Gearhead Turbos Received!
Started by StealBlueSho, April 10, 2019, 06:32:34 PM
mrhighcaliber
#15
Quote from: StealBlueSHO on April 11, 2019, 07:10:39 PM
Here is the recommended replacement hardware parts list for the Gearhead turbos. You don't HAVE to replace these... but highly recommended!! This was ordered through Tasca.
Just a note to anyone whom is doing future turbo r&r should get the MAHLE gasket kits.
P/N# GS33743 and GS33744.
left and right.
Comes with:
1x Turbo to manifold Gasket
1x Turbo to Down pipe Gasket
2x Aluminum Coolant line gaskets
1x Copper oil line inlet gasket
2x Rubber oil drain tube to block O-rings
1x Turbo to oil drain tube gasket
     -Per Kit
Price range Rock Auto to eBay is 27.99 to 32.99 per kit.
This is my second time using these kits. Oh and SBS, you require 2 turbo pipe O-rings per side. 4 total. Each drain tube has 2 where is slides into the block. Unless those are packs of 2 on your list.
Sent from my PH-1 using Tapatalk
StealBlueSho
Quote from: mrhighcaliber on April 12, 2019, 06:55:44 AM
P/N# GS33733 and GS33734.
left and right.
Comes with:
     -Per Kit
I'm basing this off what Gearhead sent me.
If there is other stuff I need to order let me know....
I didn't order any copper stuff since it wasn't on the list.
-Mike
802SHO
Great info!  Also curious if the dyno info from Matt's SHO was with upgraded hot pipes or if he is still using the stock plastic piping?
mattr66
Quote from: 802SHO on April 12, 2019, 07:45:03 AM
Yep all stock.... For now
802SHO
How much PSI are you tuned for?
mattr66
Quote from: 802SHO on April 12, 2019, 07:57:55 AM
67inhg max..
mattr66
Quote from: mattr66 on April 12, 2019, 08:07:59 AM
67inhg max..
So 18.2 psi of booat at sea level.  Boost isn't everything.  These turbos flow.
StealBlueSho
so about 18.2psi if you are monitoring..
802SHO
#23
I agree that boost is not everything.  18.2 boost at that power level?  That's very impressive to me as that is lower than I would have guessed.  Well within efficiency level?
mattr66
Quote from: 802SHO on April 12, 2019, 08:18:31 AM
I agree that boost is not everything.  18.2 boost at that power level?  That's very impressive to me.  Well within efficiency level?
Yep mire left in it but want to to keep stock rods in the block.
802SHO
Quote from: mattr66 on April 12, 2019, 08:19:39 AM
You have mentioned before I believe that your upgraded turbos are perfect for our engines without doing a built motor.  Based on what you have just explained I would be inclined to believe your turbos can also support a built motor?
mattr66
Quote from: 802SHO on April 12, 2019, 08:22:19 AM
Yes I am trying to stay around 500 torque to the tires.  I could easily generate enough power to kink them.... LOL
802SHO
Quote from: mattr66 on April 12, 2019, 08:27:09 AM
Outstanding!  Bravo and thank you for putting the time and money into the development of this forgotten platform!  Much much appreciated!
I think for many of us its not a matter of if we buy these, its only a matter of when.
18SHO
How much are we looking at for this kit Matt?
2018 SHO PP factory stock for now
AJPTURBO E30 tune stock plugs .028 gap
5.25.19 12.53 @ 112.96 1.85 60FT 1850 DA 71 F
Best trap 113.61
mrhighcaliber
Quote from: StealBlueSHO on April 12, 2019, 07:27:47 AM
left and right.
Comes with:
     -Per Kit
-Mike
I edited the part numbers and added the Rock Auto screenshot. The copper washers are for the oil line going into the top of the turbo. The 2 aluminum washers are for the coolant in and outlet lines. Seems like they would have you replace everything unless the oil inlet line is already attached.
