“AWD off” message on long drive
Started by jus2quik, May 28, 2019, 09:01:09 AM
jus2quik
Well come to find out the service advisor was lying the whole time, he never asked the manager about swapping the tires for new sho wheels and tires or the extended test drive,talked to her and she is making it happen ,dropped her back off and waiting to  hear the results. Took the car on a 4 hour drive and the message won't come on unless you are at a sustained uninterrupted 75-80mph run at around the 55-60 mile mark . Hopefully a new set of tires will solve this issue .
Basic beginner mods :GH tune,3Bar MAP,colder plugs,Drop in filter,160 Tstat
That would be infuriating, but cool.  Tires are easily replaced.  As long as the powertrain stays intact, all is well.
jus2quik
So basically Ford literature I've seen about the awd system not being finicky about tire size differences is a bunch of BS
If the tires prove out then yes it would seem.  Or maybe the not finicky is at road legal speeds?  IDK about the limitations.
jus2quik
AWD off message only comes on after 50-60 miles at 80mph so maybe over that much time and speed it's possible
TopherSho
I'm not aware of the RDU being "load sensitive". But it cleraly is a logic issue with triggering the fault at higher speeds.
Any chance the RDU was replaced at any point?
Best 0-60 public road 4.35s
jus2quik
When I was under the car it did look like I saw tool marks on the RDU leading me to believe it has been out or replaced before .After I got the car from the dealership and to.d them 8 was going somewhere else the manager talked me into coming back in,she drove the car with a new set of tires and it never faulted,they put my tires back on and no message again,I insisted you had to be going 75-80 consistently for atleast 60 miles like on a road trip. After badgering They finally installed a brand new RDU , I've yet to road test it again but will this week hopefully .
Hopefully got this thing handled now.
802SHO
I second that and wish you smooth sailing!
avidmotion
keep us updated....when i had 2 summers on the front 2 all season on back i could not tell unless hard braking in a turn, the traction control light would come on until after the turn.....only issue i could notice(both summers n all season were brand new and same stock size)....
jus2quik
Well dealer  ship installed new RDU ,went on a trip and about 45 minutes from the house ,"AWD message" came on again. Not sure what's going on .some say maybe a wheel speed sensor,but no codes indicating. Comes on after a brisk 80 or so mph cruise.Doesnt seem to happen if I stay below 70 but I can't seem to do that for long with cars passing me on the interstate.
jus2quik
Things I haven't tried yet:
Driving under 70
Put back to stock programming
Buy new tires - maybe with launching and spinning the fronts are now smaller than the rear and after a long high speed cruise it heats something up or throws a signal off
Tires are untested, the AWD module is untested.  Probably easier to check the AWD module for poor connectivity, may be a burnt pin or something like that causing the whole issue.  Should be behind the right hand side cowl trim panel.
I am sure the dealer updated the RDU/ATC barcode in the AWD module also, but worth a check.
NOTE:
DTC P1635 (Tire/Axle Out of Acceptable Range) — When the 4X4 control module detects an inappropriate size mini spare or road wheels/tires (greater than 7% difference in size across the front and rear axle or greater than 14% difference in size at one wheel on either the front or rear axle) installed, this DTC will be set.
Visual Inspection Chart
Mechanical
Active Torque Coupling (ATC) solenoid (part of rear axle)
Power Transfer Unit (PTU)
Rear Drive Unit (RDU)
Halfshafts and CV joints
Driveshaft and U-joints
Fluid leaks
Wheel/tire size and brand
Matching tire size and brand
Tire pressure
Electrical
Smart Junction Box (SJB) fuse(s):
11 (10A)
35 (10A)
4X4 control module
Wiring harness
Connector(s)
Circuitry
Pinpoint Test A: All-Wheel Drive (AWD) System Functional Test
Normal Operation
The All-Wheel Drive (AWD) system continuously monitors vehicle conditions and automatically adjusts the torque distribution between the front and rear wheels. During normal operation, most of the torque is delivered to the front wheels. If wheel slip between the front and rear wheels is detected, or if the vehicle is under heavy acceleration, the AWD system increases torque to the rear wheels to prevent or control wheel slip. When the AWD system is functioning properly, there should be no perceived speed difference between the front and rear axles when launching or driving the vehicle on any uniform surface. Traction should be similar to a part time Four-Wheel Drive (4WD) system in 4H (4X4 HIGH), but have no binding in turns.
