- RotM Winner
- Elite Member
- Boosted
- Logged
Manu you were right! After having DTC P0130 and P0150 at the same time you suggested to clean the sensors before buying new wideband. So far so good on cleaning my 3bar and IAT sensors before replacing my wideband oxygen sensors. I cleaned them...at the same time which I found they both have the identical part numbers....is that correct? My 3bar and IAT sensor are the same? I then swapped out my sp534 plugs with the sp542 plugs all gapped to about .027-.028. Brad asked me about my Meth settings and I think my new pump is more powerful than the last as he made remarks that I was spraying a lot....I kept my settings the same and just swapped the pumps. I decreased the initial by about a quarter turn and also increased gain to 8 to start spraying at 8psi. We make boost so damn quick I don't think I need to spray at less than 8.
Took it for a warm up drive then two data logs. One from a dead stop, no brake boost just a hard WOT 1,2,3 gear sweep. Then another at about 2,000 rpm in 3rd, WOT 3rd gear to about 5,600 Rpm. That's it. It felt better I must say and my check engine light did NOT come back on.
Pic of my sp534 with just 3k miles.
