2013 XSport - DTC P0016 - Camshaft Position Correlation, Bank 1
Started by MiWiAu, March 05, 2019, 10:07:52 AM
ebutler92
How long have you been running with your BOV dumping to atmosphere?
MiWiAu
Quote from: ebutler92 on March 12, 2019, 03:20:22 PM
About 2.5 years / 45k miles. The blow-off is pre-metered air on the EcoBoost, so it won't cause any runability problems like it can on other turbo layouts.
Frankly, I'll probably just leave the BOV hoses on after I reinstall them tonight.
The release is quite loud with both the front and rear hoses removed (rear points directly at firewall). If you want a more muted effect in the cabin, you can remove just the front one.
2013 XSport
SM105K
Quote from: MiWiAu on March 12, 2019, 03:36:17 PM
I vented mine to atmosphere within the first 24 hours of owning my SHO.  I love how quiet the car is overall, and when you want to give someone the business give them the BOV's!  lol.
ebutler92
Well an update. Glad I took my xsport to my friend shop rather than ford. Did a leak test with the smoke machine finding the rear bov was stuck open. Took it apart and found the rear had a blown diaphragm. This is most likely the cause of my stutter and issues. Much easier fix than the timing chain. Will update after replacement of both
MiWiAu
Was reinstalling my BOV plumbing and noticed the dealer left the boost reference line disconnected, which explains the noise and erratic BOV discharges. Reconnected it and tightened the charge pipe retaining nut that they left loose, and I seem to be back in business for the time being.
I hope the attention to detail on the internal work exceeded that of the external work.
Quote from: ebutler92 on March 12, 2019, 08:21:47 PM
Thanks for the update! Hope this gets you sorted!
2013 XSport
Fingers crossed, that is all it is. One step at a time :)
ebutler92
Under further investigation the oil smell was in fact from the PTU leaking on the exhaust. That's out and being freshened up as well.
ebutler92
MiWiAu
Quote from: ebutler92 on March 13, 2019, 02:46:01 PM
Super interesting. Were you down on power as well?
Just curious, did you have your BOV vented to atmosphere? If so, did it make a horrendous noise under boost with the ruptured diaphragm?
If it had the original plumbing hooked up, I'm wondering how it was caught with a smoke test, since it would essentially be closed loop at that point.
2013 XSport
ebutler92
Never did the vent to atmosphere thing. Never interested me. Cold air provided enough sound to satisfy my needs. But anyway, we pulled off the recirculation tube that then BOV's are mounted to and plugged both ends and port. It should have been a closed loop and no smoke should escape. Except the bov for the rear was stuck open allowing smoke to pour out. That's why we took it apart and discovered the bad diaphragm
MiWiAu
Quote from: ebutler92 on March 13, 2019, 03:36:14 PM
Nice. That makes sense. Thanks for clarifying!
2013 XSport
ebutler92
Sorry, to answer the other question. Yes it was down on power.
10bird
My 2013 SHO is getting the P0016.  It has 97K so it probably needs a new chain.  Are there any upgrades that could be done at the same time to save labor? Would installing an intercooler be easier if done at the same time?
nickstewartroc
Quote from: 10bird on March 18, 2019, 09:56:14 AM
Should replace your water pump while in there, and while you have it apart probably a good time for the intercooler as well!
Current:
2013 Ruby Red Flex Limited EcoBoost, Unleashed Tuned, drop in filter
Gone but not forgotten: 2011 SHO Non-PP in Black Tuxedo Metallic - Catback, DPs, Stoptech Z23s, MDesign CAI, LMS Tune
