802SHO 2010 Build
Started by 802SHO, April 30, 2019, 12:37:54 PM
SM105K
Yeah buddy.  Thank intercooler is flat out gold.  Cant wait see what your car is going to do.
Just glad to see new parts being developed, and proving out nicely in the field.  A big thumbs up to GearHead.
802SHO
Yes sir GearHead has done an amazing job with both the intercooler and turbos.  Its one thing to see a picture of the GH upgraded IC next to the stock IC but when you have them right in front of you, can see the difference, feel the difference......it really sinks in like....unbelievable!  No wonder our cars hear soak so much and easily....the stock IC is laughable at best!
Should have installed my torque mounts last night!  I forgot I had them lol
Pics of the new exhaust that is finally complete...doube x pipe 2.5" stainless turbos back!  Butttt looks like he saved a smidgen of the 3rd cat to save the flanges DOOHHH!!!!!
802SHO
Quite a bit louder he said 🤘😈YES!   One xpipe but two?  Plus the quad tips just magnify everything 😂 neighbors will hate me....MORE
shoNoff
Cars looks ridiculous without your chin spoiler lol. Coming along nicely buddy!
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Quote from: 802SHO on May 23, 2019, 11:49:18 AM
Got the new GH IC installed last night!  What a pain those lower radiator hose clamps....uuuuuuuggggghhhhhhh I get 😠 when I spend A LOT of time on little things like that!  Alky pump was very much in the way, thankfully I was slated to swap it out anyway as the original had to be dismounted.  Everything went fairly smooth minus those hose clips.  I changed the oil and went local so I got Royal Purple High Performance oil not the HPS and a K&N filter 2011.  Drained all the radiator fluid, well most of it and replaced with some valvoline 16.99 a gallon stuff.  It was rhe most expensive and said Ford so I went with that lol!  No flush this time around just new coolant and topped it off with Royal Purple ICE.  Jacked passenger side up and burped her 3+ times.  Didn't get my plugs changed over from SP534 to SP542 yet.  The 534's only have 3k on them so I will be fine in the interim.
First drive today since October 2018!  Dropped it off for exhaust work.  Looks goofy with no exhaust tips and front chin spoiler missing.
Boy was it nice to hear her purr and enjoy the ride to the shop.  Coolant temp hovering at 170-180 plenty of heat, no leaks, purged my new meth pump no issues, no leaks.  Starting off the year right.
Looking Good 802SHO! Keep it coming!  :thumb:  BTW Fixed the ^^^ PIC for ya. Z  :)
802SHO
#66
Picked up the car and boy does she sound hoggish!  No sound bites yet.
Dropped off to another shop awaiting turbo install.  AJP instructed me to detune back a bit bc of the increase in air flow to side with caution until we start the tuning process.  Back to 3bar, 93 octane 14 psi base tune.  Meth not necessary but I'll leave it activated as a precautionary measure.  Worst case I run slightly rich.
SM105K
Get a LiveWire homie, your life will change.
ridered74
Can't wait to see what it runs at the track!
Gearhead E30 tune, Gearhead intercooler, LMS firestorm hpfp, catted downpipes, corsa catback, 160 degree thermostat, 3 bar map, upgraded AD trans mounts, MSD coils, Nitto 555R drag tires on front, AR924 wheels and BFG sport comp 2 summer tires on rear, and an EPP intake.
12.2479 @ 118.05 fastest trap
11.591 @ 114.89   fastest ET
802SHO
Quote from: SM105K on May 24, 2019, 09:27:29 AM
Well I have the Interceptor scan gauge.  I can monitor just about everything too.  It plugs right into my OBD2 port.  Its basically the same except I can only display two at a time where you can display 6?  Correct me if I'm wrong.
shoNoff
Sm105k always pushing the livewire. Making me feel inadequate with my BDX.
SM105K
Quote from: 802SHO on May 24, 2019, 12:54:38 PM
You are wrong good buddy.  Any PID can be uploaded and I monitor 9 PID's in real time.  It displays mins and maxes for that key cycle, and I can set alarms for various things.  Coolant too hot?  Boom alarm sound.  Trans temp too hight?  Boom Alarm.....
SM105K
Quote from: shoNoff on May 24, 2019, 01:02:21 PM
The way I flog mine, I want to know everything that is going on in real time.
shoNoff
Quote from: SM105K on May 24, 2019, 01:30:14 PM
I do it like I do it at home. With my eyes closed pretending it's someone else doing it.
SM105K
Quote from: shoNoff on May 24, 2019, 02:49:06 PM
My man, you truly don't understand the gravity of the situation until you have sat on your hand for good 20 mins, then proceed.....
