BENDIX & WAGNER Rotors!
Started by ZSHO, March 01, 2019, 05:45:17 PM
Quote from: SHOdded on April 12, 2019, 08:38:32 PM
The only cautionary note I would have with aftermarket fluid in 2013+ SHOs is that DOT 4 LV is specified.  This fluid is low viscosity, and meant to improve ABS/traction control in lower temps.  There are a couple of mfrs that make compliant fluid, but match up specs to be sure.
No LV (Love) Z  :D
Thanks Manu!  :) I used Pentosin on my German imports with Good results!
https://www.fcpeuro.com/products/dot-4-lv-brake-fluid-1-liter-1224116
[BRAKE FLUID FOR COMPARISON]
Product Name
Dry boiling point
Wet boiling point
Motul RBF 660
(Track)
325 °C (617 °F)
204 °C (400 °F)
Motul RBF 660
Motul RBF 600
(Track/AutoX/HPDE)
312 °C (594 °F)
216 °C (421 °F)
Motul RBF 600
ATE Type 200
(Daily/AutoX/Light Track)
280 °C (536 °F)
198 °C (388 °F)
ATE Type 200
Pentosin Super DOT4
(Daily/AutoX)
265 °C (509 °F)
165 °C (329 °F)
Pentosin Super DOT4
BMW Brake Fluid
(Daily)
265 °C (509 °F)
170 °C (338 °F)
Genuine BMW Brake Fluid
ATE SL.6
(Low Viscosity) (Daily)
265 °C (509 °F)
175 °C (347 °F)
ATE SL.6
Pentosin DOT4 LV
(Daily)
265 °C (509 °F)
170 °C (338 °F)
Pentosin DOT4 LV
Rowe DOT4 LV
(Daily)
260 °C (500 °F)
170 °C (338 °F)
Rowe DOT4 -LV
PENTOSIN DOT 4-LV
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,brake+&+wheel+hub,brake+fluid,11389
SPEC'S
Size   1 Liter
Boiling Point   =265°C/=509°F
Density at 20C   1062 kg/m³
Flash Point   >130°C/>266°F
Ignition Temperature   >200°C/>392°F
Kinematic Viscosity at 20C   12 mm²/s
Kinematic Viscosity at 40C   6.4 mm²/s
Kinematic Viscosity at 40C   < 700 mm²/s
Melting Point   >-50°C/>-58°F
pH Value   Slightly Alkaline
Wet Boiling Point   =170°C/=338°F
Color   YELLOW AND CLEAR
When this gentleman "tested" viscosity above freezing, the flow of fluid wasn't all that dissimilar between types.  Below freezing, however is where the difference was. Since you are in a state well known for icicles and the like, you can evaluate how it works for you.  If you had motorcraft oem fluid in there, especially.
https://www.youtube.com/watch?v=YpMcG3WiN8M
I purchased a quart of PENTOSIN DOT 4-LV @ local Autozone for  $19.99!
  :bigthanx:  to SHOdded for pointing out the difference in LV Compatibility.  Z  :)
ddlopes
2013 SHO P/P mods: EcoPower Parts dual CAI, 3 bar, PPE catted down pipe, SCT X4, 170 degree thermostat, SNOW PERFORMANCE methanol stage 3 with ProMeth staineless steel braided lines, AeroForce gauges, Hot pipes, custom boost activated cutout xpipe, tial bov, Tial Wastegate mod, GH intercooler, MSD coils, AFE throttle spacer, UPR catch can, Rovos Durban wheels, AJP tuned to 389hp and 503trq on mustang dyno
