SBS 2016 Taurus SHO Build Thread - LOCKED
Started by StealBlueSho, April 23, 2019, 08:59:19 AM
shoNoff
My god SBS what a pain in the ass that is. Glad it turned into a sorta simple fix. Wonder if maybe a dab of low strength purple Loctite would help.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
StealBlueSho
Quote from: shoNoff on April 25, 2019, 09:51:27 AM
That thing pushes 3000 psi from that spring... locktite ain't helping that lol!
The new bolts are longer, stronger, and better quality... should be OK. I hammered the snot out of it...still holding soo.
StealBlueSho
Not exactly what I wanted to see after just paying the bill for the turbos and all the other work....
Good thing I hadn't eaten or I would have vomited probably..
Had my buddy who is a mechanic in the car with me... he kept me calm! Said bolts snap.. not the end of the world.
Lot of torque with that HPFP, we now know for sure LOL.
SM105K
Quote from: SHOdded on April 25, 2019, 10:36:23 AM
Since I am not worried about breaking my trans again, I wonder where the limit is before a rod gets kinked. I think a 500 hp/600 tq to the tire SHO would make for a interesting ride.
StealBlueSho
Quote from: SM105K on April 25, 2019, 11:19:12 AM
Not sure? I'm running as high as I feel comfortable right now...
I know the highest HP SHO LMS let out the door on stock internals was 465awhp.
18SHO
What's going to be awesome is there's only I think 2 other SHOs in the US That will be a run for the money after your tuned , your on stock block and no meth  😂😂 pump gas only
2018 SHO PP factory stock for now
AJPTURBO E30 tune stock plugs .028 gap
5.25.19 12.53 @ 112.96 1.85 60FT 1850 DA 71 F
Best trap 113.61
StealBlueSho
Quote from: 18SHO on April 25, 2019, 11:53:36 AM
What's going to be awesome is there's only I think 2 other SHOs in the US That will be a run for the money after your tuned , your on stock block and no meth  pump gas only
I appreciate the confidence! Track slips will help for sure. There are some pretty impressive SHO lately.
shoNoff
Quote from: StealBlueSHO on April 25, 2019, 11:57:06 AM
I call bs on any track slip. No way your car can be fast and not tuned by ***.
StealBlueSho
Quote from: shoNoff on April 25, 2019, 12:09:28 PM
Parts procured by Nick Olson too!
shoNoff
Quote from: StealBlueSHO on April 25, 2019, 12:12:15 PM
hahaha not to muck up your thread to much. Im legit in tears that the companies name gets blocked. How could I forget Nick Olson. No idea how that power is getting down without his upgraded transmission lol.
SM105K
Quote from: shoNoff on April 25, 2019, 12:20:56 PM
Who?  Sierra Sierra India?  My tune only car pump gas car has gone faster then most of their race gas cars...yawn.
StealBlueSho
Ok.. back on topic..
Pump is fixed... the car was way out of alignment.. I called National Speed, INC to let them know.. but being as I don't want to drive back there.. I went ahead and paid my go to shop to get it back in... Murphys Motorsports in Warrenton, VA... great place..
Their master tech took a look at everything, double checked the work that was done, had to make 2 hrs worth of adjustments to the cradle, suspension, etc.. but its all back into alignment..
Eric the tech said it looked good, no leaks, everything seems to be put back together correctly.. his one comment was they should have marked the cradle before removing it so they could have put it back where it was previously positioned.. would have made it A LOT easier to put back into alignment, if it even needed it.
18SHO
LOL 3 stars wonder what tuner has 3 letters
Best trap 113.61
