October 15, 2019, 10:11:37 PM
Author Topic: AWD off message on long drive  (Read 3044 times)
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11865
  • -Received: 3893
Re: AWD off message on long drive
« Reply #15 on: May 28, 2019, 03:56:39 PM »
Let's move on :)  I think we all understand each other now ...
Offline shoNoff
  • Elite Member
  • : NH
  • Thank You
  • -Given: 199
  • -Received: 602
  • Shomu the killer whale
« Reply #16 on: May 28, 2019, 03:58:17 PM »
Who have I talked down to?
Youve redeemed yourself since your original post. All is good man its water under the bridge at this point. Lets move on, fix your ride and put a smile on your face with that gh tune.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1682
  • -Received: 3640
« Reply #17 on: May 28, 2019, 04:20:02 PM »
To the OP! Did you happen to check for Codes! Never received a response! PICS to share! Z
Offline jus2quik
  • Jr. Member
  • : Jacksonville,Florida
  • Thank You
  • -Given: 1
  • -Received: 13
  • Total newbie
« Reply #18 on: May 28, 2019, 04:20:16 PM »
Just ran out and snatched the tire off,she took 8 more oz before started weeping out, thanks all and again sorry ,Ill try to behave
Basic beginner mods :GH tune,3Bar MAP,colder plugs,Drop in filter,160 Tstat
Offline jus2quik
  • Jr. Member
  • Thank You
  • -Given: 1
  • -Received: 13
  • Total newbie
« Reply #19 on: May 28, 2019, 04:22:00 PM »
Sorry buddy, I did immed. Check for codes and nothing was there. I wish my wife would have told me sooner but her being 5 hours away from home I could not have done much and trying to talk someone through adding ptu fluid wasnt gonna happen,my family arent mecahnics,just farmers up that way.Thanks again !
Offline shoNoff
  • Elite Member
  • : NH
  • Thank You
  • -Given: 199
  • -Received: 602
« Reply #20 on: May 28, 2019, 04:22:41 PM »
Wow thats quite a bit. Hopefully this resolves the issue.
Offline jus2quik
  • Jr. Member
  • Thank You
  • -Given: 1
  • -Received: 13
  • Total newbie
« Reply #21 on: May 28, 2019, 04:30:34 PM »
I hope so ,we will see. Thanks again !
Offline ZSHO
  • Forum Supporter
  • RotM Winner
  • Elite Member
  • : New York SHO
  • Thank You
  • -Given: 1682
  • -Received: 3640
« Reply #22 on: May 28, 2019, 04:34:20 PM »
No worries! Glad you were able to find the FIll Hole! Best of luck.  Z
« Last Edit: May 28, 2019, 04:41:48 PM by ZSHO »
Offline jus2quik
  • Jr. Member
  • Thank You
  • -Given: 1
  • -Received: 13
  • Total newbie
« Reply #23 on: May 28, 2019, 04:43:56 PM »
Oh yeah Im good at it now ! Just got messed up with many folks saying just add what you take out ,then I read here somewhere to gently top it off but if there is not a heat sensor on the ptu then the awd off heat signal must have come from the RDU,right? I checked that fluid as well and it was good,I didnt change it but I did check it . All we have seen is that message a few times on one trip,never lost awd or had front only pulling that I can tell .
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11865
  • -Received: 3893
« Reply #24 on: May 28, 2019, 05:33:35 PM »
Yeah, it is triggered by some situation with control of the RDU, not usually by the PTU itself.  Since many people have PTUs that had been gunked down to basically solid gunk, and the AWD still worked fine, I am not sure that having only 10 oz in there was the cause of the AWD OFF message.  I think all should be well now tho.  As I said before, the ony other item you can check is the electrical integrity of the connection at the ATC.
Offline avidmotion
  • Sr. Member
  • Thank You
  • -Given: 2
  • -Received: 66
  • Ecobooster
« Reply #25 on: May 28, 2019, 07:06:40 PM »
Since you may have burned up some of the life in the fluid, I would do a full dump and put in Amsoil etc...I'd also d the pigtail so you can change ptu quick.
Offline SM105K
  • Elite Member
  • : Arizona
  • Thank You
  • -Given: 634
  • -Received: 767
  • Land Yacht Pilot
« Reply #26 on: May 29, 2019, 05:40:58 AM »
Social media is a real crapshoot.  Since messaging occurs rapidfire, a lot of folks leave their filters off.  Can get ugly real fast.
