October 15, 2019, 09:51:05 PM
Author Topic: waste gates 2010-2012 sho  (Read 309 times)
Offline Vvvdannyvvv
  • Jr. Member
  • : Columbia Missouri
  • -Given: 7
  • -Received: 12
  • 2012 SHO
« on: April 26, 2019, 02:14:06 PM »
2012 sho, 103k miles
at 9lbs of boost its showing 78% duty cycle
at about 16 psi ish its showing 100% duty cycle and shutting the butterfly. Car pulls good up to 100 duty cycle no issues.
I had the passenger side turbo replaced a year ago from ford. (this included the whole assembly)
is there a way to test old turbo and see if that waste gate is the issue?
2012 SHO
Plugs, 3 bar, Catless dp, springs
Fastest Run stock 13.9 full weight plus extra
Fastest run on LMS 93 Race tune 12.41 full weight.
Fastest run on Ortiz TBD
Offline ford2001
  • Newbie
  • -Given: 0
  • -Received: 1
Re: waste gates 2010-2012 sho
« Reply #1 on: April 26, 2019, 02:30:47 PM »
Use a calibrated vacuum pump and see where it opens up.. most are completely open at 10 inhg
Sent from my SAMSUNG-SM-G891A using Tapatalk
* Featured Topics
* Recent Topics
by Gofspar | Today at 08:56:02 PM
Also it's extra bad if I go around a corner and apply some heavy ...
Re: Meth and bank imbalance?
by bamsho | Today at 06:17:18 PM
My single port Alky Controls with M15 nozzle, both banks on my '1...
Re: Help with codes
by ZSHO | Today at 06:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosi...
Re: Newbie first time in a Ford!
by SHOdded | Today at 12:26:34 AM
Anti-spam measures.  We get hit hard and often LOL.  Should ...
Re: Splitter
by 802SHO | October 14, 2019, 02:23:41 PM
Dropped the splitters off for corner rounding.  Should have them ...
Re: Rear upper control arms?
by SHOdded | October 13, 2019, 02:16:52 PM
What year is your Flex?  I am including the procedure for a 2011,...
Re: New PB 11.8947 Gearhead E30
by 802SHO | October 13, 2019, 08:36:08 AM
Congrats man and welcome to the 11's buddy!...
Re: Snow Pics!
by Gjkrisa | October 12, 2019, 11:56:20 PM
Here's a neat picture of the ice on her in the woods https://uplo...
Re: Boost leak help
by ZSHO | October 12, 2019, 12:04:22 PM
The wastegates should be in the closed position AFAIK! In your case it...
Re: PPE Updated Downpipes
by 76fomoco | October 11, 2019, 08:11:46 PM
I too would like to delete the 3rd cat so post back with your DP'...
Re: End of an era!
by 76fomoco | October 11, 2019, 08:05:10 PM
man I would love to by this hood!...
by 76fomoco | October 11, 2019, 08:01:20 PM
KEEPEM COMING!...
Re: Check engine flashing, fuel smell, limp mode, and now no start
by StinkinLinkin13 | October 11, 2019, 02:27:04 PM
Awesome. Congratulations and great job! 🍻...
Re: 2014 pp driveline in 2010 sho questions.
by Spyder3000gtvr4 | October 11, 2019, 10:00:01 AM
Havenít had time to look at the car again will try this weekend. Will ...
Re: Throttle body size for Taurus SHO?
by ddlopes | October 11, 2019, 09:11:49 AM
Looks like the BBK may need to be modded to work properly... according...
Back to top
