SSM 47662 - failed turbo & replacement of all mandatory discarded parts
Started by SHOdded, March 26, 2019, 10:27:32 AM
Manufacturer Communication Number: SSM 47662
Summary
For 2010-2019 vehicles equipped with turbocharged engines, when diagnosing and/or replacing turbo related concerns, all steps within the Workshop Manual (WSM) procedure must be followed including replacement of all mandatory discarded parts. For all turbocharged engine applications, the turbocharger oil supply filter (6C683 gas engine/6L625 connector style or 6A968 diesel engine) must be replaced whenever the turbocharger or the turbocharger oil supply tube are replaced. Turbocharger bearing failure may occur if oil starvation occurs due to a restricted filter.
MAKE   MODEL   YEAR
FORD    EDGE    2012-2019
FORD    ESCAPE    2013-2019
FORD    EXPEDITION    2015-2017
FORD    EXPLORER    2011-2019
FORD    F-150    2015-2019
FORD    F-650 SD    2017-2019
FORD    F-750 SD    2017-2019
FORD    FLEX    2010-2019
FORD    FOCUS    2013-2018
FORD    FUSION    2013-2019
FORD    MUSTANG    2015-2019
FORD    TAURUS    2010-2019
FORD    TRANSIT    2015-2019
LINCOLN    CONTINENTAL    2017-2019
LINCOLN    MKC    2015-2019
LINCOLN    MKS    2010-2016
LINCOLN    MKT    2010-2019
LINCOLN    MKX    2012-2014, 2016-2019
LINCOLN    MKZ    2013-2019
LINCOLN    NAVIGATOR    2015-2017
Gjkrisa
There's a turbo filter?
There are screens in the oil and MAYBE the coolant lines feeding the turbos.
Gjkrisa
How often should you be looking at these filters?
only when turbo replacement is required, or you find debris in the oil.
Quote from: Gjkrisa on March 26, 2019, 10:34:08 AM
Filters- X2 . $27.34  NEW OEM TURBOCHARGER FILTER 3.5L V6 FORD LINCOLN AA5Z-6C683-A .Z
https://www.ebay.com/itm/BRAND-NEW-OEM-TURBOCHARGER-FILTER-3-5L-V6-FORD-LINCOLN-AA5Z-6C683-A/362555418386?hash=item5469fca712:g:L3UAAOSwxbFcYl5g
