February 24, 2021, 03:03:47 PM
Author Topic:  2.0 control pack discontinued  (Read 17617 times)
Offline aprilfools
  • Jr. Member
  • -Given: 3
  • -Received: 12
  • Liked:
  • Likes Given: 0
Re: 2.0 control pack discontinued
« Reply #30 on: September 24, 2019, 07:28:40 PM »
Knock on wood, I hope the reliability I've seen in the first 400 miles continues. Time will tell. I know haven't been easy on it, it's just to addicting to not let it spool!
I think the driveline on the other hand is another story. Again, time will tell.
I'll update as time goes on.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Offline Macgyver
  • Super Moderator
  • Reading, Pa.......
  • -Given: 100
  • -Received: 372
  • Liked:
  • Likes Given: 14
« Reply #31 on: September 24, 2019, 07:46:50 PM »
What is the power to weight ratio ?
Offline aprilfools
  • Jr. Member
  • -Given: 3
  • -Received: 12
  • Liked:
  • Likes Given: 0
« Reply #32 on: September 24, 2019, 09:14:12 PM »
Car total weight is around 1400-1500. With driver passenger and gear 1800ish. I plan to have the car weighed soon to get exact numbers as the next stage is suspension work so I need those numbers.
The horsepower on this I really have no idea due to the mixed parts. The 2.0 with the 2.0 control pack was advertised as 252. The 2.3 with the 2.3 control pack was advertised at 310. Not sure where my Frankenstein falls into this category. One of the issues I faced was my boost would fall off dramatically after 15psi then rebuild. I couldn't figure out why but you could watch the gauge and feel it. After some thought and listening while driving I came up with a theory on the wastegate. I put 2 turns on the wastegate spring and wahala, holds 18lbs of boost now consistently. 2.3 ecu boost output on a 2.0 wastegate was my only thought or theory for increasing the spring to hold more pressure as it seemed to "pop off" to soon.
So I really have no idea what the actual HP numbers are. I would like to eventually know but I'd say it would be more for my own curiosity than anything else.
Offline Macgyver
  • Super Moderator
  • -Given: 100
  • -Received: 372
  • Liked:
  • Likes Given: 14
« Reply #33 on: September 24, 2019, 10:10:05 PM »
That has got to be a rocket and the turbo surge must be impressive for what it is.
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13036
  • -Received: 4234
  • Liked:
  • Likes Given: 4
« Reply #34 on: September 25, 2019, 02:19:19 AM »
Serious eyecandy that walks the talk.  Very cool!
Offline aprilfools
  • Jr. Member
  • -Given: 3
  • -Received: 12
  • Liked:
  • Likes Given: 0
« Reply #35 on: September 25, 2019, 09:10:33 AM »
Thanks guys
That's one of the other surprising things in this package,  there is virtually no turbo lag and it builds boost insanely fast. Definitely a slight improvement over the ole air cooled VW that was previously in it!
Offline BEEFKING69
  • Newbie
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 0
« Reply #36 on: December 14, 2019, 11:54:24 PM »
Any updates on how this is holding out?
Offline aprilfools
  • Jr. Member
  • -Given: 3
  • -Received: 12
  • Liked:
  • Likes Given: 0
« Reply #37 on: December 30, 2019, 09:18:16 AM »
So far it has been excellent and have had no major issues. It is winter here now so its parked until spring. I have some projects planned for it this winter but it will be ready in the spring to run again.
I did fire it up 2 weeks ago, it hadn't ran in over a month and it was cold out. Hit the button and it rolled over about 4 times and set there idling. It was good to hear the turbo whistle,  cant wait until spring! I'll update more once spring hits and I get some more miles on it.
Happy new year!
Offline SHOdded
  • Forum Supporters
  • Beltsville, MD
  • -Given: 13036
  • -Received: 4234
  • Liked:
  • Likes Given: 4
« Reply #38 on: December 30, 2019, 09:19:40 AM »
Happy New Year!
Offline GeorgiaFlattie
  • Newbie
  • -Given: 0
  • -Received: 0
  • Liked:
  • Likes Given: 0
« Reply #39 on: October 29, 2020, 02:09:55 PM »
Happy new year!
Still running well with no major issues from using the 2.3 control pack on a 2.0 engine? Did you make any other changes other than adjusting the spring on the wastegate?
I'm considering swapping a 2.0 or 2.3 into a Willys. The 2.0 has plenty of power for my needs and is about $1000 cheaper than the 2.3 around here so being able to save some cash is always nice.
