October 15, 2019, 09:51:20 PM
Author Topic: SBS 2016 Taurus SHO Build Thread  (Read 9008 times)
Offline shoNoff
  • : NH
  • -Given: 199
  • -Received: 602
  • Shomu the killer whale
« Reply #180 on: May 29, 2019, 02:17:30 PM »
Look good! I found they smoothed out my idle a ton. Hopefully they help you as well.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
Offline StealBlueSHO
  • -Given: 2269
  • -Received: 2243
  • I poke at BPD1151
« Reply #181 on: June 01, 2019, 04:25:15 PM »
So I have been having a residue oil leak after the XDI bolt snapped... cleaned it good a few a times thinking it might have been left over oil seeping since oil went everywhere....
Still get this small leak...
And a bit more here..
When XDI sent me the new bolts they also sent me a new stock mounting plate as well... so I finally took the time to pull it all apart again...
Sure enough there is the SLIGHTEST bend on mine from when the bolt snapped and the pump flexed the original plate... only detectable when placing on a flat surface.. it rocks just a hair...
So swapped them and will see if this one doesnít leak...
And mounted...
Oh and this doesnít fit...
Hopefully I can put this the bed...
2016 Taurus SHO PP, Gearhead Tuned, Gearhead Upgraded Gen3 Turbos, XDI-35 HPFP, Gearhead Intercooler, EPP Catted/Thermal coated DP's, Corsa Exhaust, HR Springs, Airaid Intake, EPP Hotpipes, Gearhead 170F Tstat, 3BAR Map, UPR CSS Catch Can, MSD Blaster Coils, Upgraded Torque Mounts, Fuel-IT BT Ethanol Analyzer, SP-542's.
484awhp/496awtq
Best of 12.192 @ 113.80 Gearhead E30 Tune - Pre-Turbo/DP/Torque Mount Upgrades.
Offline 802SHO
  • : Essex Junction Vermont
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #182 on: June 01, 2019, 05:22:27 PM »
And Beer makes everyone happy
2010 SHO non PP, GH upgraded turbos, GH upgraded IC, EPP Hot Pipes, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous 35 shot, Dicunzolo Gen2 torque mounts, SP542 .028, 160 T, Airaid Intake, 3bar, Thunderstorm Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge, Tuned by AJP Turbo
Highest Trap Speed 123.22 mph
463awhp 569 awtq mustang dyno 6/13/19
11.526 @ 118.50 NED 10/5/19 full interior +75 shot
11.391 @ 123.22 NED 10/5/19 Driver seat +75 Shot
Offline shoNoff
  • : NH
  • -Given: 199
  • -Received: 602
« Reply #183 on: June 01, 2019, 07:09:49 PM »
Damn Iím upset you found it. I was gonna suggest we trade cars since mine didnít leak there.
  • -Given: 2269
  • -Received: 2243
  • I poke at BPD1151
« Reply #184 on: June 03, 2019, 04:51:18 PM »
Well.. things have been a bit slow lately.. Had the stomach flu since last Thursday.. Finally went to the Doc... nothing they can really do.. all my lab work came back spotless soooo just have to ride it out per se...
However, on the way to the doctor I hammered on the SHO a little bit...
Leak is gone, so I can conclude it was coming from the stock mounting plate getting a hair bend in it. Finally can put that one to rest. Did have small gas leak from the HPFP high pressure line from me pulling it off.. re-adjusted and tightened it down, fixed...
The MSD Blaster COP much to my surprise actually do help smooth out the rpms and idle. It was kinda of "Well they get good reviews.. I don't really think they are going to do anything, but why not" purchase.. well.. I agree with the reviews. It does seem to have a bit more ugg nugga up top.. maybe like 1 ugg nugga.. but also smoother...
Anyway.. waiting on an updated tune from Matt which is going to fix the throttle in first/second... should make a difference for sure.
484awhp/496awtq
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 11865
  • -Received: 3893
« Reply #185 on: June 03, 2019, 04:54:17 PM »
Get well soon, in cliche parlance :D  Sounds like finally the SHO will be re-ascending to maximum potential!
Offline 802SHO
  • -Given: 1603
  • -Received: 781
  • Boosted
« Reply #186 on: June 03, 2019, 06:18:45 PM »
Hope you and Blue feel better...."At the same Damn Time"
  • -Given: 2269
  • -Received: 2243
  • I poke at BPD1151
« Reply #187 on: June 13, 2019, 03:38:01 PM »
Just a lil something.... sorry car is dirty AF...
484awhp/496awtq
Offline shoNoff
  • : NH
  • -Given: 199
  • -Received: 602
« Reply #188 on: June 13, 2019, 04:37:51 PM »
Hahaha nice touch. Looks good. Did you have those made?
  • -Given: 2269
  • -Received: 2243
  • I poke at BPD1151
« Reply #189 on: June 13, 2019, 04:41:22 PM »
Thanks! Yes custom made.
