- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: 18SHO on February 20, 2019, 05:27:54 PM
Quote from: ZSHO on February 20, 2019, 05:04:27 PM
Quote from: 802SHO on February 20, 2019, 12:18:41 PM
I didn't know the PP shock/strut made the ride more stiff. There are some mods you have to expect will change the way the car feels for better or worse. Personally I hate wheel gap. I actually would like to slam it with coilovers to tuck a little more tire but the intercooler among other things is what I'm after right now.
If the wheel gap has improved I'm happy. Better stance, improves handling....is all that matters to me.
I believe the PP-SHO Struts are categorized under "Heavy duty" applications similar to the PI sedan which would make them a bit stiffer AFAIK. Z
I'm now curious about a couple things... new shocks and struts upon install no matter PP or non PP may have a break in period and have a rough ride for a period of time and I'm also curious if a non PP shock and strut setup may be better for ride quality in general when going H&R . Already broken in shocks and struts and installing the H&R may have better first hand results
That is probably why mine felt great from day one with my non PP shocks warn in with 52k. Probably need replacement but not on my priority list right now. Learn something new everyday around here
