Interesting Video on Tuning vs Performance
Started by Macgyver, April 13, 2019, 10:32:08 PM
Macgyver
Gray Brick
It would be great if they would give ET and MPH
2013 Ecoboost Ford Flex
Macgyver
Thats why I said short comings.
Its a video to watch for fun.
StinkinLinkin13
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
Macgyver
Quote from: StinkinLinkin13 on April 15, 2019, 12:05:10 AM
Very impressed by that 2.7 liter...
Yeah if you are not gonna haul much tow much etc. Its a good engine.
SM105K
Agentlongwood
The 2.7 liter was in a smaller truck... Just an extended cab.  Whereas the other motors were in crew cab trucks.  Definitely going to be a weight difference there, with 2 fewer doors and what not.
