Well....
You ain't gonna believe this until I post video, but...this will be lengthy so bare with me.
As I finally decided the 2.0 was a dead duck I yanked the engine through it on the shelf and have been doing other things to the car. As mentioned in previous posts I ordered a 2.3 control pack just so I knew I would have one when the time came and i figured I had already budgeted for it anyways so might as well get it.
So a few weeks ago this arrived and like a kid on Christmas morning I ripped open the box to go through the items. Alot of unneeded items, but very important ones needed as well. I closed it back up and it sat in garage a few days.
I then decided I might as well layout a few things to see how well things were gonna run where I needed them being I am putting this in basically bass-ackwards from how it should be in a car. Surprisingly I was able to lay it out in a way that reached everything and I only needed to extend the throttle pedal wires to reach where I had previously mounted that. I wired in everything I could, mounted the fuse box and then thought to myself, man to bad I don't have 2.3 engine.
A few more days go buy and curiosity gets the better of me even though everything I read and calls to Ford performance said it wouldn't work. I grabbed the engine harness that had taken off and checked it to the 2.3 kit connections, they all fit and plugged in. Hmmm.....So I reinstalled this to the engine and I proceeded to put the engine in and plug in everything. Fingers crossed I flipped on the switch and.....nothing.
Truth be told I was a chicken sh... so I used the PCM out of the donor car, not the expensive one from the 2.3 kit I purchased. After a few hours of 3 of us testing everything we could we gave up for the night. Next evening 2 of us were back at it and again no luck, no power to things that just should have had power to them. Again, we gave up for the night. All the while in the back of mind I knew this would not work so I was at the point of giving up.
Then tonight I decided to gamble and use the PCM from the 2.3 kit, up to this point I still hadn't done that afraid I could burn it up.
So we plugged it in, flipped the switch, still no fuel pump, dam. I then for the heck of it hit the key and bingo, she rolled over! New life, it hadn't done this before! After a few hours and discovering that I had missed 3 connections on the engine harness to the engine, I flipped the switch on, and still no fuel pump. But, something else in the engine cycled and made a sound. We all looked at each other with that look of, did you hear that?? I cycled the switch and we all heard it again. Again, the engine would roll over but I still did not have my fuel pump to feed the high pressure pump running. My dad finally says, for the heck of it run a wire from the battery ground over to your ground for the harness. So I did, then I flipped the switch and the fuel pump sang us a sweet harmony of fuel racing through my lines to the engine! I set the regulator to 55 pounds then hit the start button knowing there was no way the coils or the high pressure pump would run on this 2.3 PCM. Within mere seconds the engine fired!! It caught me by surprise and I immediately hit the kill switch not knowing what it would do. My dad says what the heck did you do that for?!? I could not believe it fired. I flipped the switch hit the button and it reignited in mere seconds again. It revved slightly then settled into a nice idle and just sat there and ran.
Wtf? Thought this wouldn't run this?? Don't get me wrong I'm excited as heck it did. I'm a long way from believing it will run as I hope but this is a great start. I still have to build my exhaust and button up the engine install and I'm sure there is alot of tuning the engine will need somehow by computer to be right. But starting and idling is a great start in my book.
Now I just to need to figure out the best way to tune this thing!!
Cobb?? I see they make a specific one for 2.0 and 2.3 swaps. Suggestions definitely welcome here.
I'll post a video of it if I can and can figure out how if anyone is interested in it seeing it.
Sent from my SAMSUNG-SM-G891A using Tapatalk