Offline aprilfools
  • Jr. Member
  • -Given: 3
  • -Received: 12
  • Liked:
  • Likes Given: 0
« Reply #40 on: October 29, 2020, 09:40:06 PM »
Happy new year!
Still going strong and has proven to be very reliable. I put an hour meter on this the day it fired and as of now it has 72 hours of run time using all these parts. May not seem like a lot but she gets ran pretty hard at times and driven for recreation.
I have pulled the stock wastegate actuator and put on a turbosmart wastegate. HUGE improvements over stock. Noticable improvements coming on boost quicker and holding it. This package builds boost quickly and I see 20lbs of boost on intial hit and it settles at 18lbs and holds it through the gears. I have a boost gauge and a tablet running off the obd2 port and both match. I can only assume the 2.3 brain is letting me see these boost numbers as the 2.0 I  believe is at 17 stock.
The tablet is mounted in the car and I am using Torque Pro on it with a bluetooth adapter. Works great, I can monitor the entire engine on the fly. I had an intake sensor that was broken and I didnt know it. It through a code and in 10 minutes I was able to diagnose it and replaced, problem solved. That definitely is worth having for trouble shooting and monitoring.
I have one thing I cannot figure out that I have had since day one and I have not been able to solve it and I have changed many things trying. It has not hurt runnability at all so I have learn to live with it as I have put on all these hours with it. I get a po88 code which is fuel rail pressure to high. The code indicator light is on but it starts, runs and drives perfectly. I can reset the code with torque fire it and it's off. Drive easy and it stays off. Roll into it building boost and it will come on, but again runs fine. I can watch the rail pressure and I can see it increase but not real sure where the limit is to trigger it. I am guessing again it has something to do with the programming for the 2.0 vs 2.3. I have changed all kinds of things in my return thinking it was there but nothing changed it. Its been awhile since I graphed it in torque to remember the numbers I get but I can do that next time I run it and report back what I see.
But overall I could not happier with this set up. I can Sunday cruise with this or let it eat and it puts a smile on your face. Very drivable to say the least. I wouldn't hesitate to do this again knowing what I know now. I was so lost when I started all this. Hopefully Ford hasn't figured this out and made some change that wont let a new pack fire one of these engines. You nailed it to, I see so many 2.0 engines for sale priced insanely cheap for this kind of swap and fun. I know where there is a complete engine for $550. Hard not to go get it for a spare! The are great engines in a nice small package.
Hope this helps.
* Recent Topics
by bpd1151 | Today at 12:22:55 PM
02/24/2021.......Engine builder LMK that internal trans parts have bee...
Re: Converting kPa to PSI?
by Admin | February 22, 2021, 08:08:20 PM
https://www.convertunits.com/from/kPa/to/PSIThis website is great, rem...
Re: Brew City Boost no longer to offer tuning.
by TopherSho | February 22, 2021, 05:33:20 PM
https://i.ibb.co/KX2kh6K/151216360-4400460773313803-79904878115635051...
Re: RockAuto Wants To Help With Your Upcoming Car Show
by Macgyver | February 19, 2021, 06:34:46 PM
Outstanding Idea !!!...
Re: 2020+ Explorer ST Parts and Tuning Now Available at Ortiz Performance!
by Macgyver | February 19, 2021, 06:33:36 PM
Are you planning or already have the Edge ST ?...
Re: HPTuners Updated Support for 2013-2018 Taurus SHOs
by BOT_ROCKET | February 19, 2021, 05:21:20 PM
No worries on the delay. I totally understand. It got pretty chilly he...
Re: So the tax lady was good to me
by FiveLeeter918 | February 19, 2021, 03:21:46 PM
Hey bud, luckily all of the MKS and SHO stuff is interchangeable. Let ...
Re: "Engine coolant temperature too high"
by ChrisxHowe | February 17, 2021, 01:42:47 PM
Sent from my iPhone using Tapatalk...
2011 Ford Taurus SHO $11,000 Orange Cnty, CA
by dinkydingo | February 16, 2021, 01:18:15 AM
For sale is a 2011 Ford Taurus SHOThe car has had some work done in or...
Re: 2017 Black Ford Edge Sport:
by FoMoCoSHO | February 15, 2021, 03:01:41 PM
unleashedtuning.com and Torrie McPhailIf you really want to go all out...
