802SHO 2010 Build
Started by 802SHO, April 30, 2019, 12:37:54 PM
No question, your SHO is looking sharp :thumb:
SM105K
Quote from: SHOdded on July 03, 2019, 06:34:33 AM
I concur.  SHARP AF!
802SHO
Welp I can't make it to my inspection appt today as I've spent the last 4 hours simply trying to get the rear driverside lateral arm bolt free.  After a trip to the store for more tools as I later found I did not need as the lateral arm bolt has a nut on the back side...almost like a washer and some sort of holder so it doesn't move....well mine moved.  I got the bolt loose but it just spins and behind I can see that stupid nut spinning.....i should be able to sawzall off the bolt and then just pull both ends of the bolt out correct?  Don't even ask you know I'm more than ready to stab someone over a !%!\!\÷/!/!\!/!\!!\!\!\!\!\!\×;,$_×&_!& bolt!  😠😤
SM105K
I haven't been there with this car, but I have been with other cars....I know that feeling.
802SHO
Quote from: SM105K on July 03, 2019, 11:23:47 AM
Its unbelievable lol!  25 min job tops.  Jack car up take wheel off pb blaster...wait few min.  Take lateral arm nut off the joint 17 min...then take the bolt....yeah lets put it on pause there for 4 hours
Beer guzzling break time.
802SHO
So ....cut the bolt with a sazall.....and yup the square nut thing has its on fancy place behind the most impossible area to reach ....fricken A...i tried for 4 hours to get that nut to stop spinning so I could back the bolt out...now that back piece is stuck in there?  What to do now?  Drill the living $hit out of it?
802SHO
Jordan
OUCH! Shoot man. I am not familiar with that section of the car. Wish I could help! RIP. If you have space to drill it looks like that might be the solution...
802SHO
Quote from: Jordan on July 03, 2019, 07:40:04 PM
Would need on very long drill bit to get it from the front.  If I remove the track bar I'll have more access.....although not much.  Thinking about notching a small area to gain access to it from the rear....then I could just grab it out.  Possibly come up with an alternative bolt and nut combo to reattach.  I'd be pleased to run a bolt through the backside and attach a nut on the front.....that would tickle my fancy among other things
Sorry for the late reply! Try to HEAT up one side in order to remove the link/bolt!
Can you p/up a new Link or try to remove ball-joint! Z
http://www.ecoboostperformanceforum.com/index.php/topic,7536.msg115013.html#msg115013
802SHO
#251
Derale trans cooler installed.  Simple.  Cool side condensor to inlet Derale, outlet into Aux Cooler, out let aux back to transmission.  Trans fluid will now be cooled 3 times, 1 factory, Derale 10000 series 16 row cooler to performance package trans cooler.  Can't wait to see what my temps will be at the track and in general.  At some point I will change to 90 degree fittings on top.  Or even upgrade to larger cooler.  Good for now.
Special thanks to BPD for inspiration from his build yet again!
SM105K
So when are you going build me a splitter?
802SHO
Quote from: SM105K on July 05, 2019, 07:43:24 AM
When I get done with mine....just need to finish the edges better and cover with black door edge trim.  Bought some at store that's 8ft long...I need like 8ft 4...crazy!  Near complete now minus the lateral link and alignment.
Jordan
That splitter looks insanely good. Also I need to get on that trans cooler life. When the trans temps get higher than cylinder head temps I get to worrying LOL... Good thing I do fluid changes often I guess..
