Gearhead Turbos Received!
Started by StealBlueSho, April 10, 2019, 06:32:34 PM
mattr66
Quote from: 18SHO on April 12, 2019, 08:36:11 AM
Quote from: mattr66 on April 12, 2019, 08:27:09 AM
Quote from: 802SHO on April 12, 2019, 08:22:19 AM
Quote from: mattr66 on April 12, 2019, 08:19:39 AM
Quote from: 802SHO on April 12, 2019, 08:18:31 AM
I agree that boost is not everything.  18.2 boost at that power level?  That's very impressive to me.  Well within efficiency level?
Yep mire left in it but want to to keep stock rods in the block.
You have mentioned before I believe that your upgraded turbos are perfect for our engines without doing a built motor.  Based on what you have just explained I would be inclined to believe your turbos can also support a built motor?
Yes I am trying to stay around 500 torque to the tires.  I could easily generate enough power to kink them.... LOL
How much are we looking at for this kit Matt?
2k plus core
StealBlueSho
Big shout out to MrHighCaliber for the quick responses...
Here is the finalized order from Tasca for the required washers/gaskets/bolts/nuts for a turbo replacement. If this is for a failed turbo/engine you will also need to replace quite a few more parts. This is for a rip and replace for turbo upgrades.
MrHighCaliber said that MAHLE is also an OEM supplier so the Ford Parts could be MAHLE but otherwise they are listed at OEE.
The only difference in parts between the MAHLE kit and the parts order I placed is that I am also ordering new nuts/bolts in the even there is an issue. This is from TASCA so the parts are OEM.
Hard to go wrong with Mahle, Clevite, and Victor Reinz.