This pinpoint test is intended to diagnose the following:
AWD system concern without on-demand or continuous DTCs
PINPOINT TEST A: AWD SYSTEM FUNCTIONAL TEST
WARNING: When directed to drive the vehicle as part of this test, drive the vehicle on a hard surface in an area without traffic to prevent a crash. Failure to follow these instructions may result in personal injury.
NOTE: Carry out a thorough inspection and verification as outlined before carrying out this pinpoint test. Refer to Inspection and Verification in this section.
Test Step  Result / Action to Take
  A1 CHECK FOR ATC SOLENOID (PART OF REAR AXLE) LOCK
Drive the vehicle on a dry, hard surface in turns while applying the accelerator pedal.
Is driveline wind-up present in turns?
Yes
With the ignition ON, allow the ATC solenoid to cool down for at least 10 minutes and repeat the test. CHECK for wind-up again. If no wind-up is found, GO to A3 . If still present, GO to Pinpoint Test E .
No
GO to A2 .
A2 CHECK FOR VALID ACCELERATOR PEDAL POSITION MONITORING THE ACCELERATOR PEDAL POSITION (AP) PID
Enter the following diagnostic mode on the scan tool: DataLogger — 4X4 Control Module.
Monitor the AP PID while pressing the accelerator pedal.
Does the accelerator pedal position match the AP PID percent value?
Yes
GO to A3 .
No
REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual to diagnose the accelerator pedal position sensor concern.
A3 CHECK 4X4 CONTROL MODULE WHEEL SPEED SENSOR PIDs
While driving the vehicle at 48 km/h (30 mph), monitor the following wheel speed sensor PIDs:
Left Front Wheel Speed Sensor (LF_WSPD)
Left Rear Wheel Speed Sensor (LR_WSPD)
Right Front Wheel Speed Sensor (RF_WSPD)
Right Rear Wheel Speed Sensor (RR_WSPD)
Are all 4 wheel speeds within 2 km/h (1.2 mph) of each other?
Yes
GO to A4 .
No
GO to Pinpoint Test F .
A4 CHECK VEHICLE ACCELERATION IN A STRAIGHT LINE
Carry out 3 accelerations from 0-48 km/h (0-30 mph) in a straight line (1 each with low, medium and full accelerator pedal application).
Does the vehicle pulsate or shudder while accelerating?
Yes
No
GO to A5 .
A5 CHECK VEHICLE TURNING ABILITY
Drive the vehicle in a fully locked turn, on dry pavement, at 8 km/h (5 mph).
Does the vehicle bind in the turn or resist turning?
Yes
No
GO to A6 .
A6 CHECK FOR TORQUE AT REAR WHEELS USING OUTPUT CONTROL COMMAND #1 (CLCH_SOL) ACTIVE COMMAND
Using the scan tool, command CLCH_SOL to energize the ATC solenoid to a constant 100% applied.
Yes
END the active command. The concern cannot be duplicated at this time. RETURN the vehicle to the customer.
No
END the active command. CHECK that the driveshaft rotates when the transaxle is in gear. If yes, GO to Pinpoint Test D . If no, CHECK the Power Transfer Unit (PTU). REFER to Section 308-07B .
I'm curious and highly doubt you can duplicate your issue in stock tune!!!
Hmm interesting your able to spin the front tires!!
Check for any Bent Wheels which will throw off the AWD traction system. Z
Need To Move To a State with a 50 mph speed limit!  :D
