
Re: Boost leak help
by ZSHO | October 12, 2019, 12:04:22 PM
The wastegates should be in the closed position AFAIK! In your case it...
Re: PPE Updated Downpipes
by 76fomoco | October 11, 2019, 08:11:46 PM
I too would like to delete the 3rd cat so post back with your DP'...
Re: End of an era!
by 76fomoco | October 11, 2019, 08:05:10 PM
man I would love to by this hood!...
by 76fomoco | October 11, 2019, 08:01:20 PM
KEEPEM COMING!...
Re: Check engine flashing, fuel smell, limp mode, and now no start
by StinkinLinkin13 | October 11, 2019, 02:27:04 PM
Awesome. Congratulations and great job! 🍻...
Re: 2014 pp driveline in 2010 sho questions.
by Spyder3000gtvr4 | October 11, 2019, 10:00:01 AM
Haven’t had time to look at the car again will try this weekend. Will ...
Re: Throttle body size for Taurus SHO?
by ddlopes | October 11, 2019, 09:11:49 AM
Looks like the BBK may need to be modded to work properly... according...
Back to top
