3.5eco transverse prone to water pump failures?
Started by lamrith, February 14, 2019, 08:21:26 AM
lamrith
I saw this mentioned a few times in the last month on various Facebook groups (yes I know lot of BS there hence why asking here...).  Supposedly according to them the 3.5eco transverse is prone to water pump failures?
I do not recall seeing it as ever even mentioned here or elsewhere until it came up on FB last month.  Any truth to it?
Wouldnt say prone, but does it happen?  Yes.  Lot of factors at play.  Overextended coolant change intervals,  overextended oil change intervals ( even with full synth), frequent hard acceleration/braking (affects timing chains), etc.
One of the problems is the location.  Being behind the front cover, it is a 14 hr book time job to do.  A bigger concern to me is the potential for coolant to mix with oil when the overtemperature warning is ignored and one keeps driving instead if pulling over right away.  That can damage the engine internally.
The pump itself has two seals.  Old coolant erodes the seals.  Chains develop slack.  Slack causes the pump to wobble, and the bearings to wear down.
SM105K
Quote from: SHOdded on February 14, 2019, 08:35:16 AM
Along with Shodded's explanation, people don't know about the lubricating properties of coolant.  It keeps the seals lubricated and that keeps the pump happy.  People believe that coolant is a lifetime fluid.......it isn't.  Change all fluids on schedule, and don't skimp.  Hell change them earlier.
There's nothing bulletproof or lifetime Fluids IMO and definitely change your Fluids sooner than later while avoiding Fords service interval recommendations for a peace of mind and costly repairs. Z
lamrith
So no more prone than any other vehicle basically.  They made it sound like it was a chronic failure, what you all are describing here is not a cause for concern like it was portrayed on FB.
I have had vehicles with chronic common issues:  STS-V eat wheel bearings often 20-30k miles and some start to fail, shifter park switch failures at <50k miles, as well as thermostats.  944's you have to replace timing belt every 3yrs regardless of miles..
thanks again as always guys!
BlueSHO
Quote from: ZSHO on February 14, 2019, 10:45:13 AM
Fords initial change for coolant is 6 years or 100k miles so you think that is too long?
Sent from my SM-G950U using Tapatalk
2016 SHO Blue Jeans
2001 Lightning
1996 Mystic Cobra
SM105K
Quote from: BlueSHO on February 14, 2019, 12:11:44 PM
Hell yes that is way too long.  Think of all the heat cycles coolant goes through just in 3 years......extreme hot and cold.
nickstewartroc
Current:
2013 Ruby Red Flex Limited EcoBoost, Unleashed Tuned, drop in filter
Gone but not forgotten: 2011 SHO Non-PP in Black Tuxedo Metallic - Catback, DPs, Stoptech Z23s, MDesign CAI, LMS Tune
Divide that by Two! I change mine @ 30K Intervals from PTU-RDU-TRANS-COOLANT-BRAKE SYSTEM FLUSH!
Something to also consider is severe duty or severe climate would require shorter intervals IMO!  Z
802SHO
Boy oh boy I've never had mine changed, don't know when it was last done if ever, got the car with 52k and I've driven 20k....better get this done!  Too close for comfort
SM105K
Quote from: 802SHO on February 14, 2019, 06:46:26 PM
I am in the same boat.  Bought mine at 51K and I have 69K now.  I am going to try and install my IC this weekend, so I will replace the coolant then.
ClearwaterSHO
My '13 is at 114k miles. Tuned since 51k. I can't count how many passes down the track. I will tell you that I have followed the advice of the good people on this forum in terms of maintenance and have almost 0 issues from my car. I even had to take it to Ford to have the rack and pinion replaced and they told me that the car is in pristine condition, aside from the rack and pinion issue at the time. I'm hoping to hear back from GH soon on the intercooler and we will see how much oil is in the stock one. I've never looked!
My Maintenance Schedule:
Oil - Amsoil Signature - 5k miles
Trans Drain Fill - 5k miles
PTU - 15k miles
RDU - 1 time a year around June
I had my coolant flushed last feb @ 90k because I knew the interval was coming and I was worried about the pump. After seeing I should do it even more often, I'll start doing that every 40k or 2 years.
2013 NON-PP SHO Tuxedo Black
Unleashed 3 Bar Tune -12.865 @ 106.5
AJP POWERED Tune - 12.59 @ 108.?
Mods: GH Intercooler, E30 Tune by AJPTurbo, SW Catless DP's, H&R Springs, MSD Coils (Is this a mod?)
802SHO
Quote from: sm105k on February 15, 2019, 08:21:59 AM
Good call, I'll wait until I do the same since the radiator will need to come out anyhow!
Just fill the radiator back up?  Our system burbs itself doesn't it?  Not sure if that's the correct term...lol
