October 23, 2020, 01:57:52 AM
Author Topic:  SBS 2016 Taurus SHO Build Thread  (Read 28966 times)
Offline StealBlueSHO
  • Administrator
  • -Given: 2890
  • -Received: 2829
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #225 on: June 04, 2020, 08:52:11 AM »
Welp... the SHO threw a CEL last night, go figure since I was taking pictures of it...
P2195 - Oxygen Sensor 1 Bank 1 biased/stuck lean
Datalogged it and it was reading 1.99 lambda... time for a new WB.... fun fun!!
2016 Taurus SHO Performance Pack, Gearhead Custom Tunes, Gearhead Gen3 Turbos, Gearhead Intercooler, Gearhead 170 Tstat, EPP Dual Feed Intake, EPP Hot Pipes, EPP Ceramic Coated Catted Downpipes, Corsa Exhaust, XDI-35 Fuel Pump, DW In-Tank Fuel Pump, Fuel-It Bluetooth Ethanol Analyzer, HR Lowering Springs, AD Lower Trans Mounts, 3Bar MAP, SP-542 Plugs, Custom SHO Puddle Lights, Custom Gearhead emblem overlays. Best time currently is 11.922 @ 115mph full weight, stock wheels, stock tires... just like it came off the show room floor.
  • Administrator
  • -Given: 2890
  • -Received: 2829
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #226 on: June 04, 2020, 09:47:18 AM »
Also realized I never posted the plugs I pulled out...
Looked ok..all still gapped at .026
  • Administrator
  • -Given: 2890
  • -Received: 2829
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #227 on: June 04, 2020, 01:16:12 PM »
New WB installed, no obvious damage except a small indentation on the body of the plug after the nut.  Initial fuel trims and AFR look good! Idle is smoother I think...
Offline 802SHO
  • Currently World’s Fastest Ecoboost SHO
  • RotM Winner
  • Essex Junction Vermont
  • -Given: 2383
  • -Received: 1146
  • Boosted
  • Liked:
  • Likes Given: 0
« Reply #228 on: June 05, 2020, 05:22:09 AM »
You know it's tempting to bring back the true form of my wheels.  They're plasti dipped.  But underneath they are like yours.  Looks great in your photo.
Offline ZSHO
  • Forum Supporter
  • Forum Supporters
  • New York SHO
  • -Given: 1941
  • -Received: 4084
  • Liked:
  • Likes Given: 0
« Reply #229 on: June 05, 2020, 07:01:52 AM »
It looks as the washer was not fully secured! There was a TSB on the 02's IIRC! Fingers crossed. Z
https://drive.google.com/file/d/1_DEEpaKzKmuI-cdA-MTs_PtlmgeTdA8A/view?usp=drivesdk
« Last Edit: June 05, 2020, 07:10:36 AM by ZSHO »
  • Administrator
  • -Given: 2890
  • -Received: 2829
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #230 on: June 05, 2020, 11:57:41 AM »
I really like the 5 spoke TBH.. I would have preferred the 5 spoke.. but I got all four wheels for $350, so even if I rock them for a bit, I can turn around and sell them for more lol.
Offline 802SHO
  • RotM Winner
  • -Given: 2383
  • -Received: 1146
  • Boosted
  • Liked:
  • Likes Given: 0
« Reply #231 on: June 05, 2020, 12:58:04 PM »
Yeah you got a killer deal.
  • Administrator
  • -Given: 2890
  • -Received: 2829
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #232 on: July 08, 2020, 09:14:24 PM »
So I had Gearhead center cap overlays on my stock wheels... and missed the overall flow so I ordered custom overlays for the new wheels....
Thinking I need to paint the calipers...
Offline ridered74
  • RotM Winner
  • Full Member
  • -Given: 153
  • -Received: 239
    • Ken Kyle Racing
  • Liked:
  • Likes Given: 31
« Reply #233 on: July 08, 2020, 11:10:23 PM »
Where are you ordering those from? That's one of the few stickers that I like. Why steal just part of someone's build when you can steal the whole thing?
Firestorm hpfp, catted downpipes, Corsa catback, 160 degree thermostat, 3 bar map, Gearhead E30 tune, Gearhead intercooler, upgraded trans mounts and EPP intake.
