Started by TopherSho, March 09, 2019, 11:34:31 AM
Quote from: TopherSho on March 13, 2019, 10:19:43 PM*if* the issues is just the head gasket.. should i do a water pump? Cars at 70k..
Quote from: jman on March 25, 2019, 11:17:21 AMDid you do the compression test?
Quote from: SHOdded on March 25, 2019, 03:08:15 PMBest of luck!
Quote from: TopherSho on March 25, 2019, 08:47:10 PMQuote from: SHOdded on March 25, 2019, 03:08:15 PMBest of luck!I am so confused. This car makes no sense ... all three bank1 injectors are leaking. how? ... all at one time INSTANTLY?? makes zero sense. compression test came out fine.. injector test hard failed on 1,3 and 5 was meh.I give up on trying to understand ... done-zo..baffled...utterly baffled...
Quote from: jman on March 25, 2019, 08:49:55 PMI'll take that outcome 100 times before a blown head gasket or damaged valve...
Quote from: MiWiAu on March 25, 2019, 09:02:35 PMQuote from: TopherSho on March 25, 2019, 08:47:10 PMQuote from: SHOdded on March 25, 2019, 03:08:15 PMBest of luck!I am so confused. This car makes no sense ... all three bank1 injectors are leaking. how? ... all at one time INSTANTLY?? makes zero sense. compression test came out fine.. injector test hard failed on 1,3 and 5 was meh.I give up on trying to understand ... done-zo..baffled...utterly baffled...Just curious, how many miles are you at? And do you do any regular fuel system cleaning?After my stuck injector (around 34k miles maybe?), I ran 2 stroke oil in every tank for 2 years (probably close to 40k miles). Never had a repeat, but stopped with the mix because it was too much of a pain for my wife when we swapped vehicles. I just ran a bottle of Amsoil PI through the last tank. Don't really notice a difference but hoped it might keep the injectors clean. Kinda paranoid now after first failure around 34k miles. Still not sure if the stuff is snake oil or what, but it makes me feel like I'm doing something preventative. Sent from my iPhone using Tapatalk
