SP 534 Spark plug superceded?
Started by StinkinLinkin13, February 18, 2019, 01:47:07 PM
StinkinLinkin13
So is the SP580 an improved spark plug? According to rock auto it is a "replacement" for sp534. Just wondering if there is actually a difference between the two.
Livernois Catless downpipes with Totalflow mufflers - AJP E40/Meth tune - Firestorm HPFP - DW 300 LPFP - Kenne Bell Boost-a-Pump - 3 Bar Map - Alky Controls Meth Injection - 160° Thermostat - EPP Hot Pipes - AEM Dryflow Filter - BOV VTA - SSM Polyurethane Torque Struts - H&R Sport Springs - 20"x10" Niche Veronas on 275/40-20 DWS06 -
SM105K
I would assume they are the same "ish" plug.
I would say they are probably the same spark plug with just an revised part number (supercession) considering they are both Iridium! Dunno!
The last time the actual spark plug was replaced was many years ago from the Motorcraft SP-528 which were Platinum to the SP-534 Iridium plugs!  Z
MOTORCRAFT SP534 CYFS12YT3 - Replaced by SP-580; Iridium Replaced by Motorcraft SP-580
CYFS12YT4
https://www.rockauto.com/en/catalog/ford,2013,taurus,3.5l+v6+turbocharged,1503823,ignition,spark+plug,7212
Yeah, the SP528 insulators had a habit of cracking.  Thankfully no issues with the SP534 forward.
MiWiAu
Is 0.032" now the recommended gap for stock application on 2013? I have the new SP580 plugs arriving tomorrow. :)
2013 XSport
MiWiAu
Quote from: ZSHO on March 16, 2019, 07:17:53 AM
I believe it's 0.032 Gap. Z
PDF Below
https://drive.google.com/file/d/1Xl-w-ARLU5B3u1YTTlySAVHAppKocaBH/view?usp=drivesdk
Thanks, Z! That is the most common value I could find from various sources. Much appreciated! :)
2013 XSport