12.2479 @ 118.05 fastest trap
11.7513 @ 117.04   fastest ET
  • Administrator
  • -Given: 2890
  • -Received: 2829
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #234 on: August 19, 2020, 01:01:26 PM »
https://www.etsy.com/shop/DeVriesSigns
  • Administrator
  • -Given: 2890
  • -Received: 2829
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #235 on: August 19, 2020, 01:09:54 PM »
Couple things to mention...
1: Thanks to @OrtizPerformance for the battery tie down. I put a couple rubber grommets under the bolts to prevent them from breaking down the powder coating. Not sure what the material is under the powder coat, so don’t want to allow a route for rusting.
2: At Nationals this year @Bamsho noticed my low side fuel  line was rubbing. It was short when I got it, so I didn’t have a lot of room to route it, and had to stretch the stock fuel line coming off the firewall. Due to that, I am getting some rubbing that is wearing through the line. Email sent to Uwe at XDI to see if they have a longer line that routes better and isn’t as stretched.
3: Trans started leaking a drop every once in awhile again due to the seal failure where the two halves meet. While getting the oil changed at the dealer I asked them to look at it. They said they need to drop the trans and reseal it which will be covered under warranty. They also agreed to put in the upgraded torque converter from GH while its out, for a minimal fee since it has to be removed anyway. Although the dealer said the leaks is soo small it’s not a huge rush.. but small leaks turn into big leaks soo..
Offline SM105K
  • IG @egocheckersho
  • Forum Supporters
  • Arizona
  • -Given: 1045
  • -Received: 1211
  • Thee Forum Cowboy
  • Liked:
  • Likes Given: 15
« Reply #236 on: August 19, 2020, 01:24:04 PM »
Good stuff that it is under warranty.
"M" 2013 SHO PP | AJPTurbo E30 Tune | FS HPFP | Custom Air to Water Intercooler| PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Derale Upgraded Trans Cooler | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Eliminator | MSD Coil Over Plugs | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Slotted and Drilled Rotors with Stock PP Pads | H&R Springs  | AVS Flush Deflector | 802SHO Custom Splitter | Duraflex Chin Spoiler | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
  • Administrator
  • -Given: 2890
  • -Received: 2829
  • I poke at BPD1151
  • Liked:
  • Likes Given: 51
« Reply #237 on: October 17, 2020, 03:01:45 PM »
Out with the AD front mount and in with the stock one..
Being as I’m turning my SHO into a daily...  no need to have my balls vibrating in the seat all the time ....
Plus it’s debatable whether the front makes much of any difference when you pair the AD rear with a new stock front...
I forgot how much smoother it makes the ride and idle.. although you don’t feel as connected with the car since your not feeling every little thing...
* Recent Topics
Re: Ambient Lighting
by djshew12 | Today at 01:39:59 AM
Here you go:http://www.ecoboostperformanceforum.com/index.php/topic,23...
HID preference
by BlueSHO | Today at 12:32:19 AM
Thinking about changing out the bulbs in my 2016 SHO to something a li...
ecoboost_xsport Consolidated Build/Maintenance Thread
by Ecoboost_xsport | October 22, 2020, 11:35:40 PM
Oh Sh!t Moment - Incident 01Ummm, so yeah....this happened today:https...
Re: Hey from NC
by TopherSho | October 22, 2020, 07:07:02 PM
Welcome!Onto the topic what to look out for  ::It is a tough thin...
Re: Colorado SHO - Looking for advice
by djshew12 | October 22, 2020, 12:30:06 PM
Wonderful. Thanks! Yeah I was thinking that the power packages would b...
Re: Need to share with this group.
by Brucelinc | October 22, 2020, 09:51:31 AM
Damn, Brian, I hate hearing the diagnosis but I love your positive att...
by sm105k | October 22, 2020, 09:39:05 AM
I like that green.  It is sharp. ...
by sm105k | October 22, 2020, 09:36:24 AM
Never been a huge fan of turtlenecks myself.Like Archer, I wear tactin...
Re: Any Explorer Sport intercoolers available?
by Ecoboost_xsport | October 21, 2020, 08:20:52 PM
Yeah, I'm trying to find some data on the Mishimoto as far as flo...
Re: P0442 Small Evap Leak Code
by 6500rpm | October 21, 2020, 07:32:13 PM
I'm guessing your 2011 has the capless fuel filler tube,  it...
