Gearhead and LMS E30 Tunes Dyno
Started by StealBlueSho, February 27, 2019, 09:55:56 PM
StealBlueSho
Quote from: sm105k on February 28, 2019, 01:58:03 PM
Quote from: ClearwaterSHO on February 28, 2019, 01:48:09 PM
Quote from: 802SHO on February 28, 2019, 01:45:57 PM
Ok.  I asked because I would like to think even a potent 93 tune would net you under a 13.  Based on the time alone it sounded like something wasnt quite right.  Hopefully you get it sorted out.  Your E30 tune for sure will beat the 93 tune but 93 should have done better.
  Yea, I thought so too. I was honestly expecting to be close to what my E30 tune ran before the IC with the 93, but I guess I was over ambitious about it. Won't be able to run the 1/4 again until March 16th. I'll be able to go to the 1/8th mile next Wednesday, but it's going to be cool out and I'm not sure the stock HPFP can keep up with the E30 tune in 40-50 degree weather.
You should be stable with the fuel pressure in 40-50 degree weather.  I was with a little more wiggle room.
Depends on the tune and the car...
creepmuzik
Quote from: BJSHO on February 28, 2019, 12:38:49 PM
Quote from: creepmuzik on February 28, 2019, 12:37:31 PM
Looking forward to track results.  Gonna be running mine in about 2 weeks, this time I'll make sure I had good fuel, lol.
Well HELLO Ben! I see you have finally made your way to the forums. Welcome! Make sure to post an introduction as well!
Hey guys, lol.  I've actually been a member for about 2 years.  Just pop in for research mostly.  Where do I do an intro post at?
2014 SHO non-PP Tuxedo Black
GH E30, GH IC, Xdi-35 HPFP, PPE catted DPs, J2 Fab Dual Inlet CAI, MSD Coils, H&R Springs, Torque Mounts, JLT Catch Can, Oil Cap Breather w/front vent delete, EPP Noisemaker Delete, NITTO NT555s on stock Flowers
PB: 12.1 @ 112 mph - DA 0-200 [w/Airaid CAI and before IC]
StealBlueSho
Quote from: creepmuzik on February 28, 2019, 02:00:05 PM
New Member Introductions on the forum page at the top.
ClearwaterSHO
Quote from: BJSHO on February 28, 2019, 01:59:23 PM
  Well, I did some logging last night and I was at 2k on the Fuel Pressure. I'm not great at reading logs, so I'm not sure what other fuel pressure numbers you need to look at.
2013 NON-PP SHO Tuxedo Black
Unleashed 3 Bar Tune -12.865 @ 106.5
AJP POWERED Tune - 12.59 @ 108.?
Mods: GH Intercooler, E30 Tune by AJPTurbo, SW Catless DP's, H&R Springs, MSD Coils (Is this a mod?)
SM105K
#34
Yes all cars are different.  I digress, mine is stable yours might not be.
Welcome Creepmuzik! INTRO is on the below link.  Z   :)
https://www.ecoboostperformanceforum.com/index.php/board,14.0.html
4sfed
Quote from: sm105k on February 28, 2019, 11:43:30 AM
My car didn't make any more HP or TQ with the GH IC.  It made the almost the same, but with less boost.  Brad and I seem agree that my turbos are getting tired, and the new intercooler is making them work harder because of how efficient and how much volume it flows. The IC works, I have a boost problem.
I'm assuming the ATP turbo upgrade would do it, but...would upgrading the impellers be enough?
2015 SHO, GH E30 tune, GH intercooler, 3 bar, SP542's, PPE Cat'd DP's, XDI-35, H&R springs, AD Gen2 mounts
Factory Five Mark III, 2004 Mach I donor (gone)
2003 Mustang Cobra 'vert, 456 rwhp, with mods (gone)
2002 MB C32 AMG (gone)
1997 Cobra 'vert, Vortech'd (gone)
SM105K
I think a compressor/impeller upgrade may be on the horizon.  I can't be completely rule them out.
StealBlueSho
#38
Quote from: 4sfed on February 28, 2019, 03:32:55 PM
So, ATPs are nice, but the wastegate it comes with is not correct for our application from what I understand. I know one guy who had to make some major adjustments to get it right, and he still isn't happy with it. The only people who don't have those issues are the LMS installed ATPs. They order them with a different wastegate setup, however, they won't tell me which wastegate they order them with.
EDIT: They don't order them from ATP with any different setup, as I just spoke with ATP 2 minutes ago. They only offer them one way. So whatever adjustments are made, happens after they ship by Livernois.
802SHO
And let me guess the only way to get them is an in house install?  What about GH turbos?  Are they ready for sale yet?
StealBlueSho
#40
Quote from: 802SHO on February 28, 2019, 05:42:09 PM
No, not yet..I'm working on getting my shop to get a quote for them from Gearhead. If we can make the time line work, then the shop will add some margin to it, but then the turbos and labor will be under warranty.
In short... I have a quote from LMS and working a Gearhead quote...
Jordan
Quote from: BJSHO on February 28, 2019, 05:10:37 PM
To be fair he was having crazy wastegates issues to his stock turbos before the ATP turbos upgrade as well.
StealBlueSho
Updated dyno graph with LMS best vs GH best.
802SHO
#43
Its nice to see the comparisons on the same graph...it looks like Livernois was your stock file and GH when you are tuned...its that much of a difference between the two tunes.  I think that's very interesting and again shows how much can either be left on the table or as much as possible utilized from the same recipe of parts with the only exception being the tune.  Cool stuff.  And Livernois is very potent and safe so no discredit to them.  These are both great companies.
I'm assuming you will be doing another dyno comparison when you upgrade your SHO further in late April?
StealBlueSho
Quote from: 802SHO on March 15, 2019, 05:58:05 AM
No, I would need to schedule time to drive to LMS for a custom tune. After the turbos and downpipes it will be GH tuned for the foreseeable future unless I want to drive to LMS for a tune.
