Connect issue see dealer on the radio, which fuse?
Started by Spyder3000gtvr4, March 18, 2019, 11:08:38 AM
Spyder3000gtvr4
I searched the forum and can't find it. It's happened once before and couldn't verify which fuse it was so I disconnected the battery for the night. Since it happened again after a few hundred miles I figure this is a thing that's going to happen fairly often and would like to just pull the fuse for 5 minutes. Anybody know exactly what fuse this is? 2010 sho
Kik: Spyder3000gtvr4
Got my Sho deciding to make it a DD or use it for my tube chassis build :)
try fuse 14 (10 amp) in the passenger compartment fuse panel.
Spyder3000gtvr4
Thanks for the info, It turned out to be fuse 39 20amp. I've read that you only need to remove it for a few minutes (I did an hour) hopefully this helps somebody else.