It happens on this forum on occassion, but thankfully our members keep it to a minimum :)
I don't know what you are talking about......
"M" 2013 SHO PP: AJPTurbo E30 Tune, GH Intercooler, PPE Downpipes, Dicunzolo Gen2 Trans Mounts, UPR Catch Can, K&N Drop In, H&R Springs, Power Stop Brakes, Curva Concept C7's.
"The Go Cart" 2013 Focus ST: AJPTurbo Flex Fuel Tune, Megan Racing Downpipe, Boomba BOV, and Short Shifter.
Offline SHOdded
  • Administrator
  • Elite Member
  • : Beltsville, MD
  • Thank You
  • -Given: 11865
  • -Received: 3893
« Reply #27 on: May 29, 2019, 06:41:37 AM »
 :play_ball:
Offline FiveLeeter918
  • Ortiz Performance - Technical Sales
  • Full Member
  • : Tulsa, OK
  • Thank You
  • -Given: 4
  • -Received: 96
  • Bewsted SHO
    • Ortiz Tuning and Performance
« Reply #28 on: May 29, 2019, 10:27:31 AM »
Fiveleeter,I sent you an apology for this morning ,didnt have my coffee yet!
All good man, it happens.
- Lee
Ortiz Performance Vendor Forum | Find us on Facebook! | Order a Tune!
Offline jus2quik
  • Jr. Member
  • Thank You
  • -Given: 1
  • -Received: 13
  • Total newbie
« Reply #29 on: June 02, 2019, 12:11:50 PM »
Checked rear rdu fluid and its clean and full,air pressure in all tires the same ,only thing 8 have found that is suspect is the rear tires are of a different brand than the front . Same size but thinking about how if the rear or front tires are of different real size after a few hours I could imagine the clutches could possibly heat up and cause the code,you guys think this is a possibility ? I believe the Rdu is the only component with a sensor correct ? Thanks fellas for the help !
* Featured Topics
* Recent Topics
by Gofspar | Today at 08:56:02 PM
Also it's extra bad if I go around a corner and apply some heavy ...
Re: Meth and bank imbalance?
by bamsho | Today at 06:17:18 PM
My single port Alky Controls with M15 nozzle, both banks on my '1...
Re: Help with codes
by ZSHO | Today at 06:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosi...
Re: Newbie first time in a Ford!
by SHOdded | Today at 12:26:34 AM
Anti-spam measures.  We get hit hard and often LOL.  Should ...
Re: Splitter
by 802SHO | October 14, 2019, 02:23:41 PM
Dropped the splitters off for corner rounding.  Should have them ...
Re: Rear upper control arms?
by SHOdded | October 13, 2019, 02:16:52 PM
What year is your Flex?  I am including the procedure for a 2011,...
Re: New PB 11.8947 Gearhead E30
by 802SHO | October 13, 2019, 08:36:08 AM
Congrats man and welcome to the 11's buddy!...
Re: Snow Pics!
by Gjkrisa | October 12, 2019, 11:56:20 PM
Here's a neat picture of the ice on her in the woods https://uplo...
Re: Boost leak help
by ZSHO | October 12, 2019, 12:04:22 PM
The wastegates should be in the closed position AFAIK! In your case it...
Re: PPE Updated Downpipes
by 76fomoco | October 11, 2019, 08:11:46 PM
I too would like to delete the 3rd cat so post back with your DP'...
Re: End of an era!
by 76fomoco | October 11, 2019, 08:05:10 PM
man I would love to by this hood!...
by 76fomoco | October 11, 2019, 08:01:20 PM
KEEPEM COMING!...
Re: Check engine flashing, fuel smell, limp mode, and now no start
by StinkinLinkin13 | October 11, 2019, 02:27:04 PM
Awesome. Congratulations and great job! 🍻...
Re: 2014 pp driveline in 2010 sho questions.
by Spyder3000gtvr4 | October 11, 2019, 10:00:01 AM
Havent had time to look at the car again will try this weekend. Will ...
Re: Throttle body size for Taurus SHO?
by ddlopes | October 11, 2019, 09:11:49 AM
Looks like the BBK may need to be modded to work properly... according...
Back to top
