PTU Starting to Fail
Started by polskifacet, June 06, 2019, 11:41:00 AM
polskifacet
Hey Guys,
Pics of the PTU. Look like crappy manufacturing to me, shaft wasn't hardened well. Gears look really good after 100k miles 50k of those tuned. Shows changing the oil is really worth it. Minimal sludge , pics taken after cleaning with mineral spirits.
Gray Brick
What are the signs of failure?
2013 Ecoboost Ford Flex
TopherSho
Quote from: Gray Brick on June 06, 2019, 01:08:20 PM
my guess based on missing hunks of shaft metal ... it was leaking around the shaft.
Best 0-60 public road 4.35s
Yeah maybe wobbly shaft.  First instance I have seen visually OR reported.  Usually it is gears or bearings.
TopherSho
Quote from: SHOdded on June 06, 2019, 01:27:18 PM
Or lots if large chunk of metal in and outside a carwash ;)  thats how mine went.  with a huge smelly mess :D
polskifacet
the shaft with the damage is the one the middle gear spins on. No leaking but sounded like a supercharger when I floored it. It would live quite a bit longer if I kept changing the oil but who knows how long and where it would break hence why I changed it.
SM105K
Quote from: polskifacet on June 06, 2019, 02:01:11 PM
Did it happen to sound like this?
https://www.youtube.com/watch?v=AFoPXKFz_Mw
polskifacet
Quote from: SM105K on June 06, 2019, 02:13:44 PM
No it was only when I floored it and was much more high pitched.
SM105K
Interesting, thank you sir.
Gjkrisa
How hard is it to change the ptu? What is the process?
polskifacet
Quote from: Gjkrisa on June 06, 2019, 03:48:51 PM
Remove downpipes and unbolt steering rack (let it hang) , unbolt ptu.
