802SHO 2010 Build
Started by 802SHO, April 30, 2019, 12:37:54 PM
shaundizzle15
802 did you get a badge for front and rear or just front? I also love the look of their badges and have thought about it. The rear badge seems tricky with the camera housing. Keep us posted!
Hockey/Golf/Car geek, Beagle loving, and totally comfortable with it.
Tuxedo Black nonPP 2013 SHO traded in
Shadow Black nonPP 2016 SHO
VTA, and tuned by GH
Quote from: TopherSho on May 02, 2019, 01:57:48 PM
Right?  wth is all that money coming from :P   me and my hopefully 12.5 second car are starting to feel old and slow as crap ..
Quote from: SM105K on May 02, 2019, 02:29:14 PM
I am over here still trying to crack 400 awhp lol.
Sounds like we need to start a "No SHO Left Behind" support group for you guys :P
802SHO
I've been laying in wait muahahahaha
802SHO
Quote from: shaundizzle15 on May 02, 2019, 02:36:43 PM
Just rear I don't have a front badge in my custom grille and those badges also can be ordered for a camera....i was just telling ShoNoff that my SHO doesn't have a back up camera which is really weeeiirrddd
shaundizzle15
Thanks, and yes that is weird and unfortunate, pretty sure you can add one. How do you remove the rear badge ?
802SHO
I thought about adding one but I'd rather spend my money elsewhere.  The SHO would have been my first back up camera anyhow.  My stock one was glued on. Its not too hard to take that rear trim piece off either you can easily access from the inside just remove the liner.  Theres clips you can slowly pry one by one and it also has some double sided tape helping hold it in place but that peels up pretty easy.  So for me I'll just heat it up and peel it off, put the new one on...if it doesn't come with anything I'll 3m tape it on.when I do it I'll take pics
shoNoff
Quote from: SM105K on May 02, 2019, 10:09:05 AM
Geez between you and SBS, yall making moves.
How do you think I feel I actually have to go to the track WITH him. :help:
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Agentlongwood
12.5 sounds pretty dang fast.  I'm stuck at a best of 13.0 and only when it was 45 degrees out, lol.
StealBlueSho
Congrats! Excited to see the new numbers!
Matt and I have been working together the past couple days on some really cutting edge stuff in the tuning department.
You will for sure be in good hands!
When are you scheduling the install?
802SHO
Thanks!  The install is scheduled for the 24th and I'm sure I won't get it back until the 25th.  I dont have dyno numbers of the set up I have now.  There isn't an AWD dyno here that has mechanically linked rollers, there is one that is a hub dyno but the shop is odd, never has returned any of my calls and Ive left a couple voicemails.  I would prefer to do a dyno before and after GH turbos, intercooler and second meth nozzle.  I will have before and after track slips that's for sure.
I did find a dyno in NH I plan to use post install but at the moment I'm trying to plan something at a different dyno.  Hopefully that works out or I'll end up at the one I found in NH, Granite State Dyno & Tune.
The plan right now is to use GH's complimentary base tune to accomodate the new turbos and intercooler to get me going.  GH is certainly a tuner I would run with as they clearly have a grasp on this platform seeing how they developed the turbos and intercooler but I'm resisting that idea.  I'm inclined to believe GH has the best strategy for tuning their turbos and intercooler however I'm not counting my buddy AJP out so I've reached out to Brad and Ive got a plan in the works that I hope turns out.
802SHO
Quote from: Agentlongwood on May 02, 2019, 10:51:09 PM
Take the dang stroller and kid seats out !  😄
802SHO
Quote from: shoNoff on May 02, 2019, 09:07:48 PM
Got you covered there buddy how about you drive!
802SHO
Cut my tips off last night and dropped them off to Vermont Powdercoating.  Decided to go matte black instead of gloss.  Sp542 plugs showed up.  Still waiting on my badge from Billet Badges.  GH turbos and intercooler should be here later in the week.  Placed my order with TascaFord parts for all new turbo oil and coolant lines along with a brand new rear reinforcement bar.  Also placed an order today with Alky Control for new pump and dual nozzle upgrade.  Mike @ EPP said the intercooler to throttle body pipe is 1-2 weeks out so hopefully I will be able to install them before the 24th when the turbos go on.  Also ordered another trans cooler by Derale.  16 row cooler that I'm going to also mount on my front impact bar, but I will also delete my grille mesh, the cooler is black so it should look pretty mean with a grille delete with the added cooler on display.  I want to change up my front spoiler.  A sheet of 3/8 abs plastic will be plenty to make a custom front splitter with rods.  I want the front end to look like one mean mother*****r.  Items all add up and getting pricey...thats about all for now.  Just sit back and wait for them to show up then it's time to install everything myself except turbos.
SM105K
Quote from: 802SHO on May 07, 2019, 01:10:27 PM
Sitting over here....wishing I was going down this path as well.  Soon.
802SHO
If it wasn't for that trans issue you would be.  Hard to bullet proof it...just adding another cooler and hoping for the best.  I drove it a hair over 3,000 miles last year...if I can get 5,000 fun miles out of it this year with no issues I'll be stoked!
