SBS 2016 Taurus SHO Build Thread - LOCKED
Started by StealBlueSho, April 23, 2019, 08:59:19 AM
shoNoff
#165
Quote from: 802SHO on May 24, 2019, 12:59:07 PM
I hope its just tuning related.  I mean, I want to say it must be but at least you're entertaining the idea it could be something more serious...hopefully just to rule out a serious issue.
It could be your hose is too short.  It was tight getting it up there.  I will be able to show how I routed mine when I get back.  I'll even measure it to make sure we have the same length.........waiting for comments on that hahahaha
Lmao always a *ick measuring contest on forums.
2013 SHO PP 12.51 @ 110.07 AJP tuned sold
2016 edge sport 13.92 @ 99.4 mph. slow and stock baby mobile
StealBlueSho
How does it start up/crank over! Z
StealBlueSho
Quote from: ZSHO on May 24, 2019, 01:02:20 PM
Cranks and starts just fine.
StealBlueSho
New dyno completed...
I'm down about 18HP from the previous runs. However... humidity is double what it was and temps were 91F vs 85F... soo in short.. based on all the information, my engine is running well. Both banks are showing similar AFRs, no oil consumption, no knock...
The shop said everything sounds good, and the dyno results are within norms considering the environmental deltas. They said there is nothing here that would suggest a compression test would be needed at all.
Datalogs all look great....could use some more boost according to Matt... So I will let the mad scientist do his thing when he gets a chance...
Basically... summer air/humidity vs spring air/humidity...
Things are all good..
shoNoff
Quote from: StealBlueSHO on May 24, 2019, 09:50:06 PM
Thats great news! That must be a great feeling for you knowing everything is ok. Can't wait to see what that beast does turned up. Like I said da makes a massive difference. Your car will run 11's all day with that tune up in better air.
802SHO
Glad to hear that's great news!
SM105K
GOOD.  I wasn't worried, but kinda worried if that makes sense....lol.
StealBlueSho
Quote from: SM105K on May 28, 2019, 08:53:14 AM
Yea, 18HP can be heat soak easy. Correction helps with environmentals...but doesn't take into account pulled spark etc from high IATs.
SM105K
SBS,
I saw your want add about the MSD coils.  Do you and Matt believe you are starting to over exceed capabilities of the stock coils?
StealBlueSho
Quote from: SM105K on May 28, 2019, 02:53:16 PM
SBS,
No, I don't think we have exceeded the capabilities of the stock coils. However, Matt has mentioned that even the modest (IIRC 15%) increase in energy that the MSD coils provide over stock make a big difference. They did pick up 9awhp over the stock coils and Matt said that it does smooth out the top end. For $260 its a small cost... also ordered new boots to go with them. I should remove the add...
SM105K
StealBlueSho
Threw the coils in.... haven't driven it yet.... but they are there! Lmao....
SM105K
StealBlueSho
Quote from: SM105K on May 29, 2019, 05:13:12 PM
So fancy SBS.  They look good.
Thanks! I wanted black ones.... but I got a 10% discount on the red ones and free shipping....
