- RotM Winner
- Elite Member
- Boosted
- Logged
Quote from: sm105k on February 15, 2019, 02:42:56 PM
QuoteMan if you crack 400 awhp tune only that will be epic! Since you're swapping out thr t stat why not upgrade it
We will see. She went 391/470 last time. Honestly IMO there is zero gain from a lower T-stat. We can go round and round, but operating temp is operating temp. In 118 degree heat, it does not matter. The T-stat is at mercy of how efficient the actual cooling system is. I laugh inside when people say put a lower T-stat in, and even when tuners recommend a lower t-stat. Here is a good read about this...
http://www.tuneruniversity.com/blog/2012/04/low-temp-thermostats-whats-the-advantage/
Haha thats funny after I posted, I thought later about upgrading it and not even knowing a difference...