484awhp/496awtq
Offline SHOdded
  • Administrator
  • : Beltsville, MD
  • -Given: 11865
  • -Received: 3893
« Reply #190 on: June 14, 2019, 04:17:02 AM »
Even looks like an M from a distance ;)  Hope you put the smackdown on the flu!
  • -Given: 2269
  • -Received: 2243
  • I poke at BPD1151
« Reply #191 on: June 15, 2019, 06:23:07 PM »
484awhp/496awtq
Offline 76fomoco
  • Full Member
  • : Nampa, ID
  • -Given: 59
  • -Received: 114
« Reply #192 on: June 15, 2019, 09:06:15 PM »
poor vett owners have no clue what they are getting into....on the street or on the track!
2013 PP AJP multi tunes, 160 TS plugs, 3 bar, LMS catch can, EPP catted DP's, bridgestone potenza s007a
Best 5-25-19  12.51 @ 111.38 at 3350 DA
93+ meth 413 whp and 473 wtq 58* and 4020 DA on a mustang dyno
E30 415 WHP and 468 WTQ 70* and 3700 DA on a mustang dyno
  • -Given: 2269
  • -Received: 2243
  • I poke at BPD1151
« Reply #193 on: July 05, 2019, 02:05:05 PM »
Just little fun in 100F+ temps today...  old oil had 2,900 miles on it.. this was the original oil used with the turbo install plus multiple dynos, datalogs, and a few passes at the track..  LOOKED good.. no metal bits found with a magnet...
Double checked for leaks etc and everything looks good.. the output seal on the PTU is still has a little shine on it but nothing serious yet..
So we now have fresh oil to continue the revisions on my turbos.. Matt is having to remap the tables since my car isn't responding the same way as his or anyone elses.. mine is VERY boost happy..
Progress has been made as the throttle is now opening all the way between shifts in a controlled manner so thats a plus.. keeping my fingers crossed that it will be good to go in the next couple revisions.. then onto the E30 revisions which shouldn't be near as bad since Matt said he can take the new mapping and apply them to the E30 tune..
I will say that getting these turbo's dialed in has been painful, BUT even the auto octane tune is a new beast with it almost done.. can't wait to see how the E30 feels.
Matt could cheat and apply parameters to get the car to respond correctly, but him and I discussed and agreed it would be better to have the turbos dialed in 100% as opposed to short cuts.
484awhp/496awtq
  • -Given: 2269
  • -Received: 2243
  • I poke at BPD1151
« Reply #194 on: July 05, 2019, 04:38:29 PM »
Added some more styling!
484awhp/496awtq
* Featured Topics
* Recent Topics
by Gofspar | Today at 08:56:02 PM
Also it's extra bad if I go around a corner and apply some heavy ...
Re: Meth and bank imbalance?
by bamsho | Today at 06:17:18 PM
My single port Alky Controls with M15 nozzle, both banks on my '1...
Re: Help with codes
by ZSHO | Today at 06:05:58 AM
Since you have a 2010MY inspect the wiring for any chaffing or corrosi...
Re: Newbie first time in a Ford!
by SHOdded | Today at 12:26:34 AM
Anti-spam measures.  We get hit hard and often LOL.  Should ...
Re: Splitter
by 802SHO | October 14, 2019, 02:23:41 PM
Dropped the splitters off for corner rounding.  Should have them ...
Re: Rear upper control arms?
by SHOdded | October 13, 2019, 02:16:52 PM
What year is your Flex?  I am including the procedure for a 2011,...
Re: New PB 11.8947 Gearhead E30
by 802SHO | October 13, 2019, 08:36:08 AM
Congrats man and welcome to the 11's buddy!...
Re: Snow Pics!
by Gjkrisa | October 12, 2019, 11:56:20 PM
Here's a neat picture of the ice on her in the woods https://uplo...
Re: Boost leak help
by ZSHO | October 12, 2019, 12:04:22 PM
The wastegates should be in the closed position AFAIK! In your case it...
Re: PPE Updated Downpipes
by 76fomoco | October 11, 2019, 08:11:46 PM
I too would like to delete the 3rd cat so post back with your DP'...
Re: End of an era!
by 76fomoco | October 11, 2019, 08:05:10 PM
man I would love to by this hood!...
by 76fomoco | October 11, 2019, 08:01:20 PM
KEEPEM COMING!...
Re: Check engine flashing, fuel smell, limp mode, and now no start
by StinkinLinkin13 | October 11, 2019, 02:27:04 PM
Awesome. Congratulations and great job! 🍻...
Re: 2014 pp driveline in 2010 sho questions.
by Spyder3000gtvr4 | October 11, 2019, 10:00:01 AM
Havenít had time to look at the car again will try this weekend. Will ...
Re: Throttle body size for Taurus SHO?
by ddlopes | October 11, 2019, 09:11:49 AM
Looks like the BBK may need to be modded to work properly... according...
Back to top
