Quote from: jims2015 on March 29, 2019, 11:54:30 AM
Quote from: FLEXXX on March 27, 2019, 04:46:18 PM
for fuel I am tapped in between the lift pump and HPFP.
I have not touched the ring gap. I am not super worried about it since I have done all the other work (heads, exhaust, turbo's, piping, tune) I will probably not spray it anymore, no real need too. except if at the track, ill probably spray it to the moon last 500 feet. ill risk a bottom end to have the fastest flex on the planet.
This was a quick project to get it going. I did all the work/mods in 2 weeks. the motor that came out I am wanting to build legit with rods and pistons, but I think that will end up in a SHO.
In the old nitrous days I would run a completely independent fuel system with its own pumps from the tank to the solenoid. My bud would do the same except he would use a separate small fuel cell. Never a fuel problem.
If you run out of fuel will you have preignition issues?
