May 27, 2020, 07:36:03 am
Author Topic: Spark plugs  (Read 4971 times)
Offline SHOdded
  • Moderator
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
Re: Spark plugs
« Reply #15 on: April 20, 2019, 08:59:59 pm »
Looking forward to the results!
Offline 18SHO
  • Full Member
  • NY
  • -Given: 68
  • -Received: 56
Re: Spark plugs
« Reply #16 on: April 24, 2019, 02:17:30 pm »
How long should I wait until I swap plugs from a drive about 2 hours? I usually wait until cars cold but if I had time today has anyone done a swap while motors still a little warm but not hot?
2018 SHO PP factory stock for now
AJPTURBO E30 tune stock plugs .028 gap
5.25.19 12.53 @ 112.96 1.85 60FT 1850 DA 71 F
Best trap 113.61
Offline SM105K
  • Forum Supporters
  • Arizona
  • -Given: 832
  • -Received: 1028
  • HATER MAKER
Re: Spark plugs
« Reply #17 on: April 24, 2019, 02:48:19 pm »
You can change them anytime even with the motor blazing hot....it depends on how much heat you can take....
"M" 2013 SHO PP | AJPTurbo E30 Tune | GH Intercooler | PPE Downpipes | Custom Magnaflow Resonator | 3rd Cat Delete | Dicunzolo Gen2 Trans Mounts| EPP Noisemaker Elimintor | MSD Coils | SP-542's | UPR Dual Valve Catch Can | K&N Drop In | Power Stop Brakes | H&R Springs  | Curva Concept C7's | Continental DWS06 Extreme Contact Rubber |
Offline 18SHO
  • Full Member
  • NY
  • -Given: 68
  • -Received: 56
Re: Spark plugs
« Reply #18 on: April 24, 2019, 02:55:38 pm »
Oh good , wasn't sure if with the aluminum heads there was a necessity for being cold only. I bet hood open for an hour with coils off will make it bearable
Best trap 113.61
Offline SM105K
  • Forum Supporters
  • Arizona
  • -Given: 832
  • -Received: 1028
  • HATER MAKER
Re: Spark plugs
« Reply #19 on: April 24, 2019, 03:04:05 pm »
If that was the case, nitrous guys wouldn't be pulling plugs directly after runs.  Just make sure you use anti sieze on the threads, and I always use dielectric grease as well.
Offline SHOdded
  • Moderator
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
Re: Spark plugs
« Reply #20 on: April 24, 2019, 04:05:49 pm »
Ideally warm to the touch is warm enough to change plugs in aluminum heads.  Just take your time removing the plugs and installing them to avoid crossthreading.  Antiseize is typically not necessary with modern plugs, if you choose to use, use sparingly so as to not alter torque values.  If you are re-installing the old plugs, definitely use antiseize.
http://ricksfreeautorepairadvice.com/anti-seize-spark-plug-threads/
Offline 18SHO
  • Full Member
  • NY
  • -Given: 68
  • -Received: 56
Re: Spark plugs
« Reply #21 on: April 24, 2019, 05:49:57 pm »
Thanks for the replies , I'll probably use a slight dab on upper threads , says on box between 7.2 lb ft to 14 lb ft torque value . 10 lb ft sounds like perfect to me
Best trap 113.61
Offline SHOdded
  • Moderator
  • Beltsville, MD
  • -Given: 12953
  • -Received: 4203
Re: Spark plugs
« Reply #22 on: April 24, 2019, 08:09:46 pm »
There is a detailed howto in the ... HOW TO ... section :) should you need more info to look up.
Offline avidmotion
  • Sr. Member
  • -Given: 5
  • -Received: 85
Re: Spark plugs
« Reply #23 on: April 26, 2019, 10:53:15 pm »
......so now I am confused, should I upgrade to the sp542 or the sp 580.? Or that new super metal plug and change it a little less often......? Any specific vendor have deals on either plug, 580 vs 542? Thanks leaning towards the sp580 and be done with it. ..
Offline ZSHO
  • Forum Supporter
  • Moderator
  • New York SHO
  • -Given: 1932
  • -Received: 4056
Re: Spark plugs
« Reply #24 on: April 27, 2019, 08:50:01 am »
The MOTORCRAFT- SP542 is a better overall Spark plug and 1 step colder spark plugs specially @ this price-point. Z
FYI- The MOTORCRAFT SP534 CYFS12YT3 is the Stock OEM Spark plug which most recently was superseded with the SP580 Iridium spark plug! Z
SP-542- CYFS092YPT $6.11 ea
SP580 -CYFS12YT3 - $7.35 ea
https://www.rockauto.com/en/parts/motorcraft,SP542,spark+plug,7212
https://www.rockauto.com/en/moreinfo.php?pk=5931324&jsn=3
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,ignition,spark+plug,7212
« Last Edit: May 11, 2019, 03:55:35 pm by ZSHO »
Offline 18SHO
  • Full Member
  • NY
  • -Given: 68
  • -Received: 56
Re: Spark plugs
« Reply #25 on: April 28, 2019, 10:09:43 pm »
580 same as OEM , 542 one step colder better for more boost and tuned cars
Best trap 113.61
Offline avidmotion
  • Sr. Member
  • -Given: 5
  • -Received: 85
Re: Spark plugs
« Reply #26 on: May 01, 2019, 11:25:23 pm »
Ok,  I think some sp 542 have my name on them. I am only getting 35,000 out of my iridiums. ...
Offline ZSHO
  • Forum Supporter
  • Moderator
  • New York SHO
  • -Given: 1932
  • -Received: 4056
Re: Spark plugs
« Reply #27 on: May 11, 2019, 11:27:39 am »
New Motorcraft SP-542- CYFS-092-YPT Spark plugs arrived today and were gapped very close to 0.030 out of the box. Z  :)
« Last Edit: May 11, 2019, 03:48:00 pm by ZSHO »
Offline 802SHO
  • Essex Junction Vermont
  • -Given: 2070
  • -Received: 996
  • Boosted
Re: Spark plugs
« Reply #28 on: May 11, 2019, 03:20:07 pm »
New Motorcraft SP-542 Spark plugs arrived from www.RockAuto.com all pre-gapped @ 0.028 . Z  :)
Do they all come pre-gapped at .028 or did you ask for them to be pre-gapped for you?
2010 SHO non PP, Tuned by AJP Turbo, Ported GH upgraded turbos, Ported 13+ Exhaust Manifolds, GH upgraded IC, EPP Hot Pipes, EPP Dual CAI, XDI35 HPFP, Deatschwerks LPFP, Alky Control Methonal Injection, Alky dual nozzle upgrade, Zex Nitrous, Dicunzolo Gen2 torque mounts, MSD Coils, SP542 .026, 160 T, 3bar, Catless Downpipes, custom stainless 2.5" double xpipe w/muffler deletes 4" quad tips, UPR Dual Valve Catch Can, Derale 10000 series 16 row trans cooler, 13+ PP Trans Cooler, Econoaid throttle Body Booster, Mickey Thompson 20x9 SC-5 Wheels, Continental Extreme Contact DW tires F: 245/40/20 R: 275/35/20, H&R Springs all around w/rear cut 1/2", 1" hubcentric wheel spacers m14 1.5 stud/lug conversion, Aeroforce Interceptor Gauge.
Highest Trap Speed 123.22 mph
PB 11.368 @ 122.68 NED 10/20/19
Offline ZSHO
  • Forum Supporter
  • Moderator
  • New York SHO
  • -Given: 1932
  • -Received: 4056
Re: Spark plugs
« Reply #29 on: May 11, 2019, 03:50:32 pm »
I stand corrected and the Gap was closer to 0.030 . Z
« Last Edit: May 11, 2019, 03:52:43 pm by ZSHO »
* Featured Topics
* Recent Topics
Re: 802SHO 2010 Build
by 802SHO | Today at 06:17:39 am
Honestly that's not alot of $ for better flow vs our manifolds IM...
by bpd1151 | Today at 01:21:26 am
I'm hoping that that opening line is laden with sarcasm.Actually ...
Re: Updated Gallery Capabilities
by bpd1151 | Today at 01:10:42 am
I have some time off from work coming up soon. I'll have to check...
Re: Transfer case torque limit
by 10sleeper | Today at 12:43:07 am
My tuner just noticed that I was hitting my transfer case torque limit...
Re: For those looking for something different for a 2nd (or 3rd) car
by FoMoCoSHO | May 26, 2020, 11:23:21 pm
There is another CON if you are a DIY type...The packaging is slick bu...
Re: Thinking of trading the 16S H O
by Gjkrisa | May 26, 2020, 09:28:19 pm
I almost bought a dodge/jeep/Chrysler product once....nah I didn'...
Re: Does anyone here have a Taurus 2.0 EB?
by GhostlyGrenade | May 26, 2020, 07:35:35 pm
They must be giving SCT devices away. There's no way people are s...
Re: MRT blues
by StinkinLinkin13 | May 26, 2020, 04:32:36 pm
We'll my four muffler setup is a winner for me. Its not pretty ri...
Ecoboosted Gallery!!
by StealBlueSho | May 26, 2020, 11:27:31 am
Add a picture of your ecoboost or your favorite ecoboosted picture! It...
Re: MrHighCALiber's SHO Forged Engine Build
by 802SHO | May 26, 2020, 05:15:44 am
That's crazy!  Looks like she won't be down for long in...
Re: EBPF Under New Ownership!
by 76fomoco | May 25, 2020, 12:19:53 pm
SBS thanks for picking up the torch and keeping this wealth of informa...
Re: EPP CAI
by 802SHO | May 25, 2020, 05:58:21 am
I ordered mine last week and it's sitting on the bench. I figured...
Re: Letís talk weight reduction?!
by 802SHO | May 25, 2020, 05:42:56 am
I think it's worth it for a couple reasons...first being youre fa...
Re: Ford Recalls
by BlueSHO | May 24, 2020, 11:16:02 pm
FORD EXPLORER RECALL: SUSPENSION PROBLEMS IN 1.2 MILLION SUVS. Z ...
Re: Brake Cooling Kit
by bpd1151 | May 24, 2020, 07:55:43 pm
None that I've found. Although I do employ the Titanium heat shie...
Back to top
